Old 06-20-2014, 01:21 PM   #151
McMurphy
McMurphy's Avatar
Re: 1962 chevy c10 update.
Originally Posted by 62 Barnfind View Post
I painted it with rustoleum semi-closs white and it took a while to get it right. For some reason the cans are so full you can't rattle the can until you spray out about a1/4 of it. The first 1/4 comes out with globs and it kept messing up my paint job.
Tap the bottom of the spray paint can on something solid like the floor or I use my vise a lot. The ball in the can tends to settle in the bottom and just needs to be jarred loose.
I did my whole build with Rustoleum spray cans, so I know a few tricks about them.... LoL
Otherwise the grille looks great !!
Were the letters difficult to do?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 06-20-2014, 01:34 PM   #152
1963c-10
1963c-10's Avatar
Looking good....keep up the progress and updates!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-07-2014, 07:41 PM   #153
62 Barnfind
62 Barnfind's Avatar
Finished the radio mount today. It came out good but the pic isn't good. I need to order the speaker mounts for the kick panels and get it hooked up to the radio. I also took the truck to the exhaust shop to get a glass pack installed. I pick it up tomorrow and it will be ready to get inspected. I'm having surgery so I won't get it done until Aug.
I will post pics of the exhaust after I pick it up.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 07-10-2014, 08:39 AM   #154
bj383ss
bj383ss's Avatar
Looks good John. I have to do the same to mine.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 07-11-2014, 08:31 AM   #155
62 Barnfind
Let me know when you are ready. I'll come by and help you. It's better to do it when you are doing the metal work inside before the interior goes in.
John Z
62 Barnfind
Old 07-11-2014, 08:43 AM   #156
1963c-10
1963c-10's Avatar
Nice job on the radio repair. I've got to do the same in my fleetside when I get to that point. Also have to fix a piece of the speaker grill on top of the dash. PO's on that truck drilled over 20 holes that will need welded up. Funny thing is not one thing bolted or screwed down to any of the holes.....can only wonder what was mounted.
Old 07-11-2014, 06:02 PM   #157
bj383ss
bj383ss's Avatar
No Problem John. Thanks for the help. I will need you help to put the cab back on as well. Plan on getting 4 guys together instead of using the engine hoist.
Old 07-11-2014, 08:06 PM   #158
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looks good! I like it!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-13-2014, 02:46 PM   #159
62 Barnfind
I had to stop on the truck for a while. i just finished my leg realignment surgery on the 10th. I can't put any weight on my leg for 7 weeks and the pain sucks so bad right now. i can still come and direct all the traffic when you are ready to do it.
John Z
62 Barnfind
Old 07-13-2014, 03:16 PM   #160
markeb01
Senior Enthusiast
markeb01's Avatar
That dash sure turned out nice. Never know it was damaged. Another tip regarding spray cans, heat them up in warm (not boiling hot) water for 5-10 minutes before spraying. It loosens up the rattle ball, and also increases the pressure of the propellant so the can doesn't start spitting half way through the paint job.
Sorry to hear about the surgery. That can certainly put a miserable crimp in your progress. Good luck on a speedy recovery.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-13-2014, 04:33 PM   #161
62 Barnfind
Thanks for the tip and compliment. Those rattle cans sure been pissing me off. Thanks for your concern on my leg surgery. It's the first of two that hopefully will prevent full knee replacement.
John Z
62 Barnfind
Old 07-13-2014, 06:20 PM   #162
Johns66
Very nice job.
Johns66 is offline   Reply With Quote
Old 07-13-2014, 08:00 PM   #163
bj383ss
bj383ss's Avatar
Wishing you a speedy recovery. Let me know if you need help with anything. Its been a year already since I came and got your wheels.
Bret
Old 09-21-2014, 06:48 PM   #164
62 Barnfind
Finally got around to installing the radio in the truck. I wasn't digging the floor vents at all so I wanted to do something different. I saw that DLW had his speakers in the floor vents and it gave it clean look. So I cut some steel, painted it and mounted some 4in speakers and screwed them in place. It can be changed at any time I cut it from the vent design and used the original mounting screw holes. Here are the pics.
John Z
62 Barnfind
Old 11-30-2014, 06:41 PM   #165
62 Barnfind
Attended my first coffee and cars this morning. I met a bunch of cool people, good coffee and saw some fine rides.
John Z
62 Barnfind
Old 12-01-2014, 08:48 AM   #166
bj383ss
bj383ss's Avatar
Radio looks great John. Which one did you go with? It looks to be one of the Ipod compatible ones.
Old 12-01-2014, 06:53 PM   #167
62 Barnfind
Yes it is the IPOD one. It works great!
John Z
62 Barnfind
Old 12-01-2014, 09:18 PM   #168
Clrussell
Clrussell's Avatar
Nice build, saving it for later for a good read and info!
61 apache
Clrussell is offline   Reply With Quote
Old 12-01-2014, 09:31 PM   #169
62 Barnfind
Thanks Cirussell. I hope you enjoy it!
John Z
62 Barnfind
Old 04-07-2015, 06:56 PM   #170
Eric15chevys
Eric15chevys's Avatar
Man that is a great looking 62. I can't wait until mine is up and running.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 04-08-2015, 01:40 PM   #171
62 Barnfind
Thanks! I couldn't wait either.
John Z
62 Barnfind
Old 05-02-2015, 09:53 PM   #172
62 Barnfind
Friday I took the fender off to try to get the door aligned. I had Bret (BJ383SS) come help me do it. After a couple of hours I think we finally got it aligned and found two other problems. One is the door seal and the latch. So now I have a new latch on order and the door is aligned better. Today I entered my truck in it's first car show. As of now all I have been doing was going to cruise Ins and get togethers. I wasn't expecting coming home with any trophies because I came late to the show. It turned out to be a good day, I came home with six and one of them was best in show. I guess we did a good job Bret getting that door aligned!
John Z
62 Barnfind
Old 05-02-2015, 10:20 PM   #173
Monte's62
Congrats on the new hardware!! Nice truck
Monte's62 is offline   Reply With Quote
Old 05-02-2015, 11:30 PM   #174
Jeff La
Congrats, you did a great job and deserve it.
Jeff La is offline   Reply With Quote
Old 05-02-2015, 11:58 PM   #175
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Congrats! Well deserved!
