Old 08-10-2011, 09:40 PM   #126
68 TT
Still plays with trucks
68 TT's Avatar
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
The T-56 is the same length as the 4L60E so the shifter should be within the high hump tunnel area.
The trans in the pic below is a 4L60E.
The worst thing you would need is an offset shifter handle to push the lever forward away from the front of the seat a little.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-11-2011, 10:32 AM   #127
67cheby
67cheby
67cheby's Avatar
70shortfleet, has one for sale on the for sale sec $75 shipped, looks nice too
67cheby is offline   Reply With Quote
Old 08-11-2011, 04:44 PM   #128
Hduramax
Hduramax's Avatar
just read your build from back to front, nice to see guys making progress on their projects cant wait to get back to mine. Really like the swap u have picked, modern power in a classic ride. Keep up the good work.
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 09-03-2011, 12:52 PM   #129
nibs
JRods Garage
nibs's Avatar
PERFECT! someone doing the same engine/trans swap as I am... in current day. I watch a couple build threads only to realize they are 5-6 years old. LOL definitely keeping up on this one
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 09-26-2011, 08:36 PM   #130
mcbassin
Still Learning
mcbassin's Avatar
What's up any progress?
mcbassin is offline   Reply With Quote
Old 09-28-2011, 07:00 PM   #131
trkfrk
trkfrk's Avatar
Thanks for asking..
It has been just over a year since I started the build. The wheels and tires are mounted and its finally on the ground. I completed the front end with a new power steering box and tie rod ends.
I have been stripping the doors and hood in preparation for primer. Luckily, the front clip is clean with no rust and very little body work needed. I have been contemplating on switching the front clip for a 67 grill but have decided to stay with the GMC double head light front grill.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 09-28-2011, 07:03 PM   #132
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-28-2011, 07:32 PM   #133
CParnell
CParnell's Avatar
Looking really good man.
1968 GMC 910 Project Tommy
1974 Olds Cutlass
CParnell is offline   Reply With Quote
Old 09-28-2011, 08:47 PM   #134
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Extremely clean build! One note though, I have the same red poly tie rod and link boots on the camaro clip in my 57 and they SQUEEEK like crazy when I turn the wheel!!
ChuckDriver is offline   Reply With Quote
Old 09-28-2011, 09:22 PM   #135
jasonhall
jasonhall's Avatar
Awesome progress!!
jasonhall is offline   Reply With Quote
Old 09-28-2011, 10:21 PM   #136
67cheby
67cheby
67cheby's Avatar
Clean....everything looks KILLER !!
Old 09-29-2011, 10:16 PM   #137
trkfrk
trkfrk's Avatar
Thanks for the input.. I do know choosing to go with the polyurethane has its pro and cons. Hopefully my engine will be louder than the squeak - LOL .
I appreciate all of the compliments! This board keeps me motivated!
Mark
Old 09-30-2011, 12:10 AM   #138
mcbassin
Still Learning
mcbassin's Avatar
Man, You have kicked tail on this build in only a year. I wish I could keep up with ya. Your sheetmetal looks great. Keep up the hard work.
1 question, how do you plan on painting the cab underside? I am almost to this point and wonder what the best order? I was thinking about painting the bottom firewall and interior before mounting on the frame. Then paint the panels before assembly.
Old 10-02-2011, 02:43 PM   #139
trkfrk
trkfrk's Avatar
I plan on pulling the cab off the frame and paint it on Jack stands. This worked well when I stripped and primer-ed the cab. I was able to prime it all at once. I also plan on removing the engine and transmission one more time. I am not sure of the condition of the clutch, flywheel and throw-out bearing. Thanks
Mark
Old 10-02-2011, 08:52 PM   #140
mcbassin
Still Learning
mcbassin's Avatar
Sounds like a plan to me. So have you decided on what kind and color paint yet?
Old 12-06-2011, 10:19 AM   #141
nibs
JRods Garage
nibs's Avatar
How do you like the F-body accessory drive? I like how clean it looks over the other OEM options, and I would be interested how it fits
Old 12-06-2011, 11:17 AM   #142
OLDIRON69
nice build
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 12-06-2011, 01:56 PM   #143
El Campo
El Campo's Avatar
I like the way you did the rear brake line through the frame. Did you build that?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-07-2011, 01:32 AM   #144
CROWN
^^^ what he said. Also what motor mounts are those and did you have to modify the frame for the motor to set in there???
CROWN is offline   Reply With Quote
Old 12-07-2011, 03:27 PM   #145
custom63
custom63's Avatar
I see that you used CPP tubular engine frame mounts but what adaptor plates did you use on the block? Are those Poly motor mounts? Compared to stock location, where does the engine site? Forward, back, higher, lower? How far off the firewall. And last and not least. Howd you squeeze the A/c pump in there? Are you going to have enough room to run the lines? Or are you going to have to do some frame trimming? I am at this point in my build and want to pull the trigger on parts but still dont know what the correct combination of parts are to make it all work. Any and all info is much appreciated. Keep up the awesome work!!!!!!
Tommy~
The difference between genius and stupidity is that genius has its limits
-- Albert Einstein
63 build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317341
custom63 is offline   Reply With Quote
Old 12-07-2011, 08:56 PM   #146
trkfrk
trkfrk's Avatar
I haven't decided on color. I am using Dupont products.
I thought it looked cleaner than the other options. It was more challenging getting the engine exactly where I wanted it. I did trim less than 1/2" on the inside of the frame rail between the core support and front A-arms to help clear the A/C pump. This should allow me room for the lines and not effect the integrity of the frame.
Adapter plates are also from CPP part#CPLS1-K. comes with the plate, poly mount and hardware. I moved the engine back around 2" from the stock location. This helped with the oil pan clearing the front cross member and filling in the gap between the firewall and the rear of the engine.
I made no modifications to the frame or brake lines except for shortening the rear lines before entering the Wilwood calipers.
Originally Posted by OLDIRON69 View Post
nice build
Thank You....
Mark
Old 12-07-2011, 09:55 PM   #147
72LSK10
72LSK10's Avatar
Very nice build, glad to see you chose a color other than black for the frame and suspension. I'm running the same drive train in my 72 SS Nova build and have the same model wheels, except that mine are grey centers. Great minds think alike. I'm leaning towards powder coating my frame a similar color, maybe the differentials also. Keep the pic's coming, looks great.
72LSK10 is offline   Reply With Quote
Old 12-08-2011, 06:17 PM   #148
brandy hickman
brandy hickman's Avatar
Im in on watching this build. Jealous
brandy hickman is offline   Reply With Quote
Old 02-17-2012, 03:43 PM   #149
darkgable79
Any updates?
darkgable79 is offline   Reply With Quote
Old 02-27-2012, 10:40 PM   #150
franky69c10
chevy runs deep
franky69c10's Avatar
TTT
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
