Old 05-09-2014, 10:22 PM   #126
OrrieG
OrrieG's Avatar
Re: Project "Schrum" 1959 Gmc 100
Dome light should be orange wire and white wire, running from the light switch up the front door ("A") pillar then around the top/side to the dome hole. Don't pull the wires out of the pillar, it can be a challenge to get them back up there. If the headliner is out and the wires are AWOL bend up a wire and start fishing down between the inner and outer cab above the door, you should hook them. I had to do this when I used the old wires to pull in the new harness.
OrrieG is offline   Reply With Quote
Old 05-09-2014, 10:40 PM   #127
SCHRUMGMC
SCHRUMGMC's Avatar
The old Factory dome light was a Single prong connector like on the ignition switch. How do I hook it up? What end do I need
Does one of the wires go to the fusebox? if so the wires are way way too short
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 05-10-2014, 12:16 AM   #128
lowrodderchev
lowrodderchev's Avatar
got to tell man probably would be easier if you bought a new wiring harness. new harness is around $140 plus few extra dollars for misc. but youll be all new and pretty I put one in my truck had a few hiccups but I'm pretty happy
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 05-10-2014, 12:42 AM   #129
SCHRUMGMC
SCHRUMGMC's Avatar
I'll have to dig around for the Wire, it was there. I'm going to buy a Door hinge lower pillar
Got this idea, let me know if its a great one !!!
Spray Rhino Lining on the
bottom of the Cab Steps
Bed Steps
At the back of the the bed fenders
1971 GMC Sierra
1959 GMC 100
Old 05-16-2014, 04:20 PM   #130
SCHRUMGMC
SCHRUMGMC's Avatar
Bought some more parts today
Making some progress on the '59
Costed me $82 sweet lord these parts are pricey
1971 GMC Sierra
1959 GMC 100
Old 05-16-2014, 05:56 PM   #131
Kim57
Kim57's Avatar
They are pricey but it's nice to have new some times.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-16-2014, 06:12 PM   #132
lowrodderchev
just those 2 parts? where'd you go
Old 05-16-2014, 06:24 PM   #133
SCHRUMGMC
SCHRUMGMC's Avatar
To a well known truck place around here, about 40 mins away. I'm going to buy the Door parts next.Next week I am going to hopefully get the truck in my name Officially !!!
I'll get a new Front bed panel as well. Just can't wait to see how all of this looks after all of the welding work
1971 GMC Sierra
1959 GMC 100
Old 05-17-2014, 07:01 AM   #134
coralhead
coralhead's Avatar
With the title in hand it should not be any problem getting it titled "officially" in your name. If you have someone else doing the welding make sure all the old rust is removed and not the new panel layed over the old. I've seen that before.
coralhead is offline   Reply With Quote
Old 05-17-2014, 11:28 AM   #135
_Ogre
_Ogre's Avatar
dome light has an batt hot wire running from the light switch brake light hookup to the dome light
ground wire from the dome light goes back to the light switch white ground for dome light
if you add door switches hook them to the white ground for dome light
there is no fuse in the circuit only the bimetal spring for overload protection that protects the brake and tail lights
if you need to run new wires to the dome light use plastic strapping like what is used to strap packages for a fish tape
run it up the drivers side windshield pillar and pull 2 wires down
shop air compressor timer
Old 05-17-2014, 02:37 PM   #136
OrrieG
OrrieG's Avatar
The orange also has a second wire that is power to the dome, see post 122.
Old 05-17-2014, 04:11 PM   #137
SCHRUMGMC
SCHRUMGMC's Avatar
Here is the set up right now with the Dome light
Fished around for the wiring, only found this one..It was hard to do
1971 GMC Sierra
1959 GMC 100
Old 05-19-2014, 03:30 PM   #138
SCHRUMGMC
SCHRUMGMC's Avatar
Well finally got Pawpaws '59 Gmc in my name !!!
