Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-30-2012, 08:56 PM   #151
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Originally Posted by BACKYARD88 View Post
I saw you posting on HTR the other day and was wondering if it was the same hotrod80. Cool truck you have, and as close as youre running with Billy it must be fast! I've been considering stepping out of the lowriders and in to racing as a hobby.
Yeah , thats me . Billy is a good guy . I like racing with the "conroe bunch". Im kinda the outsider . Come on out and do some racing , its alot of fun .
Got all the parts and the truck to the shop and looked it over today . Should be ready friday and we moved the shocks so i can upgrade from the Rancos later if needed .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-31-2012, 02:44 PM   #152
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: New project
I've known Billy since I was 16 and he's always been a pretty cool kat. I go out to HMP on Friday nights and watch a lot, I guess I need to throw a motor in something and come play
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-01-2012, 02:19 AM   #153
Rannos
Rannos's Avatar
Re: New project
Billy is good as gold man. I have known him for almost 20 years. Has always had some nice cars and he does awesome work.
Should have my new motor in my truck soon Hotrod... Hopefully in a month or so I can come out to HMP and play some as well. Working a deal right now to get a lil cage done. Dont want to cut the firewall or back of the cab tho. Not sure I would need it for my lil' motor anyway. Hope your suspension changes work out for ya.
Jay
Rannos is offline   Reply With Quote
Old 06-01-2012, 07:12 PM   #154
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Yeah , me and Billy seem to end up as rivals . Good people .
Well , truck is in the chassis shop and rear frame is stripped down to the rails . New front mounts are tacked in and the will be ready for me to inspect in the morning before final welding . Same guy that did my 12 point cage is doing this work . Mclwayne's racecars in Baytown . I have been very happy with the work , price and time frame . Hoping to get it back monday or so . i'll get a picture up soon , as i think ive been almost a page with no new pics .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-03-2012, 10:47 PM   #155
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Update :
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-04-2012, 11:58 PM   #156
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Went by today and they had it finished up . I put about 200#'s in the drives seat , gapped the bars and tightend everything up . I fired it up and let it warm while checking tire pressures in the drag radials . They were asking me what i was doing . I told them "testing your work " and jumped in for a ride . Guessing these guys dont get to see what they do on the street very much . Truck "works" alot better so far . We will see friday night if i can get it to behave . Saturday and sunday are a 2 day event . I will be double checking everything and changing the oil .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-05-2012, 02:58 PM   #157
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Back from Mclwayne's racecars in Baytown . hoping it is still consistant .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-11-2012, 09:06 PM   #158
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got it home and did some adjustments to the bars Checked everything out to make sure it was ready to go and headed for the track friday night . Truck did pretty well ,, but had some space in the front spring eye mount inside the Caltracs and outside the eye . Seemed to be rocking on the sidewalls all the way down . Added some tire pressure as a temp fix . ended up 4 clicks from firm on the Ranchos and 1 turn of preload in the bars . Truck was working but i ended up going red bad almost every pass .
Got it home and saturday morning dropped the front of the springs and shimmed the space with washers for tractor supply . Greased everthing and set tire pressure at 17 . Won the first round and broke out second round with a 11.25 on a 11.30 . I even had the time to dump with my reaction ,, which still wasn't on .
Sunday morning worked on it again . Pulled the spacer plates between intake and nitrous plat and plate and carb as it seemed to want to stumble unless it was at the perfect temp. Took 1/2 turn of preload out of the bars . Dropped 1 # or pressure out of the slicks so they could wad up and put my 26 " M/T sportsmans on the front . It went .006 right off the trailer . Worst light was a .051 . Got down to 9 cars and went red .093 . Truck seems to leave great if i load the converter and suspension . If i get a head start on the converter from idle it pulls the front tires straight out of the beams . Still working to get a handle on it . Points should come out in a couple of days . thinking sunday put me in the #2 spot .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-13-2012, 01:37 AM   #159
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-13-2012, 02:03 AM   #160
djracer
djracer's Avatar
Re: New project
Love the Luv!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-25-2012, 06:54 PM   #161
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got a call early saturday for a buddy , " Where you at ? " They were at a 2 day race in Sealy Texas at Lonestar motorsport park . This is an hour and a half away . Mind you i just got chewed on the night before about racing and money and vacation blah blah blah . Im on the back porch and she says "who's that" im like "Rodger". wife " whats he want ? " , me " they are racing in Sealy and he was checking to see why i wasnt there " . wife " better get loaded up and on the road " . Go figure .
