Old 12-25-2014, 01:47 AM   #126
skymangs
skymangs's Avatar
Re: Cecil the 1953 5 window / S-10 / 5.7 TPI
Santa brought Cecil a Christmas present today.
skymangs is offline   Reply With Quote
Old 12-25-2014, 06:33 AM   #127
47 Fasttoys
47 Fasttoys's Avatar
Nice choice on the gauges. I'm looking at the same brand for my '47. How are you mounting yours? Did you buy some Basel adapter rings or will you modify your own?
Thanks, Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-25-2014, 10:05 AM   #128
skymangs
skymangs's Avatar
I'm going a different route with this one. It's going to get taken apart and made to look like the original speedo.
Old 12-25-2014, 05:51 PM   #129
bauto52
bauto52's Avatar
Originally Posted by oossuuu754 View Post
The donor S-10 is a drivable 85 that I picked up on CL. Unfortunately this one doesn't have a 700r so I will have to use another CL find. My goal is to drop this vehicle to about an overall stance of 6'4 or so. Chris is going to install drop spindles and lowering blocks in the back. The tire wheel combo is Ridler 695 (18x8 and 20x10) with meaty Kumo Tires (255/55/18 front 275/55/20back) I prefer more sidewall but this may not allow me to get the overall height I want, we will see.
I have started my swap. Can anyone tell me,,,with the S10 sitting on same size tires on concrete if my frame should be an inch lower on the left side at the front s10 cab mount?? sorry to use this thread but havent start my own yet, thanks
1952 Chevy truck
1955 chevy Belair 2 dr Hardtop
1955 Chevy Belair 2 dr post
1962 Red corvette
1962 Red impala 2 dr hardtop
1926 Star by Daurant
bauto52 is offline   Reply With Quote
Old 12-25-2014, 10:08 PM   #130
skymangs
skymangs's Avatar
Nope. I would suspect a collapsed spring. Unless a tire is low or they are mis-matched. Measure from the lower shock mount to the ground on each side. If the measurement is the same, it's your springs. If the measurement is much different then it is your tires.
Old 12-30-2014, 07:33 PM   #131
oossuuu754
oossuuu754's Avatar
Skymangs
finished up the rear suspension
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
Old 12-30-2014, 10:49 PM   #132
oossuuu754
oossuuu754's Avatar
Additional photo of suspension
---Shawn
Old 12-30-2014, 10:52 PM   #133
oossuuu754
oossuuu754's Avatar
SKYMANGS
"This is Cecil's fuel sender. I'll be installing an aftermarket 0-30 ohm sender to br compatable with the stock fuel gauge. The new in tank pump is all set up, tomorrow the sender goes back in, and the bed goes on for the last time."
---Shawn
Old 12-30-2014, 10:56 PM   #134
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Here's the finished fuel sender. I heat shrink and routed the wires through the old evaporation line, then sealed the end with heat shrink.
---Shawn
Old 12-30-2014, 10:58 PM   #135
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Cecil's speedo arrived from speedhut the other day, so of course my first step was to tear it apart. I think it will work out nicely in the stock gauge cluster
---Shawn
Old 12-30-2014, 10:59 PM   #136
99 to Life
99 to Life's Avatar
looks good sarge. here is a write up on the lean issue. not to deter from this thread but my daily s10 leans, this guys old set up prolly does lean, starting fresh should help iron it all out. http://www.s10planet.com/forum/archi...php/t-230.html
the gauge is looking great. Iv been hoping for a cheaper alt like this for years. been meaning to find a gauge to do the proper period looking conversion. this is prolly as close as its gonna get. I planned on making my own inserts, maybe add a bit of a different color to them, but I like how you used the actual insert too.
Are you making a new hole in it for the High beam or just routing a light indicator elsewhere?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-30-2014, 11:00 PM   #137
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Bed was mounted for the final time today.
---Shawn
Old 12-30-2014, 11:12 PM   #138
99 to Life
99 to Life's Avatar
sarge, here is what I worked on a while ago for the new insert. I have the numbers from the stock gauge that I can move around to be spot on with that gauges numbers. You can see here how they line up, the stock AD gauge is close but this gets its spot on. Obviously the final product would look just like the stock insert, just with shifted numbers and the digital trip meter would show through like yours.
Old 12-31-2014, 12:19 AM   #139
skymangs
skymangs's Avatar
Thanks 99. I'm going to let my graphics shop make the decal for me, that way i can keep them in stock. I've given them the new decals, and a template for the marks on the speedhut gauge.
Old 01-02-2015, 11:44 PM   #140
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Drivers floor is all wrapped up. Next will be kick panel, then on to the passenger side.
---Shawn
Old 01-02-2015, 11:49 PM   #141
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Finished drivers floor. Passenger side was a little more rusty than I had originally thought. Once I scraped off all the under-coating, I found a screwed in piece of sheet metal... installed over the pre-existing rust of course. The patch panel is all made and fitted. Tomorrow I'll weld it in.
---Shawn
Old 01-02-2015, 11:55 PM   #142
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Passenger side floor work. I've got the kick panel patch fit, and ready to weld in tonight. I'm expecting to have the cab pulled tomorrow, and start getting the motor ready for initial start up.
---Shawn
Old 01-03-2015, 12:00 AM   #143
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Passenger side finished up. Tomorrow I'll install th he shifter and pull the cab.
---Shawn
Old 01-03-2015, 12:34 AM   #144
Advanced Design
Advanced Design's Avatar
Looking great guys! Sorry to back up a bit...is the brake mechanism from an S10?
Probably answer my own question if I go through the S10 sticky...thanks!
Advanced Design is offline   Reply With Quote
Old 01-03-2015, 12:49 AM   #145
skymangs
skymangs's Avatar
Yes, pedal mechanism is S10 square body.
Old 01-03-2015, 06:54 AM   #146
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Very nice work and helpful information. Thanks for taking the extra time to post this.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 01-03-2015, 12:29 PM   #147
918733
Have you showed how you modify the rear shock mount plate to re-located the rear end forward
918733 is offline   Reply With Quote
Old 01-03-2015, 05:09 PM   #148
skymangs
skymangs's Avatar
I don't think I have. I use 2.5" 1/4 wall square tube for blocks, then offset drill the hole for the centering pin by 1". Pretty simple.
Old 01-03-2015, 08:17 PM   #149
oossuuu754
oossuuu754's Avatar
SKYMANGS:
PIC 1 Shifter was installed to check clearances and shift rod geometry, then removed until the cab goes on for the final time. PIC 2 & 3 New kick panels all trimmed up and fit
---Shawn
Old 01-03-2015, 08:21 PM   #150
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Center panel made and welded in
---Shawn
5 window, 5.7 tpi, chevy truck, rusto mod, s-10 chassis swap
