03-28-2011, 09:27 PM | #1601 |
Re: PO has me PO'd
Carlisle will be coming up... I'm right off the turnpike and on the way for you...
I'll also be out at Ft. Dix at the end of May.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-29-2011, 12:03 AM | #1602 | |
Re: PO has me PO'd
Posted via Mobile Device |
03-29-2011, 08:56 AM | #1603 | |
Still plays with trucks
Re: PO has me PO'd
It is possible to give it some texture similar to the sand casting too but that takes a bunch of time.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
03-29-2011, 08:56 PM | #1604 | ||
Re: PO has me PO'd
Thanks for the idea, are you talking about the member sourkraut? I wanted to talk to him about powdercoating something anyway??
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
03-29-2011, 09:22 PM | #1605 | |
Re: PO has me PO'd
03-29-2011, 10:53 PM | #1606 | |
Re: PO has me PO'd
You've got a great build goin', keep it up AJ
03-30-2011, 07:47 AM | #1607 |
Re: PO has me PO'd
My kids (and wife) are the same way.... I would be opening a box and they were all excited, now they ask "what's in the box" and I reply with "truck parts".... "IT'S ALWAYS TRUCK PARTS FOR DADDY!" is the average response...
03-30-2011, 08:26 AM | #1608 | |
Re: PO has me PO'd
It will look good when done just not like it was unrepaired. The repaired area will be smooth and not sand cast finish. You can rough it up a bit but I haven't been able to make it look exactly like the sand cast finish.
03-30-2011, 08:48 AM | #1609 | |
Re: PO has me PO'd
2001 silverado stolen by family 1983 short n wide custom deluxe SOLD 1985 silverado longbed 305 engine 700r4 OH NO! NOT ANOTHER LEARNING EXPERIENCE!!! "Just because you can do it, doesn't mean that you should" |
03-30-2011, 10:19 AM | #1610 | ||
The Few, The Proud
Re: PO has me PO'd
My wife doesn't even bother bringing in the boxes anymore. Wherever Fed-Ex/UPS leaves them is where I find them when I get home in the evenings. Quote:
My 4 year old will ask everytime now before I open a box if it's truck parts for my truck. Pretty sad huh?
Shannon Last edited by sdailey; 03-30-2011 at 10:20 AM. |
03-30-2011, 05:55 PM | #1611 |
Re: PO has me PO'd
Looks like I should send a small present to your children Shannon and Mike...PM me yourhome addys
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-30-2011 at 06:03 PM. |
03-30-2011, 06:15 PM | #1612 |
Re: PO has me PO'd
[QUOTE=sdailey;4588338]My wife doesn't even bother bringing in the boxes anymore. Wherever Fed-Ex/UPS leaves them is where I find them when I get home in the evenings.
My wife used to pull that, until I told her the price of some of these parts
03-30-2011, 06:17 PM | #1613 | |
Re: PO has me PO'd
03-30-2011, 09:03 PM | #1614 |
Re: PO has me PO'd
thanks for the offer...
03-30-2011, 10:50 PM | #1615 |
Re: PO has me PO'd
is he into legos, just bought some for my grandson and he is 4yrs. old
03-31-2011, 12:17 AM | #1616 |
60-66 Nut
Re: PO has me PO'd
I just thought about checking in to see how that EFI fuel filter worked out, but I see you've had other issues. Too bad about that intake. I agree with 68 TT on fixing that....that's an easy fix. It seems odd to me that you couldn't find anyone in your area to fix that for you. There are lots of fab/weld shops around here, of course not all of them know how to weld aluminum.
I hope your luck gets better.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-31-2011 at 12:17 AM. |
03-31-2011, 08:48 PM | #1617 | |
Re: PO has me PO'd
The intake didn't take long to get rid of, so I don't have to find a fab shop... I'm looking at the GMPP intake 12496822 w/ an adapter plate to get it from a square bore to a spread bore I think I understand what happened with the galling, seems that the tolerances were wrong on the thread pitch of the fittings. I'll check out Aeroquip this time
04-01-2011, 11:33 AM | #1618 | |
Re: PO has me PO'd
I have had a few new intakes not tapped deep enough for the fittings to engage enough threads. I typically run a tap into the pipe fitting holes until the fitting gets as many threads into the intake as possible before it bottoms out just to give the intake more structural integrity. That may have been part of your problem. Too little engagement area at the boss so it put too much force into too small of an area on the intake. If the hole wasn't tapped all the way through you could have bottomed out the plug and caused the damage that way too.
04-01-2011, 02:29 PM | #1619 | |
Re: PO has me PO'd
yeah, I'm thinkin' this quadrajet (500-600cfm) won't make muster down the road. Now that the top end is about done, I want to build a 400 cu. in. stroker good points, and info., and what you say makes sense. Great job keeping me informed, good thing about this board
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-01-2011 at 02:30 PM. |
04-01-2011, 03:27 PM | #1620 | |
Re: PO has me PO'd
04-01-2011, 06:21 PM | #1621 |
Re: PO has me PO'd
yeah, you're right, forgot about them...I'll start looking now, orrrrrr 2 quadrajets, that might be cool
04-02-2011, 06:15 AM | #1622 |
Re: PO has me PO'd
oh my,,, an OctaJet
04-02-2011, 08:05 AM | #1623 |
Re: PO has me PO'd
Could not tell 100% but is that a water port? If interested I could weld it up for you. Is the easy out still in there? We can get that out and fixed up to. Will pm you.
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
04-04-2011, 12:20 PM | #1624 |
Re: PO has me PO'd
sorry guys, had the flu for a couple. didn't feel like doing anything
04-21-2011, 11:07 PM | #1625 | ||
Re: PO has me PO'd
Ya know, I don't think this engine will ever need 850 cfm, but ya never know if I get around to building a 400 stroker... Maybe this weekend I can post up some pics of the new intake manifold from GM, still have to chase the threads to make sure it doesn't happen again
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-21-2011 at 11:09 PM. |
