Old 10-09-2015, 08:45 AM   #151
BMERDOC
BMERDOC's Avatar
Re: My caster mod (with pictures)
Originally Posted by picklito View Post
Not sure I'm following this. 1/8" (where?) equals .5"(where?).
Uppers back is a good idea, too. Before I found these threads I was only thinking of lowers forward cuz I also wanted to move the wheel forward in the well, mainly for cosmetics. Obviously, uppers back would negate a little of this, but I'd take 6 degrees over a perfectly centered wheel!
I probably shouldn't include myself in the conversations while I'm half asleep on the couch. Now I need to go back and re-read everything I wrote.
I have been thinking about elongating the upper cross shaft locating holes for finer adjustments, leaving the shims only for camber adjustments (1/8" of motion would equal .5 degrees of movement). I need to go back and look over your math and Scoti's alignment numbers.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-15-2015, 05:25 PM   #152
69gmcc10
69gmcc10's Avatar
I have become quite fond of this thread as of late, probably because I am at this point in my build and I wanted to say thank you all for being a part of this growth and development to improve our vehicles.
I know there is some discrepancy in the OE and aftermarket lower shaft index holes and I Just wanted to share what I removed from my truck last night. As far as I can tell from the amount of play on the ball joints and the shaft bearings coupled with speaking to the brother and mechanic of the long term owner of the truck my lower shafts on my 72 are original. The hole is indexed 1 1/2" back from where the shaft decreases in diameter to accept the arm (photo may be deceiving). I will post numbers on what my moog replacement shafts come indexed to and then have them re-indexed with 2 or 3 longer indexed hole locations for adjustment at a machine shop.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-15-2015, 11:28 PM   #153
picklito
You, too! Thanks! Good pic.
picklito is offline   Reply With Quote
Old 10-18-2015, 09:19 PM   #154
jnickell41
The pictures below are of my recently delivered CPP lower shafts. As you can see the indexing holes are already at 2" from where the shaft drops in diameter.
These will be going on an '87 2wd, should I bother getting holes drilled at 2.25"?
jnickell41 is offline   Reply With Quote
Old 10-18-2015, 11:09 PM   #155
Domer
Domer's Avatar
What is the distance from hole to hole center? The factory ones are around 8.xx inches. Where as the pins are 9"
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Domer is offline   Reply With Quote
Old 10-19-2015, 08:05 AM   #156
jnickell41
I'll check when I get home. Does this influence anything, I thought only one end indexed in the the frame member?
Old 10-19-2015, 09:00 AM   #157
BMERDOC
BMERDOC's Avatar
Only one does from the factory. What box did those shafts come in?
Nick Carter
Old 10-19-2015, 09:12 AM   #158
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Just my opinion... but I don't think you can compare the steel bushing and rubber bushing type shafts with one another. Who's to say that the shoulder you're measuring from is the same on both types of shafts?
I think all of these measurements would be best taken from the centre of the LCA shaft. That way, we could accurately compare any type of LCA shaft. Like this...
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 10-19-2015, 11:35 AM   #159
crakarjax
crakarjax's Avatar
Very good point, iff the shoulders are indeed different. Anyone have two types of shafts that they can compare?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 10-19-2015, 08:55 PM   #160
jnickell41
So these will be going on a 1/2 ton '87 R10 so will have the rubber bushings.
The holes are 8.75 inches apart, 4.375 inches from the centerline of the shaft. I have included a picture of the box they came in.
I checked the shafts that came out of these lower control arms and they appear to be the exact same measurements, distance from the ends as well as distance from each other.
Am I missing something here, are the majority of the 1.5 inch measurements I've seen on this site from 72 and older trucks, or 3/4 ton trucks with steel bushings?
Any insight would be greatly appreciated.
Old 10-20-2015, 09:47 AM   #161
The Rocknrod
Moderator
The Rocknrod's Avatar
I have a 64 with Steel Bushings, here are my measurements before drilling on a stock unit:
Old 10-20-2015, 03:43 PM   #162
69gmcc10
69gmcc10's Avatar
That is one of the things we are trying to figure out right now and why everyone is trying to add as much info as possible. Thanks for adding your information to the thread. Hopefully, with guidance from BMERDOC and others of his caliber on this thread, we can make some sense of things.
Old 10-26-2015, 03:22 PM   #163
crakarjax
crakarjax's Avatar
I got my bag mocked up, but it looks like it'll have stress in bad places. Then again, I've never run bags. Anyone know if the offset pictured will cause more than a marginal decrease in bag life? I also have no idea what the internal bumpstops on these bags look like. I'm a little worried that they aren't making solid contact as pictured.
Old 10-26-2015, 03:47 PM   #164
BMERDOC
BMERDOC's Avatar
Have you put air in them (cycled them) to see if they settled out correctly?
Nick Carter
Old 10-26-2015, 03:49 PM   #165
SCOTI
SCOTI's Avatar
I made my own upper plates & shifted the mounting holes forward when I did the caster mod for my lowers. I then had to shift them back (drill more holes) when I swapped in the PB lowers.
I would make new uppers or re-drill the holes accordingly to keep the bag as straight as possible @ ride height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-26-2015, 04:38 PM   #166
crakarjax
crakarjax's Avatar
No, my crossmember isn't installed yet so I'm just mocking things up. I contoured my lower cups though and they're inthe spot where they are going to land.
Yeah, shifting them forward seems like the best option at this point -- I should have waited on painting the plates! I wish I had just fabbed up some plates for the lower control arms now though, because then I could put the bags wherever I wanted them. I did find a cutaway of the SS bags though and the bumpstop looks like it covers the entirety of the bag top/bottom, being a non-issue.
Old 11-10-2015, 01:32 PM   #167
69gmcc10
69gmcc10's Avatar
got myself my new Moog (part# k6147) lower shafts in the mail today! When I set them up against the old shafts I noticed something was not right!
The old shafts are longer than the new shafts!
Old 11-10-2015, 01:48 PM   #168
69gmcc10
69gmcc10's Avatar
New shafts
Old 11-10-2015, 01:50 PM   #169
69gmcc10
69gmcc10's Avatar
Old Shafts
Old 11-10-2015, 02:04 PM   #170
69gmcc10
69gmcc10's Avatar
And side by side...
Old 11-10-2015, 02:18 PM   #171
69gmcc10
69gmcc10's Avatar
In the photos yo will notice the overall length of the shafts themselves are the same, bot with and without the caps on. When comparing the end of just the shafts, not the knurling or lip but over all length of the entire rod, the index hole on both shafts are the same. It appears that there was a redesign to the new shafts at some point and they decreased the length of the large diameter (by 3/8" on each end to be exact) and used a longer rubber grommet to cover the distance. This is why we are getting different dimensions when comparing old shafts to new shafts, they are designed slightly differently, but keep and maintain the same geometry as the old shafts.
One of the biggest telling factors are the rubber seals/grommets used, there is a large difference between the old and new.
Old 11-18-2015, 05:50 PM   #172
The Rocknrod
Moderator
Can you just buy those new grommets somewhere?
Old 11-23-2015, 12:13 PM   #173
69gmcc10
69gmcc10's Avatar
I don't know, I haven't looked, sorry.
Old 02-20-2016, 12:28 AM   #174
Ezzz
About to give this mod a go this weekend. One thing I'm wondering is why it's necessary to remove and replace the original riveted stud on the saddle that serves to locate the shaft? If we're drilling the same size locating hole on the shaft won't the same locator work?
Ezzz is offline   Reply With Quote
Old 02-20-2016, 07:49 AM   #175
jjzepplin
jjzepplin's Avatar
I reused it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
