Old 08-23-2015, 05:49 PM   #126
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Jesses' 48 PU
Wow Jesse, thought you fell off the edge of the world!
Nice update, keep it going Bud just a bit at a time (like I should talk). What did you finally decide to do with the engine?
Don't forget to post an updated photo of your little friend; he's what? About 19 now?! Lol
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-24-2015, 04:38 PM   #127
Jesse49chevy
Jesse49chevy's Avatar
Re: Jesses' 48 PU
Hey Dan, well it felt like I fell off the side of the earth, a lot has happened in the last year or so. Mainly good stuff, but kept me very busy and it seemed as if the truck slid to the back burner. But well, I am going to work on it every chance I get.
No, my little buddy is not 19, he is 7 and he keeps me busy. Baseball, school, Wii, PS3 etc.... the kid just wont run out of energy!
As far as the engine, well have not made up my mind, I regret getting rid of the LS1, I got a great deal on it and well to be honest, I want to go with a LS1 or LS2. The 454 my brother in law has will require too much. I can get a complete LS1/2 for about 2k, to think that I already had one! Below is my little buddy... I swear the kid is coolest, at the pace I am going, he will be driving the truck when he goes to high school!
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 09-07-2015, 08:04 AM   #128
rollinrooster
rollinrooster's Avatar
Re: Jesses' 48 PU
Hey man stay at it!!!! and spend as much time as you can with your little best friend. I was looking thru your post and thought about the time spent with my little best friend... now he's almost 17!!! and will probably get to drive the '49 to school. Anyway good luck and keep us posted.
rollinrooster is offline   Reply With Quote
Old 09-23-2015, 06:18 PM   #129
Jesse49chevy
Re: Jesses' 48 PU
I am no where near the point where i need the engine. But i am always looking in Craigslist or Offerup app for that special deal. Well today i scored what i think is a good deal on a LS2 6.0 engine. It was pulled from a 2002 Escalade with 98k miles. He wanted 1500.00 for the engine trans computer and hareness, but because the tranny is set for 4wheel drive my buddy said we can use a 700r instead. Long story short, i paid 850.00 for the engine, wire harness and computer. I feel its a good deal.
Semper Fi
Old 09-23-2015, 06:20 PM   #130
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 09-23-2015, 06:22 PM   #131
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 09-23-2015, 10:24 PM   #132
ricott
Re: Jesses' 48 PU
That is a smoking deal on a 6.0!! If it is out of an escalade, it should be a LQ9 engine - rated by GM at about 360 HP. I have one in a 1966 GTO and it is a great engine. Looking forward to seeing you get this in the truck.
ricott is offline   Reply With Quote
Old 09-23-2015, 10:31 PM   #133
Advanced Design
Advanced Design's Avatar
Re: Jesses' 48 PU
That was an outstanding deal! They are around 2k here. Looking forward to the next steps.
Advanced Design is offline   Reply With Quote
Old 09-23-2015, 10:45 PM   #134
Dan in Pasadena
Re: Jesses' 48 PU
Good looking boys you guys have. EXCELLENT that you've got them involved with their dads on well, almost anything. As long as they're with you they're talking to you and that's always a good thing!
Old 09-24-2015, 01:40 PM   #135
Jesse49chevy
Re: Jesses' 48 PU
RICOTT, what transmission do you have in your car with the LQ9?
I am getting conflicting info on what trans I should run. I have a 4L60 in my garage from an earlier deal, I am being told I will burn it out quick if I use it/.
Semper Fi
Old 09-24-2015, 09:24 PM   #136
ricott
Re: Jesses' 48 PU
I have a T56 six speed out of a 2000 Camaro behind the 6.0 that is in the GTO. I can tell you that the 2002 Camaro ran a 4l60e and that engine (LS1/6) was rated by GM at 330HP. The corvette of the same vintage also used a modified 4l60e (bolted to the transaxle) and in 2002 it was rated at 405 HP.
