Old 11-27-2009, 08:51 PM   #151
ghettoluxury
ghettoluxury's Avatar
Re: 73-87 4x4s
Originally Posted by Rollinsqrbdy View Post
Ya I like em all except to totally tricked out show truck. what a waste.
Ya that 10 bolt would be junk in a matter of hours with me behind the wheel
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-28-2009, 09:53 PM   #152
ghettoluxury
Re: 73-87 4x4s
Old 11-29-2009, 12:02 AM   #153
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: 73-87 4x4s
Hey where can i find some of them white wheels? I'm really starting to like em. Im also bettn that their cheap
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 11-29-2009, 12:09 PM   #154
ghettoluxury
Re: 73-87 4x4s
Your local tire store can order them My chrome ones ran me $56 each and I think the white or black ones are about $40 each.
Old 11-29-2009, 08:38 PM   #155
ghettoluxury
Re: 73-87 4x4s
Old 11-30-2009, 03:07 PM   #156
Rollinsqrbdy
Re: 73-87 4x4s
The red one is so sweet. What is that bout a 6'' lift on 35's?
New Mexico Member
Old 11-30-2009, 03:10 PM   #157
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 73-87 4x4s
Who, that last one....18" lift and 52's? 48's?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-30-2009, 07:21 PM   #158
onlyifihadachevy
Re: 73-87 4x4s
Those are the 54" boggers can tell by the cuts. Should have gone with a wider wheels, they look like balloons.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 11-30-2009, 09:23 PM   #159
ghettoluxury
Re: 73-87 4x4s
Old 11-30-2009, 11:47 PM   #160
70 beast
Certified Hobbiest
70 beast's Avatar
Re: 73-87 4x4s
Originally Posted by onlyifihadachevy View Post
... Should have gone with a wider wheels, they look like balloons.
and maybe some stronger axles
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 12-01-2009, 09:23 AM   #161
thirdstreettito
Resident of Here
Re: 73-87 4x4s
I "think" the front is a D60, but the tires make it look small. I hope its a D60 anyway...
~Bradley~
Miss having a truck
Old 12-03-2009, 12:21 AM   #162
Rollinsqrbdy
Re: 73-87 4x4s
Somebody say more?
New Mexico Member
Old 12-03-2009, 12:42 AM   #163
Rollinsqrbdy
Re: 73-87 4x4s
couple more..
New Mexico Member
Old 12-03-2009, 12:46 AM   #164
thirdstreettito
Resident of Here
Re: 73-87 4x4s
1990 Chevrolet Suburban 46" Claws with only 8" of lift
Dyna-Trac Dana 60 rear w/Detroit. Teraflex high pinion CRD design Dana 60 front w/ARB and Longfield CV style 300M "Super Axles" with 4:88 gears. Both axles are custom 6 lug built specifically for this truck. Cross over steering with AGR hydraulic ram and Howe pump w/remote reservoir. TBI 454 c.i. w/ceramic coated Thorely headers, electric fans, dual Yellow Top Optimas, Painless wiring w/relays. Custom 700R4 w/stock NP241 transfer case. Front Warn 15000 winch and rear Warn 9500, both cab operated (if needed). Viar compressor with remote tank. Wilwood 6 piston 14" disc brakes on all corners. 46" Mickey Thompson Baja Claws on Stazworks 20x16 (16 being the width) double beadlock wheels. Sway-A-Way Race Runner reservoir shocks and hydraulic bump stops. 45 gallon fuel tank. Line-X on entire inside of truck as well as lower sections of body. Lower exo-skeleton front to rear provides strength as well as forms flares needed to cover tires. Skid plates, additional cross members and custom traction bar with driveline hoops. Powder coated Conferr roof rack with rear and side facing lights. Off road lights as well as LED rock lights underneath. Lowrance Globalmap 540C Baja GPS, 40 channel CB w/250 watt booster etc.
