Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-06-2015, 10:42 AM   #151
cru_zn_29
cru_zn_29's Avatar
Re: Hydroboost Mounting Plates
I see what you are saying now that i have removed the old booster.So i will not need your hydroboost plate.
Thanks Kenny
cru_zn_29 is offline   Reply With Quote
Old 09-06-2015, 11:08 PM   #152
Captainfab
60-66 Nut
You could always convert to hydroboost using the correct booster bracket and this hydroboost mounting plate.
Thanks Kenny
Old 09-10-2015, 11:20 PM   #153
Captainfab
60-66 Nut
I have the hydroboost nut sockets back in stock.
Old 09-11-2015, 10:26 AM   #154
rustyrexiusrodz
I would like to order a bracket for a 1962 truck thanks
olyhotrodz
rustyrexiusrodz is offline   Reply With Quote
Old 09-11-2015, 11:37 PM   #155
Captainfab
60-66 Nut
I'll sent you a PM with ordering info.
Old 09-23-2015, 09:35 PM   #156
62LS1
62LS1's Avatar
I need the information on ordering the 67-72 bracket (powdercoated) and the hydroboost bracket. Send the info to vratman@sbcglobal.net
Too many dreams, too little money.
62LS1 is offline   Reply With Quote
Old 09-23-2015, 10:52 PM   #157
Captainfab
60-66 Nut
Email sent.
Old 09-24-2015, 01:19 AM   #158
2tontruck
I will need the bracket and plate as well for my 72 Suburban. Please message me and let me know if you have this in stock. I will paint it. Thanks Scott
2tontruck is offline   Reply With Quote
Old 09-24-2015, 11:18 PM   #159
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Old 11-16-2015, 04:02 PM   #160
The Rocknrod
Moderator
The Rocknrod's Avatar
Would a 94 Chevrolet K3500 Diesel Hydroboost work with your mounting plate?: http://www.cardone.com/Products/Prod...=527334&p=rock
and
http://www.rockauto.com/dbphp/x,carc...e_Booster.html
Old 11-17-2015, 12:03 AM   #161
Captainfab
60-66 Nut
Yes it will work.
Once you remove the factory mounting bracket all GM hydroboosts are interchangeable.
and
Old 12-28-2015, 09:32 PM   #162
Theboatandcarman
Lightbulb Re: Hydroboost Mounting Plates
i want a hydroboost bracket and i guess a power brake bracket for my 72 cab! black powdercoating if available please. doing a complete setup from a chevy 2500HD (hydroboost and master cylinder)
Theboatandcarman is offline   Reply With Quote
Old 12-29-2015, 12:29 AM   #163
Captainfab
60-66 Nut
Old 12-30-2015, 05:57 PM   #164
DaddyOh
DaddyOh's Avatar
Need Paypal info for a hydroboost mounting plate...
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356
DaddyOh is offline   Reply With Quote
Old 12-31-2015, 02:03 AM   #165
Captainfab
60-66 Nut
PM sent
Old 01-11-2016, 02:01 PM   #166
solidaxel
solidaxel's Avatar
I will be converting my 62 Corvette to Hydroboost so will your bracket fit the firewall mounting bolts where the stock M/C is located?
Here is the HB unit I am using, it came from a 2000 ford GT so I guess I will need the Nut removal tool also, what else will I need?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-12-2016, 12:38 AM   #167
Captainfab
60-66 Nut
Sorry but I have no idea what the firewall hole pattern is for the master cylinder on a '62 Vette. If by chance it was the same as these hydroboost mounting plates, you would still have to enlarge the center hole a bit. These plates are intended to be used with my booster brackets so that no modification to the firewall is necessary. that also maintains a good solid connection between the booster/master and the pedal bracket as GM designed it to be.
Old 01-12-2016, 09:49 AM   #168
solidaxel
solidaxel's Avatar
Thanks,
I will wait until I get the car back and take some measurements and pics.
LS 3 4L70E
Old 01-20-2016, 12:01 AM   #169
Ctinman
I would like info on your booster bracket and hydroboost mounting plate. Please PM me the info. Thanks
Ctinman is offline   Reply With Quote
Old 01-20-2016, 12:30 AM   #170
Captainfab
60-66 Nut
Old 01-20-2016, 12:56 AM   #171
Curtb1971
Curtb1971's Avatar
Thanks Captianfab! Finally got the my hydro boost mounted tonight.
Curtb1971 is offline   Reply With Quote
Old 01-20-2016, 08:51 PM   #172
pullit
Looks Great! I like the look of the flat plate directly on the firewall instead of the use of the adaptor bracket. Any more pictures? What did you do to the pedal and linkage to make the connection?
pullit is offline   Reply With Quote
Old 01-21-2016, 12:45 PM   #173
Greywolf200
That looks much better than the old booster and bracket sticking out into the engine bay.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 03-18-2016, 12:52 PM   #174
Will206
I have an 89 Suburban V1500 I am doing hydroboost on, so I am in the market for a bracket/plate assembly.
I have a hydroboost from a 99 silverado I plan on using but the mounting between the two is fairly different.
Heres the hydroboost I have:
http://i.imgur.com/B9vdQZK.jpg
The issue I have is that two of the holes on the firewall (and on the pedal assembly) are to the sides of the larger push rod hole and not above it. Also, there are 6 bolts on the booster, two up at the very top, that I assume I just wouldn't need anymore.
Here is a picture of my firewall to get a better idea:
http://i.imgur.com/Gvulyo6.jpg
Is this a part you make or can make?
Will206 is offline   Reply With Quote
Old 03-19-2016, 12:01 AM   #175
Captainfab
60-66 Nut
All you need is a factory hydroboost mounting plate for a '73-'86 C/K or a '87-'91 R/V truck, Suburban or Blazer. Then just remove the factory '99 mounting bracket and install the earlier one. As for connecting to the pedal, some fabrication may be needed. I'm not sure as I have not done anything like this. It would likely be a whole lot easier to just get a '73-'86 C/K or '87-'92 R/V hydroboost and bolt it up.
