Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-07-2012, 11:40 AM   #126
Chad215
Re: The Good, The Bad and Ugly from Harbor Freight
Originally Posted by Chad215 View Post
I've rarely had problems with anything I've bought from HF. I don't consider them high quality tools, but generally if I use them for what they were designed for, I don't have problems
Good-
Drill press
Angle grinder
nail guns
1.5 hp pancake compressor (abused for years, works great)
heat gun
BAD
HVLP paint gun- got the one with a can to do some painting around the house and nothing sealed properly, splattered horribly and after about 5 min the gun wouldn't stop spraying and ended up with a large mess.
I've been debating getting the little sandblaster with the 50lb hopper.
I got the little sand blaster last weekend-
Works fine for what it is designed for. I wouldn't try to do a whole frame with it, but it is called a spot blaster- I'm happy with it so far. Should save me a trip when I need some small parts cleaned.
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline   Reply With Quote
Old 02-12-2012, 02:02 AM   #127
flamingbig10
6.0 powered square
flamingbig10's Avatar
I bought a few things from harbor freight over the years, some work great, some work some what, and some don't work at all
the good
us general 56" roller tool cabinet, works great I use it at work for my every other day tools
us general 5 drawer service cart, Ive been using it every day loaded down with tools for a year and half, the only problem ive had is the floor has buckled, and it looks like the casters need a 4 wheel alignment
us general 4 drawer service cart, I purchased it for truck parts storage last month works great so fare
earth quake 1/2" impact works great it work just as hard as a snap on
bad
wire strippers I stripped about 5 12 gauge wires and they broke
1.5 ton aluminum floor, tipped over on me while I was changing a flat on the right rear on my truck dented the gas tank and bed
ugly
1/2 drive metric swivel sockets I broke two with one hit of the impact pieces went flying
I purchased a lot more thing then this oh its reminds me I haven't been since last month I'll have to make a run tomorrow
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-12-2012, 02:23 AM   #128
blime81
Laid Lo
blime81's Avatar
The magnetic parts dishes are the greatest! Never drop, kick or lose a bolt or nut again. One for each side of the vehicle for things like brakes plus a couple for your bench.
Has anyone else noticed that some of the Jegs tools are re-branded HF?
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 02-12-2012, 11:00 AM   #129
rpmerf
rpmerf's Avatar
I purchased a couple tool chests. My first was something like 5 drawers, large open area at the bottom, locking top. Its held up perfectly. A few months ago, I purchased a 13 drawer chest for about $350. I wish the drawers were a tiny bit deeper, but the overall quality is very good. Certainly worth what I paid for it.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-12-2012, 11:24 PM   #130
Mxracer202
Mxracer202's Avatar
Thinking about getting the 400ft wire store house cause it comes with wire. Anyone tried? Im thinking too good to be true?
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 02-28-2012, 11:52 PM   #131
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Probably better than I had...replaced my cheap, broken HF 1,000# wheel skates with these
new 1,500# skates (also HF). Reg price was $160 for 2 pair. Paid $126 with discounts (+ tax).
I'll post a review after loading a mid-70's Charger on them!
ETsC10 is offline   Reply With Quote
Old 02-29-2012, 01:40 AM   #132
Cue-Ball
Cue-Ball's Avatar
Don't hold your breath. I've read that even the 1500lb versions are very weak and that the casters are pretty poor. Supposedly, even very light cars refuse to roll. Keep your receipt handy.
Cue-Ball is offline   Reply With Quote
Old 03-01-2012, 12:21 AM   #133
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Thanks for the heads up. Guess I should have built some years ago.
Old 03-14-2012, 11:41 PM   #134
k1rodeoboater
I used the mini movers dollys on my truck...worked fine so long as you faced the wheels prior to moving. A pickle fork was an easy way to face the wheels in the correct direction. I also checked through the stack for good ones, and added grease before I put the truck onto them.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 03-15-2012, 09:01 AM   #135
FrankieD
FrankieD's Avatar
I bought 2 of the 3ton steel jacks they had on sale for $49 gave one to my cousin for letting me use his pole barn. Just bought the portable winch mount ($44.95) haven't used it yet but I can beef it up if I need to. I just found out that if you go through their on line site and click on something you want with in a few weeks it will show up on their on line sales flyer they send out. They will also take the coupon from your phone.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 03-28-2012, 12:01 AM   #136
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Picked up a 20 Ton press. The frame is well built but I understand the jack might fail me some day. I bought it with that understanding and already have a 20 Ton jack that I would trade it out with. I added casters to it so I can roll it around the shop. The casters are $4 each from HF. It rolls easy.
Torrey72 is offline   Reply With Quote
Old 06-01-2012, 12:46 PM   #137
ole dollor
ole dollor's Avatar
sinister: try taking the spray nosiel off the gun and see if there is a small o'ring on the needle behind the spray nosiel, if so take the o'ring off and throw the o'ring away, not the paint gun...dont ask me how i know this...its a secret....
ole dollor is offline   Reply With Quote
Old 06-01-2012, 01:08 PM   #138
ole dollor
ole dollor's Avatar
All i can say is everyone be real careful going to Harbor freight: you may not know this but "it is addictive", and as of this date and time their is no cure. and no you can never take enough money with you....be careful...
