#151 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: 1961 Crew Max
Got it back to a roller with some help from my head mechanic.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#152 |
![]() Join Date: Jul 2012
Re: 1961 Crew Max
Great picture with the head mechanic!
Chizzler, looks really good as a roller. This is going to be a very cool truck. |
#153 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 1961 Crew Max
That is down there man! It looks great! I'm sure the head mechanic loves all your rides!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#154 |
Re: 1961 Crew Max
Today got started on fitting the motor. This thing is massive. Was able to get the crank pulley over the R&P by 1 1/2" and oil pan in back of R&P about the same. Everything is clear around the frame rails. Motor mounts will need to be relocated back farther. Oil filter will need to relocate. Both oil and trans pan are above bottom of frame rails. Most likely the entire recessed section of firewall will have to be all remade. You can see in the last pic how close the motor is to the top of firewall. Body still needs to come down about 1 1/2" to sit on cab mounts. Overall fit is pretty good to start.
#155 |
Re: 1961 Crew Max
Now you're talking!!
#156 |
Registered Loser
Re: 1961 Crew Max
Dang! That rocks!
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#157 |
Who Me?
Re: 1961 Crew Max
The head mechanic is awesome! Hopefully he will keep this project on schedule and under budget!
Correction: What is the head mechanic doing with an Eagles shirt on? I will send him a Steelers shirt soon ![]()
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#158 |
Re: 1961 Crew Max
No eagles around here. Seatte seahawks. As far as budget and schedule goes if it's under what the wife thinks im good. Thanks for checking in.
#159 | |
![]() ![]() Join Date: Jul 2002
Re: 1961 Crew Max
#160 |
Who Me?
Re: 1961 Crew Max
You're right!! My bad on the wrong bird identification!
#161 |
Re: 1961 Crew Max
Nice work on fitting the engine!
#162 |
Re: 1961 Crew Max
I'm late to the party but I'm here now. Nice truck and nice work.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#163 |
1961 crewcab
Re: 1961 Crew Max
that's going to be quite a high hump! looks like you might even need to modify the seat if you go with a bench..
are you going to use a heater? and is there still room for the wiper motor? I sectioned a 60 el camino, and those were 2 things that fought me a little bit, I wanted at least a generic heater just for the defrost function.. after seeing this I can't wait to get the body on mine , looks good low!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#164 |
Re: 1961 Crew Max
Major modification through the floor and firewall. Should be able to fit a heater with defrost and floor heat. Going to use factory bench so might have to tunnel through bottom of front bench. We will see for the wiper motor soon. Thanks for checking in.
#165 |
![]() Join Date: Mar 2007
Re: 1961 Crew Max
Chizzler -
This ones going to be great. I like the start. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#166 |
Re: 1961 Crew Max
Thanks marc.
#167 |
Re: 1961 Crew Max
Well motor is in for now. More clearance is needed at the top of the firewall but sitting on cab mounts.
#168 |
Custom Truck Lover!
Re: 1961 Crew Max
Love this truck. Sweeeeet!
Squarebody guy |
#169 |
One day...
Re: 1961 Crew Max
Pretty awesome build, keep it up!
#170 |
Re: 1961 Crew Max
So cool. Can't wait.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#171 |
Re: 1961 Crew Max
Wow, that looks so cool Chizzler!
#172 |
Re: 1961 Crew Max
Wow,that looks great and I love your shop .
#173 |
Re: 1961 Crew Max
I really like the 65 grill with the center removed , my other 63 has a 65 grill...
#174 |
1961 crewcab
Re: 1961 Crew Max
right click save, right click save!
love the look.
#175 |
Re: 1961 Crew Max
Hi,
Your build is looking great! I'm also thinking of a Duramax swap. I have an LLY from a 2WD 2007 Savana. It has the smaller gear box, so it should be less cutting in floor. Any other major issues seen yet? How are you doing with rebuild of the Duramax harness? What motor mounts did you chose from Porterbuilt? I guess they do not fit, but was it even close? I'll keep looking. /Thomas
1965 c10 BBW LWB - Duramax 2010 Camaro SS - Whipple (721hp) 2017 Volvo V60 diesel-hybrid (233hp) 2008 volvo XC70 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=677577 |
