Old 11-07-2014, 02:17 AM   #151
marvgarr68
marvgarr68's Avatar
Re: 68 c10 6.5 turbo diesel
Originally Posted by '68 Newtricks View Post
ahhh it's so close I can hear it!!
I know so close.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 11-15-2014, 10:38 PM   #152
marvgarr68
marvgarr68's Avatar
Got some work done. I finally got the Fluid Damper and installed it. Crank pulley is installed so is the fan and the spacer. My buddy machined this spacer to my specs to get the fan were I wanted it. The spacer also adapts due to the wp hub being 3/4's and the fan pilot is 5/8's he made it very precise. I got the belt ran finally so that wraps up the front of the engine. I mounted the oil fill with new grommet in timing cover. I also welded a v band flange to the top intake and installed it. I have the ceramic coating for the exhaust manifolds I still have to finish them. I also installed the timing tab.
Old 11-15-2014, 10:41 PM   #153
marvgarr68
marvgarr68's Avatar
Some more pictures.
Old 11-15-2014, 10:45 PM   #154
marvgarr68
marvgarr68's Avatar
I also got the steering all wrapped up.
Old 11-17-2014, 06:11 PM   #155
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Looking good. Is there not enough room for a fan clutch, or did you just not want to use one?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-17-2014, 06:57 PM   #156
marvgarr68
marvgarr68's Avatar
No room for fan clutch.
Old 11-18-2014, 09:17 PM   #157
Dieselwrencher
I was wondering if that was the issue.
Ryan
Old 11-19-2014, 02:11 AM   #158
marvgarr68
marvgarr68's Avatar
Should run cool not sure on the noise or mpg though.
Old 11-22-2014, 08:01 PM   #159
marvgarr68
marvgarr68's Avatar
Got the exhaust manifolds all ceramic coated and turbine housing on turbo ceramic coated also ceramic coated all the manifold bolts. Also a pic of the top hat all finished.
Old 11-24-2014, 09:24 AM   #160
Lemield
Lemield's Avatar
WOW! That sure looks NICE! I've said it before, you do nice work.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 11-24-2014, 01:36 PM   #161
marvgarr68
marvgarr68's Avatar
Thanks. I really appreciate it.
Old 11-29-2014, 04:42 PM   #162
marvgarr68
marvgarr68's Avatar
got injector return lines installed. I also got the ignition bezel and scratch guard installed. Also replaced the headlight knob and wiper knob.
Old 11-30-2014, 11:25 AM   #163
Dieselwrencher
Nice work. Where'd the scratch guard come from?
Ryan
Old 11-30-2014, 02:49 PM   #164
marvgarr68
marvgarr68's Avatar
Brothers is where I bought it.
Old 11-30-2014, 03:53 PM   #165
Dieselwrencher
Cool, thanks.
Ryan
Old 12-24-2014, 07:19 PM   #166
marvgarr68
marvgarr68's Avatar
Here are some pics of what I have done lately. The first pic is the circuit breaker for the glow plugs. Next is the oil pressure gauge line. The rest is the exhaust cross over I made and the v band flange I welded on to the turbo. I still need to ceramic coat the cross over and put the bottom connecting flange on.
Old 12-24-2014, 07:21 PM   #167
marvgarr68
marvgarr68's Avatar
More of the cross over.
Old 12-24-2014, 07:26 PM   #168
marvgarr68
marvgarr68's Avatar
Here is the turbo finally mounted, heat shield on, and turbo drain and oil supply line done. I also wired up all the glow plugs and made my own harness and in cased it in a heat sleeve good for 2000 deg.
Old 12-28-2014, 09:29 PM   #169
marvgarr68
marvgarr68's Avatar
I got exhaust crossover ceramic coated and v band welded in.
Old 12-29-2014, 03:04 AM   #170
Dieselwrencher
Nice work on it!
Ryan
Old 12-29-2014, 05:40 PM   #171
marvgarr68
marvgarr68's Avatar
thanks.
Old 01-03-2015, 10:06 PM   #172
marvgarr68
marvgarr68's Avatar
I got the crossover wrapped and installed with new gaskets. I also got the oil cooler lines ran.
Old 01-04-2015, 10:34 AM   #173
ryanroo
ryanroo's Avatar
very nice. i love the attention to detail.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-04-2015, 12:46 PM   #174
jbclassix
Junk Yartist
jbclassix's Avatar
Attention to detail ends up fixing everything GM did wrong. I can say that because I have a 6.5 that needs something every time I drive it. This 6.5 is the cleanest, smartest 6.5 I have ever seen. Every little thing is built better and looks better. I love the 2 piece cross over. Genius!
Edit. Almost forgot. Did you already post what you are doing for a lift pump?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-04-2015, 03:25 PM   #175
marvgarr68
marvgarr68's Avatar
Thanks jb haven't heard from you in a while did you have a great holiday? I hope I have covered all the factory mistakes we shall see. I had to do the crossover two piece because it would not fit in my blasting cabinet very well. Plus it would be a pain ceramic coating it. Makes it nice bolting it up though goes right on with out messing with it. The lift pump is a carter 8 psi 72 gph pump. I think there is a pic of it on here mounted right after the pri fuel filter on the firewall. I know fuel pumps are suppose to be mounted below the tank but truck is low and if ever there was a problem I want to be able to get to it.
