Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-04-2012, 12:29 PM   #126
bigboybodry
bigboybodry's Avatar
Re: New project
looks great brother!!!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 04-04-2012, 02:22 PM   #127
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Originally Posted by Marv D View Post
Wow they do really really nice work. One question tho (totally unrelated tot he bar) Is that a cable throttle,, at your ET they don't require a toe-hook positive return?
I am probably required to have a solid linkage , just havent gotton there yet
Originally Posted by Rannos View Post
Truck looks great man. Can't wait to see it run.
Me too . Bought ET street bias plys for the race on the 14th and will be testing those on the 7th at the truck only race here in Baytown . I havent gotten a handle on the radial yet and dont have a progressive box , yet . I have a set of 29.5 x 10.5 trues in the garage im gonna try and fit under it also . These will be for bracket racing and some sunday night stuff .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-04-2012, 09:13 PM   #128
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
New windshield .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-04-2012, 11:38 PM   #129
Captainfab
60-66 Nut
Re: New project
The cage turned out nice....truck's lookin' good
Old 04-09-2012, 08:08 PM   #130
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
HPT truck shootout . Went a few rounds . Made adjustments after every round as the truck is way different with the cage . I was the smallest tire in the event and on a DOT with a street truck . All others were bracket race trucks . 80 % of the trucks there were street trucks with hard tires . I was at a huge disadvantage , but i made a few passes and got a few things lined out . Really have to look to even see the bars in it . Also got interveiwed and pictures taking and might be in street trucks magazine as they were covering the event .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-18-2012, 09:22 PM   #131
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well , I ran Street legal warrior last weekend and got flat out run over . I changed jets to my 200 tune up and bolted up the ET streets thinking i was gonna set the world on fire . Truck went 6.25 on 165 and drag radials . Now with 200 and bias plys it went 6.30 best pass . I went 6.37 to a 5.90 in the first round . Guy had a 3100# notch with an 88 mm that flat out rolled . I tree'd him and was ahead at 60' , but here he came . On the trailer quick .
Racing for us will be down for a couple of weeks with the nationals at the big track and several grudge events at the small track . Back to 7.0 index and bracket racing . The turbos took that class over .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-19-2012, 04:44 AM   #132
1ronnieluv
1ronnieluv's Avatar
Re: New project
Good to see you got the little truck running.
1ronnieluv is offline   Reply With Quote
Old 04-19-2012, 04:55 AM   #133
1ronnieluv
1ronnieluv's Avatar
Re: New project
Looks good!! Sure brings back alot of memories.
Old 04-19-2012, 08:33 PM   #134
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-07-2012, 11:54 AM   #135
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
2 day race weekend . 1/4 mile on sat and 1/8th on sunday at Royal purple raceway ( old HRP and 1/4 mile ) . The nationals were last week so the track was really good . Also first passes on 28 true 10.5's . Started out sat with a stumble tore the front off the old demon and change the pump , squirter gaskets and add 2 numbers to the front jets as i wouldnt have time to reopen it before 1st round . the stumble went away with the changes and off to first round . Ended up going 5 rounds and broke out , but a good day . It was hot and my reaction times showed it . Sunday was better . Cooler with some cload cover all day saturday in the 1/4 mile race the truck went 7.05 to 7.08 so i knew what to do . Stuck a 7.04 on it and let it eat . Reaction times were good truck was good then down to 11 cars and the stumble came back . Had 7.03 on it and we went .164 on the light ouch , he spun as he was out first and didnt know i was late . I drove it out and drug the shifts out and ended up a nose over at the strip with a 7.01 . All in all a good weekend . Now 4th in points Division 4
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-08-2012, 11:22 PM   #136
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
These things have changed my consistancy . One of the local small tire car guys hooked me up with a set of his take offs . 6 passes @3200 and a 706 with 2 kits . Just getting broke in for my truck .
Also had a small oil leak . Not bad enough to be backed out of the start line , but it has been there and i knew about it and it has been bothering me . Passenger side crear corner of the intake at the corner of the head and intake . Tore into it and cleaned everthing up . Gaskets are ordered and will be in tommorow . Swapping to the QFT 750 also . Got a list of about 10 things that i need to update this week . Testing friday night , as we have another 2 day event on the 19th weekend and im their .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-10-2012, 04:34 PM   #137
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got it back together with new intake and header gaskets . No more leaks . Well maybe a drip now and then from the trans selector shaft seal . Ill get that fixed also . I did get this today though.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-10-2012, 06:23 PM   #138
Marv D
Registered Truck Offender
Marv D's Avatar
Re: New project
What did they charge for the cert. Here in Az it is like pulling teeth to get the NHRA tech to show up at the track to do certs, then... $280 for his trouble. My Nova's 8.50 cert expired last month, as did the SFI trans case. Man <9.99 is sure a money pit!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-10-2012, 09:25 PM   #139
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well good to see someone knows how hard it is to get that little silver sticker .
