Old 12-17-2015, 08:35 AM   #1501
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by Billhilly View Post
Looking sharp! Build quality on this whole rig is !!
Thanks! i have a ways to go before it looks as good as yours!
Originally Posted by 1985-GMC View Post
Like brand new, nice! How hard was the NV4500? Had you done one before?
I had never rebuilt a nv4500. ive done a handfull of other manuals, all older 4 speeds though. it was pretty easy. there are no clearances to set other than end play. for the most part its disassemble and re-assemble. there are a few bearings that require creativity or the correct tools to remove, but i did OK without
Originally Posted by Dieselwrencher View Post
The transfer case looks great Ryan. I really like the pto cover! Great work.
Thanks Mister!
Originally Posted by jbclassix View Post
Ryan, there are at least 2 different shift "combs" that chevy used for the 241C, there's a break in years, I think it's 93, or something like that. Check to make sure the 4wd indicator switch is the same against the Dodge suck switch. there is a visible difference in thread-to-ball length in the GM variations. you should be able to tell if it will work in the DHD just by looking at it
Good to know. they had to order the one i have from east jesus nowhere. the photo it looked OK, but ill see when Oriellys calls i guess. the one i ordered is for an 89.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-18-2015, 10:35 AM   #1502
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Cool deal, I'm gonna have to rebuild one pretty soon.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-22-2015, 01:55 AM   #1503
rgreathouse
Re: 72 k20 project
Looking great! What clutch did you go with?
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 01-17-2016, 07:06 PM   #1504
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Sorry, I thought I had responded, guess not...
It is a valair dual disc organic.
72 K20 12v build
Old 01-17-2016, 07:09 PM   #1505
ryanroo
ryanroo's Avatar
Re: 72 k20 project
It'll be a cakewalk I'm sure. Doing upgrades while in there?
72 K20 12v build
Old 01-18-2016, 12:58 AM   #1506
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Other than the usual stuff, locking 5th gear nut or collar, replacing the coutershaft and swapping out the input for the Cummins version I wasn't really planning on it. But really there's no telling once I get in there and start ordering parts. Any suggestions?
Tony
Old 01-24-2016, 05:39 PM   #1507
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i'm guessing you are starting with a gm 4500? i would go ahead and upgrade the input unless you are staying strictly stock power levels. you will be needing a clutch anyhow so you can get whatever you need with a big input hub. is the counter gear bad?
72 K20 12v build
Old 01-24-2016, 08:48 PM   #1508
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
I'll send you a pm. I don't want to fill up your whole thread with my stuff.
Tony
Old 03-15-2016, 08:46 PM   #1509
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Dang. i had to go back to the second page of sub'd threads to find this. haha
i had a mild catastrophe with my phone and left my camera when i was visiting Lauren at christmas. so, the pics i did have are gonzo. but, i also wasnt really very productive, so not much has changed.
i did get this handy tig welder as a gift from my wife lady. the cooler was on global backorder for a few weeks but i got it outfitted and built a quicky cart.
i fiddled around for a few days making welds and getting adjusted to the machine. i had a bazzilion weld coupon pics and all of the titanium welds i have done(very few, but they look cool) they all died on my phone...
i installed the 241dhd but haven't taken new pics of it installed. got some work done on the shifters. no pics of that yet either.
but, i did document some recent progress!
this is a condenser, power steering cooler and power steering filter set up.
i knew where i wanted it to be, but if it would fit... turns out it just does. the inner fender still clears, you can remove the filter, might even be able to get to it when the truck is assembled completely. maybe.
put the new welder to work.
i also built this framework to hang the condenser and cooler off of. it is a tight fit, but with just enough of the latch mechanism ground off, it fits.
next is the cooler. and the other billion little things.
72 K20 12v build
Old 03-15-2016, 09:05 PM   #1510
COS399
COS399's Avatar
Re: 72 k20 project
Okay Ryan, the million dollar question is what happened to allow you to get that new toy? I want a TIG machine so I need to know. Nice progress.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-16-2016, 08:05 AM   #1511
coggonobrien
Re: 72 k20 project
why filter the power steering?
coggonobrien is offline   Reply With Quote
Old 03-16-2016, 12:26 PM   #1512
burnitg
Re: 72 k20 project
Gorgeous welds! That new machine must be sweet.
Burnett
burnitg is offline   Reply With Quote
Old 03-16-2016, 12:53 PM   #1513
6BT 56
6BT 56's Avatar
Re: 72 k20 project
For the same reason all the stuff is bad ass and lots of over kill.
Becouse he can ......
