#126 |
Re: Loadmaster '47 COE
Hey Rob,
I'm looking at a 48 Coe that had just arrived here in Australia and was wondering do they have the same leg room/ cabin size as a 48 4400 truck? I have one of those but I'm 6ft7 so I'm concerned the Coe is smaller? great work with your truck with only a few weeks in it mate! Thanks Shane
Australian GM/Holden Dealer 1937 Chev Rod - LS1/4L60E 1949 Chevy 4400 Dually - 235ci/4L60E 1958 Chevy Apache Fleetside SBC/T400 |
#127 |
Same leg room, just a hump in the floor which covers the valve cover, same basic cab just modified firewall and floor and lower doors.
My '47 C.O.E build |
#128 |
6>8 Plugless........
![]() Join Date: Sep 2007
Rob, great work. The cab looks great up high. I like that visor too! You could make an enclosure and put all the electronics in it under the hood so it's easy access. I don't remember, is you radiator going up front or in the rear? I'm thinking of putting the radiator up front on mine. If I can fit it behind the grill and still shut the hood.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#129 |
Thanks, I'm really not sure yet on the radiator. I need to see if it will fit under the cab using the original fan. I will try and use the donor radiator to save a few bucks. So far the donor is working out great, it even looks like I can reuse the rear drive shaft at it's stock length, the fuel tank in it's stock location, the exhaust from the muffler back and the spare tire mount.
Rob
#130 |
Well that'll be great. Save a lot of work. Speaking of work, what work do you do in China?
#131 |
Maintenance support, we built a new factory here and I was sent here to teach the Chinese how to maintain the equipment. It's good work.
Rob
#132 |
Sounds pretty good. That part of the world is getting filled with factories with owner relationships with the US. Good luck with it.
#133 |
![]() Join Date: May 2007
ha seeing the santana taxicab flashes me back to my march trip, we went to shenzhen, nantong, and shanghai, those santanas were all over shanghai.
I googled bar j ranch in colorado and they have a website. http://awesomecoloradoland.com/bar_j_ranch.htm cool project! you really get after it.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#134 |
Thanks for the link, I have seen some for a dude ranch but that one is actually only about 150 miles from where I bought the truck. I need to find the ranch owner to see if any pictures are available from when the truck was in use, now that would be cool. By the way, I live in Shenyang at the Crown Plaza Hotel, yes, I live in a hotel
![]() Thanks again, Rob
My '47 C.O.E build Last edited by 47 Fasttoys; 05-26-2014 at 08:03 AM. Reason: added stuff |
#135 |
I love those old COE - cant wait to see it done!
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels |
#136 |
I am about to start a 1946 COE build. I appreciate you taking so many pics. So far i have the 1946 COE cab and a 50 long narrow bed. I traded some stuff for a running 1994 Chevrolet 3500 with a 6.5 diesel in it. I want a diesel and do not want to mid mount the engine because I want to use the bed. Anyway, keep putting the pics up they are very helpful..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#137 |
All right guys, I'm looking for a little help here. As you have seen, I'm running a mid mounted drive train. My plan is to make an electrical shifter using a linear actuator, control board, some resistors and some switches. What I need is some measurements for a 4L60 transmission shift arm. So, if you have a transmission laying around and you have a few minutes please have a look at the drawing below. You can also see what my feeble mind has come up with for the bed.
Thanks, Rob ![]() ![]() ![]()
#138 |
Man you need to stop having so many cool ideas cause its making my drive to do a COE too big. Got alot of irons to cool down bf I get on mine. Sorry I'm of no help on your measurements. Can't wait to see this thing come together.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#139 |
Ok I have some measurements for you.
2 and 1/4 center to center on shift arm 7 and 3/8 from the leading edge of shifter bracket to center of shift arm pivot at full retraction 10 and 3/16 from the leading edge of shifter bracket to center of shift arm pivot at full extension I hope these will help you out.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#140 |
Thank you very much Ghetto, that's just what I needed. Yes 99 I have a few ideas, that seem to one of the things with my working away from home right now, I have a ton of time for planning and saving. I have a lot of things worked out on paper (or computer in this case). As the shifter project comes along I will post some updates. I will build a working model before I return home to work out some of the bugs.
Rob
#141 |
A little update, I ordered a linear actuator (4 inch stroke), a control board, a position display and a power supply. Locally a bought some components and built a resistor circuit and switch set up to control the position of the actuator. I was only able to find a 6 position switch in the style I liked so I will be limited to 6 positions. All are adjustable, so for now I will have P,R,N,D,3,2 with no first control. I could give one of the other gears if needed (maybe neutral). Anyway I have tested the control circuit works good. I'm still waiting on the other parts to arrive. So this little silver knob is my shifter control.
![]() ![]() ![]() Rob
#142 |
![]() Join Date: Jul 2012
Very creative! Looks like a product that could be packaged and sold.
#143 |
Really nice build. Subscribed. Thanks for the help on mine. Dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#144 |
OK, so I got some parts in today, played with some wiring and presto! I now have have a prototype for my shifter. Click on the picture to play a crappy video. The actuator is kind of small but it's rated at around 15 lbs. so it should move a shift lever just fine. I can adjust it to stop in any of 6 positions and it repeats to .02 mm. It also has adjustments for speed, sensitivity and range of motion. Same force, push or pull. Overall very pleased but I may need to use a different switch as this does not feel like it would hold up for long.
![]() Rob
#145 |
That is neat. One thought for the switch would be to use a third gen camaro shifter or a C4 Corvette shifter. The Neutral Safety Switch (NSS) is attached to the shifter and, as I recall, the switch has an output for each gear/position. When you moved the shifter, it would output through the NSS based on the position of the NSS . This should allow you to have a "shift by wire" setup using the traditional shifter (if that is the look you are seeking).
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#146 |
Nice!
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120 1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806 1966 C10 SB Custom Cab, Fleetside, BBW. 1968 Chevelle SS 396 1937 Chevrolet Coupe |
#147 |
The transmission (4L60) has a position switch on it which includes a NSS. I will use some of the outputs and LEDs for gear selection indicators. The plan is to adapt the throttle knob to replace the aluminum one. This knob has a "T" on it for transmission. Other then the knob I don't plan on having a normal shifter.
![]() I still need to figure out what to use the "C" or choke knob for. Rob
#148 |
"C" is for Cruise!
#149 |
Well now that's a good idea, I was thinking cargo, as in cargo light but cruise works even better. My plan is a one button cruise activation with it being "on" in the back ground all the time. The rest of the cruise will be all the factory hook ups.
#150 |
Very cool shifter set up you have made there sir!