The guy that did the Rollcage had 7 cars lined up within a 5 mile radius . I was luckily off work and loaded up and was their when he got their . He looked everything over to a t . Very professional . $200 Cash .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-11-2012, 11:27 PM   #140
Gobbles
Gobbles's Avatar
Re: New project
Sounds like a job I want, inspecting race cars for tons of cash, I could get used to that. Truck looks awesome, love the videos!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 05-12-2012, 03:59 PM   #141
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I got 7 passes in last night before the rain . The carb helped out my reactions as my worst was .041 and best being .008 Every pass was inside of those two . I also bought a pair of new tubes and rotated the slicks . It went 1.52 60' on motor which i thought was good . Still got a small oil leak and the only thing i havent touched are the valve covers . They are coming off next week .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-17-2012, 10:46 PM   #142
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Found the leak on the distributor slip coller . Made some modifacations to the throttle linkage to get wot . Just been running it through heat cycles every day checking for problems . Got a 2 day ET bracket event sat & sun . If i am out quick sat im loading up and going to HMP .
http://www.royalpurpleraceway.com/
there is a huge grudge event @ HMP
http://houstontruetens.com/image3/MAY19B.jpg
I would run 7.0 index and whatever .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-21-2012, 09:04 AM   #143
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Saturday double brake in the quarters and sunday down to 12 cars and bent the rear leaf springs . Good weekend . Moved up in points .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-21-2012, 10:08 AM   #144
Marv D
Marv D's Avatar
Re: New project
Congrats on the rounds! It make the whole thing worthwhile to get a good group of win lights!!!
Old 05-21-2012, 11:57 AM   #145
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Yea , it's more about going rounds . This is my first year over there and im the "new guy" funny they all know me by name now . Think we had 58 or 59 cars saturday for 1/4 mile and more sunday for the 1/8th mile race . fun weekend . Now to fix the truck . Call to Calvert .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-22-2012, 06:54 AM   #146
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Talked to Travis at Calvert today and he pulled up the specs from the Blue truck i had . Looks like they only make 2.5 inch springs @ 200 a # spring rate. This leaves me having a set made and then having them milled to 2.25 in front for the spring pocket or replacing the front mount . Also looking at moving to a 9/16" or 5/8" front eye bolt for safety reasons . Also considering a sllider style rear mount vs a shackle any input on this would be greatlly appreciated , ecspecially street drivability and manners .
I have been wondering why i had 7 degrees of nose down pinion angle . I took some of that out with a shim awhile back , looks like the spring has been flatting a little every pass for awhile . I'll be starting from scratch on the pinion angle with new springs and adjusting the heighth with the rear mount .
Looking at this front mount
http://www.summitracing.com/parts/AFC-50200/
and these sliders
http://www.summitracing.com/parts/AFC-20236S/
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-24-2012, 06:43 AM   #147
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well , ended up goung Mopar style front mount and rear slider . Speedway has the ball bearing slider for $49 each . The spring will be built to factory lengths and stock height and i willl adjust the ride height with the rear slider spacing off the frame . Also rear shocks are in front on axle and inboard of the leaf . These will be moved straight up and down and behind the axle . I am told the adjustments become more distinctive when the shocks are not angled and are vertical . Waiting on parts now going to the chassis shop tuesday after the long weekend . Im just letting the guy that did the cage do it .
I also bought a new ( used ) trailer . 24 ' enclosed with 4' side door and a/c and work bench . Picking it up saturday 20 miles east of Dallas .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-27-2012, 02:14 PM   #148
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Trailer deal fell through . Drove all the way to Dallas , 10 hours round trip , to find the trailer was from up north and had road salt type damage . Lost $100 deposit and $150 in fuel plus a day .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-30-2012, 11:53 AM   #149
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Looks like we are going to leave the shocks in their factory state an dadjust the bottoms to 1.5"-2" of compression and the rest extension . This will allow the springs and bars to work . Also looking at a Coilover in front to replace shaocks and remove all the torsion bar cross member and parts . Just going to make one change at a time . Hoping to have it back together by the weekend .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-30-2012, 03:12 PM   #150
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: New project
I saw you posting on HTR the other day and was wondering if it was the same hotrod80. Cool truck you have, and as close as youre running with Billy it must be fast! I've been considering stepping out of the lowriders and in to racing as a hobby.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