I load up quick and get on the road . Get there just in time to get 1 time trial in and pull back around to hot lap and the lanes are closed . They let me in for one more . Red on both time trials . Out first round on both tech cards with reds . Rodger buys me back in after we argue ( i usually dont buy back ) . 2 more reds . I walk up there and look thinks over and there aint much roll out at this track Lights are low and together . I pay Rodger back and head home . Swap tires and change the truck up to tone down the wheelies and soften the hit to the tires Get up and load the golf cart and go to head out sunday and the wife says we gonna get um today and loads up with me . Got the lights figured out and ended up going to the 8's and drew a bike . covered him and didnt chop enough out and went .04 breakout . Had fun though wife was fired up about all the rounds and a small payout dispite the 100 degree weather .
Thomas' daughter Brittany out of out camp ended up going all the way and winning the Ironman . This is her last year in the Jr. She will be in footbrake with us next year
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-08-2012, 06:46 PM   #162
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Big 2 day event this weekend . Swapping to a 24" front tire to test friday night and gonna make a couple of passes on a new set of 26 x 8.5's i have in the garage just to see what happens . Probably be back on 28 trues for sat & sunday . Looks like im gonna end up with a orange 75' Luv also . I have all the parts to make this work so i will be working on that this winter .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-09-2012, 11:31 PM   #163
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Found part of my reaction time problem .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-10-2012, 08:04 AM   #164
djracer
djracer's Avatar
Re: New project
? what is that?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-10-2012, 10:28 AM   #165
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: New project
whats left of a engine mount
GMR-PERFORMANCE is offline   Reply With Quote
Old 08-13-2012, 07:00 AM   #166
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
My truck takes first gen Camaro motor mounts . That is the motor mount from the driverside .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-04-2012, 11:52 PM   #167
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got the motor mounts finished . Bought a set of solids , but put captured poly urethane in for now to try them . SOlids are in the trailer . Fixed the master switch so it works correctly , cleaned up the neutral safety switch wiring . Needed to get these fixed in case i go to a track with by the book tech . Pulled the passenger seat out as it will run 7.0 with that little bit of weight reduction .
Last race of the local NHRA season tis this weekend then reagonals in Dallas 22nd & 23 rd . Currently 3rd in points need a win to be track champion , but only 18 out of second .
Worst yet . I have most of the parts to put another Luv together and im heading to Huntsville to look at on in the coming weeks . It is an Orange 75'
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-06-2012, 06:27 PM   #168
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Turns out both saturday and sunday are for Wally's . Saturday is National dragster challenge and Sunday is Summit king of the track .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-06-2012, 06:56 PM   #169
djracer
djracer's Avatar
Re: New project
Sweet I would love to have one of those.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-11-2012, 10:28 PM   #170
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well a Wally wasnt in the cards guys . I tested friday and pushed the extension housing bushing into the trans and got to see both walls . Saved it though . Worked til late into the night and got it back together early in the morning . Got spooked of the little 23 inch fronts and went back to 25's as they drive so much better . Ended up 6th in points for my rookie year .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-11-2012, 11:21 PM   #171
Captainfab
60-66 Nut
Re: New project
It's not quite a Wally, but I'd say that's a pic worth framing.
Old 09-16-2012, 08:43 AM   #172
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Thanks i believe i'll do that . Looks like im going to DIV 4 bracket finals at Texas motorplex in Ennis , Texas Oct. 4-8th Going to run no E street class. Also have Super Chevy the 29th and 30th of Oct .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-27-2012, 09:47 PM   #173
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
2 day this weekend at super chevy .DOT and footbrake saturday on a drag radial and foot brake on a slick sunday . Div 4 et bracket finels oct 4,5,6& 7
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-29-2012, 11:56 AM   #174
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Rain out for saturday from a tropical storm . They are scheduled to run all three classes tommorow after this blows through
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-30-2012, 03:43 PM   #175
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well went out today and they decided to run electronics , footbrake and a 5th gen camaro class . They had 15 dot tech cards sold and only 5 cars in the camaro only class . Got 1 pass in and was first down the track . Then the rain came . ET bracket finals here we come starting thursday .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