I know first hand
Old 06-07-2012, 11:47 AM   #139
butch86
butch86's Avatar
my biggest issue with HF is its to easy to stop in and drop 30 or 40 bux every day. i have lots of HF tools my favorite by far is the auto darkning welding helmet. i also have one of the 90dollor wire welders that use flux core wire. my biggest issue wit it is the wire is 100% hot all the time whenthe unit is on. i wish the wire was energized when you pull the trigger.
also have the 180 stick welder. i love it for anything you need to weld with a stick. mine is 8 years old now and i have to crank up the heat to full power for thicker stuff but it works great.
now HF welding wire and sticks SUCK big sweet potatos. i also love my HF $5 heat gun. and all of my junk yard tools came from HF. there channel lock type plyers suck too.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 06-08-2012, 12:47 PM   #140
Weasel Diesel
OK,... I lost my Snap-on snap ring pliers. Stopped by HF and got the 4 set of Pittsburg snap ring pliers. All 4 broke within first 5 minutes of use.
Weasel Diesel is offline   Reply With Quote
Old 06-09-2012, 01:06 AM   #141
BarryB
BarryB's Avatar
I know first hand
isn't that the truth! When the HF store first opened up here. I got accused of knowing how many tiles were on the floors. Yes I visited there a lot. I've bought several tools from there. I like being able to go to the store and actually look at the stuff before you buy it. When you could only order from their catalog it was a guessing game what you were getting.
I have the 220v 151 dual mig welder. I built my little utility trailer with it. only problem I have with it, is the duty cycle is lower than I normally like.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-11-2012, 12:55 PM   #142
NONHOG
NONHOG's Avatar
The only good thing about those pliers is you can twist them and wad them up like a pretzle before tossing them in the garbage.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 06-11-2012, 08:18 PM   #143
bean
i just bought their foldable engine hoist cause i had a coupon from classic truck. It was only $99 because of that. Used it twice without a problem.
bean is offline   Reply With Quote
Old 06-14-2012, 12:06 AM   #144
67lowered
Quote: butch86; my biggest issue with HF is its to easy to stop in and drop 30 or 40 bux every day. i have lots of HF tools my favorite by far is the auto darkning welding helmet.
I got one of those helmets too, hopefully yours works better than the one I got. Even after turning it to the fastest darkening, still too slow! I would see the initial arc, Then it darkened! saw 1 white spot for awhile. ya get what ya pay for
67lowered is offline   Reply With Quote
Old 06-14-2012, 10:52 AM   #145
ERASER5
ERASER5's Avatar
My $70 "Eagle" HF auto darkening helmet works great. As long as I lower the helmet first, I get no flash.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-14-2012, 10:53 AM   #146
Weasel Diesel
Sooooo.... Ya saying it's no good for the Nuclear Apocolypse either? That initial flash may be a tad bright??
Old 06-14-2012, 11:35 AM   #147
El Campo
El Campo's Avatar
I have some things from there. Some I love Some I hate
Good: air die grinders (as long as you oil them these 9 dollar things go and go)
mini air saw (the first one didnt work straight out of the box but the next one works as well as the 190 dollar one my friend has from Cornwell
Multimeter (cheap and works great, my friend who is at MMI [motorcycle mechanics institute] says they recommend this 40 dollar one from HF over the Snap On one)
Calipers
Bad: air fittings are complete crap and all leak soon
any wrench of theirs is horrible and does not fit as tight as it should, rounds off, breaks. Will never buy another wrench cheaper than Craftsman again (and I just got a set of 9 wrenchs from Sears on sale for 14 bucks how do you beat that?)
ratchets are equally terrible. I have definitely decided that Snap On and Proto ratchets or the premium Craftsman at the least are WELL WORTH the money.
cutting discs especially cut off wheels are junk, burn them up in 1/4 of the time that others take.
Many times when I use a tool from here I remember this: "The bitterness of poor quality remains long after the sweetness of a cheap price is forgotten"
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 06-15-2012, 12:23 AM   #148
67lowered
Blinding! not sure what shade I would need for that couldn't get it at HF
Old 07-11-2012, 11:32 PM   #149
1774btcrew
1774btcrew's Avatar
Let me start off by saying I have a parts locating business and spend the full day at the wrecking yard pulling parts. I have NO cheap tools in my junkyard bag at all with the exception of the harbor freight pick set. The fact is, I cannot afford to be at the wrecking yard and either mess up the part or not be able to get it because a cheap tool didn't work right. I also cannot afford to wait until the next day as I risk someone else getting the part before me. My tools are Snap On, Matco, Proto and Craftsman. That being said I NEVER pay retail on my tools and have had great luck scouring swapmeets, and yardsales to come up with some really incredible deals on quality tools. I am not one of those guys that has to have all of the newest, most expensive Snap On tools just to say I have them. What I will say is Snap On makes the best wrenches hands down.
The good
Screwdriver sets. These aren't bad and cheap enough to put in a tool box in each vehicle.
Gloves, good and cheap. It is hard to screw up gloves!
Their small 4 piece pick set. I use this on a daily basis. Literally! I am more than happy with these!
The bad
Pickle forks, these are JUNK! The fork spreads and flexes. Buy a good one. It will save a lot of headaches.
Snap ring pliers, these too are not worth owning! First time I squeezed the handles they bent!
Bearing seperater. This was on sale for $40 and I figured it would be fine for the occasional use. WRONG! The first time I used it one of the side bolts bent and the jaws chipped.
Steering wheel lock plate tool. These are junk as well. Too thin metal and bends/flexes with any tension at all on it.
Drill bits, weak and dull right away
Wrenches are a joke. These flex and never tight enough around the bolts.
1774btcrew is offline   Reply With Quote
Old 07-15-2012, 03:46 PM   #150
FrankieD
FrankieD's Avatar
bought an 8oz touch up gun worked great for spraying the inside of the fenders and rockers, also bought the little butane torch for soldering and putting wire shrink on works great