I can tell you the 4l60 will work fine, but if you beat on it (drag race it), you probably will wind up having to rebuild it. I can also say that I have had even less luck beating on a 700r in a corvette I had. For ease of wiring and operation, I would go with the 4l60e. I am currently using this combo (LS1/4L60e) in a 58 vette we are restomoding.
Good luck with your project!
Ricky
Old 09-24-2015, 09:54 PM   #137
Jesse49chevy
Re: Jesses' 48 PU
Ricky i appreciate the info. Ill stick to the 4l60 i have.
Semper Fi
Old 10-11-2015, 05:11 PM   #138
Jesse49chevy
Re: Jesses' 48 PU
Was able to work on my truck for a bit, I mounted the fuel tank. I used some 1/8 inch thick 1" square tubing Left over from a fence project from a while back and some 1/8 inch thick 1" flat stock I also had in my scrap pile. The flat stock was to thin and it flexed a bit when I mocked it up so I welded a piece on to at 90 degrees in the center to give it some support. It worked just fine.
Semper Fi
Old 10-11-2015, 05:12 PM   #139
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 10-11-2015, 05:14 PM   #140
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 10-11-2015, 05:19 PM   #141
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 12-13-2015, 09:36 PM   #142
Jesse49chevy
Re: Jesses' 48 PU
Hello world, it's been a few weeks. I've been working on my truck on and off, making a little progress at a time. I started working on the cab. After taking a closer look at the floor, I realized it was rusted through pretty bad in some areas, so I decided to replace it. The front floor pans are new, my dad had replaced them for me already so it's just the back part I need. Once I cut it off, I fixed the inner corners by making some patches and welding them solid. I used 1/8" thick 1" square tubing to weld in a frame for my new floor panels. I need to grind my welds, weld in my floor and flip the cab over to weld the bottom side. I plugged a few holes on the firewall. I didn't bother counting them, but I am sure my neighbors hate me by now with my grinder going non stop for an entire day.
Semper Fi
Old 12-13-2015, 09:38 PM   #143
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 12-13-2015, 09:39 PM   #144
Jesse49chevy
Re: Jesses' 48 PU
Semper Fi
Old 12-16-2015, 11:12 PM   #145
Jesse49chevy
Re: Jesses' 48 PU
Guys I have a concern and a question. On my truck I don't have the rear cab mounts that I see on others, when I took it apart I clearly remember only having to unbolt the cab from the two front corners and the center of the rear. I have looked at all of my pics over and over and it doesn't have the rear corner mounts or supports. (as shown on the pictures below from other projects i've seen in here) is this normal? did all trucks not have these supports, should I be concerned about it? Any information will help.
thanks.
Semper Fi
Old 12-17-2015, 12:22 AM   #146
chev3600
chev3600's Avatar
Re: Jesses' 48 PU
That's normal. 47- Early 49 used single mount in the center. Late 49+ used the shackles.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 12-17-2015, 12:24 AM   #147
Jesse49chevy
Re: Jesses' 48 PU
I appreciate the info.... I was worried.
Semper Fi
Old 12-17-2015, 12:24 AM   #148
wood1
Re: Jesses' 48 PU
'47-'48 had center mount rear. So only 3 mounts.
Changed to 4 in '49
wood1 is offline   Reply With Quote
Old 01-07-2016, 05:05 PM   #149
Jesse49chevy
Re: Jesses' 48 PU
Update on my project. Been working on it whenever I have a chance. I have been working on the floor, I laid the cab on its back and welded the bottom. I then flipped it back, cleaned up the welds and sprayed some chassis black on the 1 x 1 frame I installed. I patched the rear of the cab. I used an old hood I had laying around from my daughters car. No I did not leave her car without a hood, a while back she was involved I a minor accident and the hood was damaged. It worked out great for what I needed. I hope to cut up the floor panels this weekend and weld them in.
Semper Fi
Old 01-07-2016, 05:08 PM   #150
Jesse49chevy
Re: Jesses' 48 PU
this part of the cab was seriously damaged and rusted through in several places. So instead of doing 10 little patches I decided to do one big one. Worked out.
Semper Fi