Looken good . Can't wate to see this thing moven under its own power .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-17-2016, 07:24 PM   #1514
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Loving the welds and fab work Ryan!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-17-2016, 09:46 PM   #1515
Chevy_mud_truck
Chevy_mud_truck's Avatar
Re: 72 k20 project
If that the 250ex I have the same one
Chevy_mud_truck is offline   Reply With Quote
Old 03-17-2016, 10:17 PM   #1516
msgross
msgross's Avatar
Re: 72 k20 project
nice work
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-20-2016, 04:55 PM   #1517
mx289
mx289's Avatar
Re: 72 k20 project
Looking good kind sir.
Bad air..soon..!
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 03-21-2016, 02:25 AM   #1518
swamp rat
swamp rat's Avatar
Re: 72 k20 project
All this time i thought Everlast was a band, come to find out Everlast makes you a great Tig welder!
All kidding aside, nice welds! Good to see your making progress again too!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-09-2016, 10:38 AM   #1519
ryanroo
ryanroo's Avatar
Re: 72 k20 project
I took her to Belize for her 30th last year. thats what she said anyhow. haha
Basically. it may be overkill, but the 60$ or whatever it was i spent on the filter and head, plus the additional fittings ill need are a one time expense. filtering the fluid before it goes into the pump is a good thing. keeps the pump happy for a long time. keeps trash out of the box, the hydroboost and the assist ram, so hopefully it just increases longevity across the whole system. kept cool and filtered the fluid should also last longer.
Burnett
Thanks! im still learning the tricks of it for sure. i have never had an inverter with this much pulse tunability. its a little bit of a learning curve so it is fun dinking with it. still haven't gotten the aluminum fully tuned yet. i also may try to play with some gas mixtures with that for the heck of it too.
Thanks! i want to see it move too. every day
thanks!
its a 256 multi process. its a plasma as well, but i havent set that up. basically the same machine though.
Originally Posted by msgross View Post
nice work
Bad air..soon..!
Thanks fellas, i keep dreaming about the dual side pipe spitting smoke. its almost arrogant bike riders season...
"father of mine, tell me where have you been?"
Thanks! goes in spurts it seems
72 K20 12v build
Old 04-09-2016, 11:03 AM   #1520
ryanroo
ryanroo's Avatar
Re: 72 k20 project
here are a few more updates.
worked on the cooler mount for the steering fluid
it is 14ga with dimples for posterity
some additional love needed to be made with the release lever on the latch, but for the most part it all fits. just barely. the grille insert may need a touch of material sanded off in one spot also.
here are a couple of the t-case in the frame. hard to get a decent shot from the floor.
i also have this stuff i ordered a while back
and made this
from these things. a flaming river ujoint 3/4"-30x1"DD and a sweet mfg. 3/4"x36x3/4"DD, and a borgeson collapsible shaft, cut to fit.
72 K20 12v build
Old 04-09-2016, 11:08 AM   #1521
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i need an assist ram mount too. i planned on making a ring for the diff cover like i did with the set up on my M715. then a couple so called friends made a suggestion and another week of after work nights went to crap...
i am waiting on a part to get made in the CNC to finish up the ram mount, so the reason for this thing isnt even pictured, yet.
I re mounted these with accomodations for the wood floor bed and also to remove the welded on mounting tabs.
sorry for the IG pic, it was the only place i had it posted that didnt die.
i cut these spacers for the front bags for that extra inch to clear the 35s.
i also have a start on the t-case shift. the bracket needs to be finished and welded. the lever has no handle or knob so i am not done yet by far.
thats all i have pics of so far!
72 K20 12v build
Old 04-09-2016, 03:04 PM   #1522
6BT 56
6BT 56's Avatar
Re: 72 k20 project
Very nice . Going to be ashame to get it dirty . But I guess if was meant to be a show truck then all the cool hd over kill would be for not . Keep up the great work . I was long overdue for some pics . Thanks for getting me my fix .
Old 04-10-2016, 01:53 AM   #1523
Chevy_mud_truck
Re: 72 k20 project
I don't remember that one being able when a pick my 250ex up or id probably got that one man you're fab work is outstanding I hope mine turns out half as nice and well built when I'm done I've got the sheet metal and steal down pretty good but man aluminum is kicking my butt
Old 04-10-2016, 07:04 PM   #1524
COS399
COS399's Avatar
Re: 72 k20 project
Excellent work as usual.
When should I drop off my International?
Old 04-11-2016, 08:51 PM   #1525
Dieselwrencher
Re: 72 k20 project
So called friends have some great ideas I'd say. It looks great. I didn't realize you had to raise the bag for the 35's. That is a nice spacer for sure.
Ryan
