Old 09-05-2016, 01:13 PM   #151
Old_Truck_Fan
Re: Project "Financial Burden": 1968 SWB C10
Loaded up for storage.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 09-05-2016, 01:59 PM   #152
Advanced Design
Advanced Design's Avatar
Congrat's on the new house and bigger shop. Truck is looking good...and who doesn't like two turbos in place!
Advanced Design is offline   Reply With Quote
Old 09-05-2016, 03:48 PM   #153
slowcpe
slowcpe's Avatar
Nice progress. Those turbos looks sweet!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-22-2016, 05:49 AM   #154
Seventy Two
Subscribed
Seventy Two is offline   Reply With Quote
Old 04-26-2017, 07:31 PM   #155
Old_Truck_Fan
Well the new house is finally finished and we have moved in. The workshop is 24' x 26'. I started by epoxy coating the floor and then moved all my stuff out of storage. It's a mess at the moment but I hope to have it functional in the next two months so I can start back on my project.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 04-26-2017, 07:58 PM   #156
SouthGA 67
Very nice. That thing is gonna rip.
SouthGA 67 is offline   Reply With Quote
Old 04-26-2017, 09:40 PM   #157
Smittee
Looks like a REALLY nice project! Hopefully some day I will get to see it in person. I get over towards Columbus for meetings in Bloomington every month! So yeah, we are kind of neighbors!
Smittee is offline   Reply With Quote
Old 07-30-2017, 07:56 PM   #158
Old_Truck_Fan
Thanks for all the nice comments guys. I finally have my new shop organized and started making sparks for the first time today. It's good to be back in the shop and making progress after 11 months on the pause button. I've attached a picture of the shop as it sits today. I enjoy watching shop tours on YouTube so I figured I should at least post a picture of mine. I'm sure I'll make some more changes but for now I'm ready to start using it!
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 07-30-2017, 09:44 PM   #159
72 tigger
72 tigger's Avatar
Very organized! Almost looks too nice to work in!
72 tigger is offline   Reply With Quote
Old 08-01-2017, 12:43 PM   #160
erichevy
erichevy's Avatar
Great work! I'll follow along. Give me some inspiration for when i start working on my 68 SWB C10.
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 07-01-2018, 07:14 PM   #161
Old_Truck_Fan
It's been a long time since my last post. So let's get you up to speed. I painted the inside of the door shells and the new door skins. Since I had easy access at that point I put Dynamat on the inside of skin and the lower part of the door shell. It made a big difference in the sound of the door when you strike it with your knuckle. I hope it helps when you shut the door as well. I purchased a Craig Hopkins "Door Skinning 101" DVD and followed the techniques he outlined. This worked out well and I would recommend the video if you are doing it for the first time. I have to do some more tweaking and final welding but I was happy with how things turned on both doors.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 07-01-2018, 07:20 PM   #162
Old_Truck_Fan
More pictures.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 07-01-2018, 07:29 PM   #163
Old_Truck_Fan
I also realized why I see a lot of trucks without the rear tire splash guards. The fit of the aftermarket panel is off by quite a bit. I had to redo and rework them but I was able to get them to fit. I would hate to add up how many hours I have in them for such a small detail but it does finish off that area of the truck.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 07-01-2018, 07:33 PM   #164
Old_Truck_Fan
Under hood plumbing and mechanicals are next. Here's a shot of one of the intercoolers next to my mock up.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 07-03-2018, 10:19 AM   #165
knomadd
knomadd's Avatar
Nice work, keep it up.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-06-2018, 08:05 AM   #166
mcbassin
Still Learning
mcbassin's Avatar
Very clean work on the sheet metal! Looks great!
mcbassin is offline   Reply With Quote
Old 07-06-2018, 08:48 AM   #167
nawlinjoe
Looking good.... subscribed
nawlinjoe is offline   Reply With Quote
Old 07-06-2018, 09:35 PM   #168
72 tigger
72 tigger's Avatar
Making good progress- will be a super nice truck when finished
Old 02-24-2019, 09:46 PM   #169
Old_Truck_Fan
I've got several updates to pass along. First I finished welding the door skins and drilled for for the rear view mirrors. I also cut the dash for the center AC vent and the two side vents. The ball in the side vent is a billet piece from Restomod Air.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 02-24-2019, 09:50 PM   #170
Old_Truck_Fan
I installed a clutch master cylinder from a board member and finished up the weld nuts and support strips for high hump tunnel.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 02-24-2019, 09:57 PM   #171
Old_Truck_Fan
I also came up with a Dodge Hellcat inspired fresh air inlet setup near the head lights. Duct work will connect these 4 inch tubes to the turbocharger compressor inlets.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 02-24-2019, 10:05 PM   #172
Old_Truck_Fan
I also mounted the intercoolers and was able to preserve the factory hood latch and grill support. The bottom grill surround needed just a little modification to clear and I made some pass through provisions for the cold side plumbing.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 02-24-2019, 10:10 PM   #173
Old_Truck_Fan
Santa also brought me 45,000 BTU garage heater which has been nice the past few weeks and an upgraded tool box. I went kinda nuts on organizing stuff.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 02-24-2019, 10:47 PM   #174
72 tigger
72 tigger's Avatar
Can’t be too organized- great attention to detail- any goals for paint?
Old 02-25-2019, 12:40 PM   #175
slowcpe
slowcpe's Avatar
Very nice. I'm jealous of the heater. This time of year I have the constant taste of keroscene in my mouth.
Ryan