Most of my trips are in the Cascade mountain range in southern Washington State. I do almost all of my wheeling trips in the winter so snow is all this truck really sees. In fact it has developed over the years into quite a capable mountain rig. The snow here in the Cascades has a tendency to get very deep as the season progresses. It is not unusual to "float" on top of 5 to 6 feet of snow on forest roads at or above 4000 feet. The roads tend to be wide and are bordered by 100 foot tall fir trees. On a clear day from the top of the mountains you can see for miles, viewing other distant peaks as you plan ahead for next weeks outing into the unknown. However, those are definitely not my favorite days; I love a good old fashion blizzard. Wind howling down the peaks with impressive force and then gusting even stronger. Snow falling at a rate of 6" an hour that covers your tracks so fast that the rigs behind me have to ca ll up on the CB to see which way I went at the crossroads because my tracks have already filled with new snow. It's really the challenge that drives me; not knowing if I'll be sleeping in my soft bed at home or in the not so soft sleeping bag in the back of the Suburban. This rig is equipped to handle the roughest terrain the Cascades can dish out, and gets used hard each snow season.
~Bradley~
Miss having a truck
Old 12-03-2009, 08:41 AM   #165
71GMCNC
Re: 73-87 4x4s
Here is my new baby. 6" Skyjacker Suspension and 35's.
'98 Chevy K1500 ext Cab Z71 4x4
196k miles and still going!
83' Chevy K10 Longbed 4x4. Dana 44 front and rear axles. Lift with 35's. Hopped up 350 V8, 4 speed manual w/granny. NP208 Transfer case SOLD!!!!
'71 GMC Shortbed 350 V8/Edelbrock performer intake and carb/Custom Dual Flowmaster 40 Exhaust
Currently in progress eventually 383 Stroker! SOLD!!!!
'67 Chevy C20 londbed Original 327 V8/4 Speed Custom Cherry bomb Exhaust
Inline to be next project sporitng primer grey SOLD!!!!!
71GMCNC is offline   Reply With Quote
Old 12-03-2009, 04:41 PM   #166
RednecK30
RednecK30's Avatar
Re: 73-87 4x4s
this is my 87 1 ton
shotgun, rifle, and a 4 wheel drive. And a country boy can survive!
RednecK30 is offline   Reply With Quote
Old 12-06-2009, 05:51 PM   #167
Benelli
Watchin the rust grow
Benelli's Avatar
Re: 73-87 4x4s
What tires are those?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 12-06-2009, 07:51 PM   #168
Rollinsqrbdy
Re: 73-87 4x4s
They look like goodyear wranglers
New Mexico Member
Old 12-06-2009, 08:22 PM   #169
RednecK30
RednecK30's Avatar
Re: 73-87 4x4s
they are the 36" military OZ wranglers (found on hummers, and the chevy 1 ton cucv's)...
Old 12-06-2009, 08:43 PM   #170
thirdstreettito
Resident of Here
Re: 73-87 4x4s
37" Found on Hummvees only. Not on the CUCV's. Sorry.
~Bradley~
Miss having a truck
Old 12-06-2009, 09:34 PM   #171
RednecK30
RednecK30's Avatar
Re: 73-87 4x4s
This is a military hummer. I know what you are saying you can also get a 37" hummer tire
36" (what I have on my truck)
these are the 37's you are speaking of. A little less agressive, but a bigger tire.
I happened to be in the military, and rode in hummers with both different sets of tires. Maybe next time I am on base I will stop and take pictures of dozens of them with both different applications on them.
HOWEVER, you may be right about the CUCV's. they may have just been put on in different units (may not have came with them).
Old 12-07-2009, 10:39 PM   #172
SMiller
Re: 73-87 4x4s
Lots of units have swapped the hummer tires onto CUCV's. One good way to get around the 4.56 gears.
SMiller is offline   Reply With Quote
Old 12-09-2009, 11:21 PM   #173
blownz
Active Member
Re: 73-87 4x4s
Here is my 84 SB
Wayne
blownz is offline   Reply With Quote
Old 12-10-2009, 03:25 AM   #174
409sbc pwr
409sbc pwr's Avatar
Re: 73-87 4x4s
SICK BURB!!!! love it!!!
84 3/4ton swap 4x4, 409sbc 37x13.50 toyos 8 inch superlift
2007 2500 HD, 10-12 cognito lift, 38x13.50 toyos soon to be boosted via rearmount system
409sbc pwr is offline   Reply With Quote
Old 12-11-2009, 12:11 AM   #175
Rollinsqrbdy
Re: 73-87 4x4s
Originally Posted by blownz View Post
Here is my 84 SB
Wayne
sweeeeet truck. Whats the specs on it?
New Mexico Member
