Old 09-28-2016, 09:25 PM   #151
Advanced Design
Advanced Design's Avatar
Re: Mike's 50
Looking very good!
Advanced Design is offline   Reply With Quote
Old 10-02-2016, 07:58 PM   #152
MIKESAD50
Re: Mike's 50
Here are some final assembly (hopefully) pictures. Frame is going back together, still need to torque everything. need a port plug for the proportioning valve otherwise could have bled brakes.
Have Dyna Mat to start installing in cab. will start working on cab assembly. I will roll cab on back to clean, and coat with raptor liner or something similar, then will be able to install cab to frame.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 10-03-2016, 09:37 AM   #153
reaper71
reaper71's Avatar
Re: Mike's 50
Looks awesome.
Mark...
reaper71 is offline   Reply With Quote
Old 10-04-2016, 07:31 PM   #154
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Mike's 50
Looking good!
ChuckDriver is offline   Reply With Quote
Old 10-08-2016, 10:26 AM   #155
Scott2
Re: Mike's 50
Looks great! Where did you end up on tire and wheel size?
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 10-08-2016, 02:04 PM   #156
Thesilverfox
Thesilverfox's Avatar
Re: Mike's 50
It's going to be a really nice truck
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003
Thesilverfox is offline   Reply With Quote
Old 10-08-2016, 05:34 PM   #157
MIKESAD50
Re: Mike's 50
Scott 2- I went with Boss 18x9.5 rear with 18x8 front.
Tires 295/35/18 rear and 255/25/18 front
Silverfox- thank you
1950 3100 5 window
Old 10-08-2016, 05:41 PM   #158
MIKESAD50
Re: Mike's 50
Couple of AD's seen today at Laguna Seca. the green one was a 3rd generation family truck and nice. the red was nice also.
1950 3100 5 window
Old 10-14-2016, 10:23 PM   #159
MIKESAD50
Re: Mike's 50
Making some progress. Installing Dynamat, also got steering column in, Glove Box door, Liner , and Speaker grille and Gauges.
Plan on continuing with Dyna Mat and maybe get to door Reassembly.
I will work on getting cab on its back and clean, paint and undercoat the bottom of the cab.
I will get some pictures posted tomorrow or Sunday.
1950 3100 5 window
Old 10-16-2016, 03:10 PM   #160
MIKESAD50
Re: Mike's 50
Not much Motivation this weekend for truck work. Did go to shop today and start installing wiper linkage to body installed Drivers side cowl vent gasket and. Couple of pictures
1950 3100 5 window
Old 10-16-2016, 03:14 PM   #161
MIKESAD50
Re: Mike's 50
another shot
1950 3100 5 window
Old 12-04-2016, 05:52 PM   #162
MIKESAD50
Re: Mike's 50
Not alot going on other than working, not on the truck much.
Got the bottom of the cab cleaned and put a coat of Por15 top coat on and will cover next with MonstaLiner roll on bed liner.
I've also started on reassembly of doors.
Hopefully will be able to apply bed liner next weekend.
1950 3100 5 window
Old 12-04-2016, 06:34 PM   #163
Advanced Design
Re: Mike's 50
The floor bottom looks really good. Progress is progress....
Old 12-17-2016, 10:05 PM   #164
MIKESAD50
Re: Mike's 50
Got first coat of bedliner on bottom of cab and wheel side of inner fenders.
I used Monstaliner roll on bedliner.
Tomorrow I will put a 2nd coat on.
1950 3100 5 window
Old 12-18-2016, 10:18 AM   #165
reaper71
reaper71's Avatar
Re: Mike's 50
Look's good, what kind of price point and Availability of the product?
Mark...
Old 12-18-2016, 06:10 PM   #166
MIKESAD50
Re: Mike's 50
For 2 gallons with everything you need including mixer, rollers, brush, etc was $250. it is from Chassis Saver. They have tintable also. shipped to my door.
2nd and final coat. will still need to do inside of front fender and also rear fenders.
1950 3100 5 window
Old 12-18-2016, 09:54 PM   #167
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Mike's 50
Looking amazing Buddy!
--Josh
Old 12-24-2016, 07:25 PM   #168
MIKESAD50
Re: Mike's 50
Stockish, Advanced Design, Reaper71, Thanks.
Got the cab back on the chassis hopefully for the last time.
Started filling and bleeding brakes, not done. Have had a few small leaks. I'll get it.
I also put the steering linkage back in, need to reclock it and loctite the set screws.
1950 3100 5 window
Old 12-30-2016, 06:55 PM   #169
MIKESAD50
Re: Mike's 50
Well i got a few things done this week.
I media blasted and painted with VHT Epoxy painted the running board seal retainers. Installed the new running board seal and retainers
Media blasted the Interior Dome Light painted it also, cleaned up the trim, Have another one that is painted interior color, Like this one though.
Loctited the steering shaft set screws.
Installed the brake pedal.
Also Installed a Lokar black Transmission dipstick Assembly.
Hope the trans mount Tube assembly will work.
Couple of pictures. Little things count towards the final product
Also reinstalled the cowl vent assembly
1950 3100 5 window
Old 12-30-2016, 08:29 PM   #170
Advanced Design
Re: Mike's 50
I do like the trans dip stick tube tucked away like that, if it is reachable. Plus loctite on the steering set screws...going together and staying together.
Old 12-30-2016, 11:01 PM   #171
solidaxel
solidaxel's Avatar
Re: Mike's 50
FYI, I am getting some fluid from my Lokar trans dip stick where it meets the seal on the trans, my plan is to remove it and add silicone around the base to see if it quits leaking (4L60E)
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-31-2016, 10:06 AM   #172
MIKESAD50
Re: Mike's 50
Solidaxel, I did put a small amount of silicone on the tube fitting at transmission case, just above o-rings. It actually mentions it in the install directions.
1950 3100 5 window
Old 12-31-2016, 10:17 AM   #173
HULK64
Re: Mike's 50
Did you put bedliner under the hood as well? Looks like great stuff and went on smooth- I am debating between this stuff and raptor liner. Any reason to sway me? I like that the Raptor liner isn't chunky- but the monsta liner looks pretty smooth as well....
HULK64 is offline   Reply With Quote
Old 12-31-2016, 11:57 AM   #174
MIKESAD50
Re: Mike's 50
Hulk64,
I did not use bedliner on underhood, it is just a Hot rod satin black paint same as firewall and rest of underhood metal.
I bought product for roll on fact. It is sprayable also. Cant say anything about raptor liner, I was looking for ease of prep since not spraying, prep was "easier"
I'm happy with the light texture and ease of use and will be using on underside of front and rear fenders. Eventually will find out how durable it is once on the road.
1950 3100 5 window
Old 12-31-2016, 04:44 PM   #175
hotrodelrod
hotrodelrod's Avatar
Re: Mike's 50
Mike, Just read your whole build, don't know how I missed it. This is one beautiful truck glad to see you're in the homestretch.
Rick
hotrodelrod is offline   Reply With Quote