Ahh hopefully I will be able to buy the door bottom this Friday
Can't wait to get the Title here soon
Didn't know there was Two parts to a door bottom
1971 GMC Sierra
1959 GMC 100
Old 05-20-2014, 09:14 PM   #139
SCHRUMGMC
SCHRUMGMC's Avatar
Tailgate Tuesday
1971 GMC Sierra
1959 GMC 100
Old 05-21-2014, 12:49 AM   #140
OrrieG
OrrieG's Avatar
No clue on the dome light, GMC must be different than Chevy. Maybe just on or off with no dimming???
Old 05-21-2014, 08:01 PM   #141
SCHRUMGMC
SCHRUMGMC's Avatar
Put the new Dome lamp in the '59 earlier
Some touch ups here and there
1971 GMC Sierra
1959 GMC 100
Old 05-28-2014, 11:28 AM   #142
SCHRUMGMC
SCHRUMGMC's Avatar
Always have one of these !!!
1971 GMC Sierra
1959 GMC 100
Old 05-31-2014, 04:39 PM   #143
SCHRUMGMC
SCHRUMGMC's Avatar
Enjoying the weather
It got special treatment for once in its Life, its parked in the garage LOL
I need a new Clamp fork thing for the Distributor where can I locate one?, Thanks in advance
Tuesday or so, I will be buying a brand new Gas tank for it
1971 GMC Sierra
1959 GMC 100
Old 05-31-2014, 06:21 PM   #144
Kim57
Kim57's Avatar
Auto Zone carries them.
I would think any good auto parts store would have one.
Kim
http://www.autozone.com/autozone/par...mString=search
My build thread
Old 06-03-2014, 11:33 PM   #145
SCHRUMGMC
SCHRUMGMC's Avatar
Junkyard finds
May look like Junk to y'all !!!
C60 GMC Horn CAP
Two Old Commercial License Plates
Old GM Key to a C60
AshTray for the Nissan
Windshield Wiper Fluid lid
Saw a '59 Chevy Apache Shortbed Fleetside in Shelby !!!
Bought a brand new Tail light housing for the '59
How do I wire it to the brake light switch? it doesn't want to reach?
What exactly does it snap on to?
1971 GMC Sierra
1959 GMC 100
Old 06-04-2014, 09:30 AM   #146
Kim57
Kim57's Avatar
Those are some cool items.
Kim
My build thread
Old 06-04-2014, 12:17 PM   #147
SCHRUMGMC
SCHRUMGMC's Avatar
New Taillight housing
Original Transmission Cover, Thank you DaveCarney2
1971 GMC Sierra
1959 GMC 100
Old 06-10-2014, 03:42 AM   #148
SCHRUMGMC
SCHRUMGMC's Avatar
Just went out to crank the '59 it started up with no hard start, and you could press the gas.. Looks like H-A's and Geralds old truck is on it way.. Trucks about to be in a News article so stay tuned !!!
Pretty excited for all of this to happen
Sent the carb to a Fellow member on 55-59 Chevy trucks, and he rebuilt it and the truck cranked right up. I can't wait to cruise in it tomorrow and see what it does
1971 GMC Sierra
1959 GMC 100
Old 06-14-2014, 03:59 PM   #149
SCHRUMGMC
SCHRUMGMC's Avatar
Bought a new Fuel pump for the truck
The other Fuel pump must of went out or something because its not pumping gas what so ever
1971 GMC Sierra
1959 GMC 100
Old 06-26-2014, 12:22 AM   #150
SCHRUMGMC
SCHRUMGMC's Avatar
Bought another Tail light and just got done installing it
Now they match one another
Bought a front fender patch for the right side
I've dropped already close to $300 in parts in this thing...still have a ways to go
Here soon I'll have to buy a battery tray for the truck, the one that is on it is wrong for the year or something, according to some truck people
Truck still isn't getting gas, Buying another long rubber fuel line to see if it fixes the current problem
The truck has come a long way since buying it back in November 10th, 2013
The truck is also in my name..got the title the other week..
Me and the truck have a unstable relationship at times, but I won't give up on it
1971 GMC Sierra
1959 GMC 100
