Old 02-02-2019, 01:46 PM   #151
Advanced Design
Advanced Design's Avatar
Re: slammed 57
Really nice work! Enjoying following along.
Advanced Design is offline   Reply With Quote
Old 02-02-2019, 03:13 PM   #152
mongocanfly
Post Whore
mongocanfly's Avatar
Re: slammed 57
Looks great...no problem seeing your pcs....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-03-2019, 11:38 AM   #153
clegg
Re: slammed 57
Originally Posted by slammed57 View Post
graphed in the one piece dash yesterday
Also squeezed in the vintage air gen iv unit( its a big unit and tight fit due to the engine set back ,but its as snug as a glove).. after i cut out the original dash I mocked up the condenser, pre- ran all the lines, bulk head fittings made sure there was enough room for all the vent runs, and defroster vents, welded in threaded studs so the fire wall remains clean. If didnt do this when the dash was cut out and would have put the smooth dash in first, it would have been a nightmare to get it all put in.( Thanks rick mellon for that idea )
If you look way down there you can see how i ran the A/C lines and the heater lines just hidden under the A/C lines ( for a clean look with easy maintenance if need be,, the dryier is tucked up under the fender
Found some pre-molded heater lines so I can run them where It needed to be.
put in a more compact size hood latch and relocated
Nice work so far, very inspiring.
In the last pic showing that hood latch spring, does anyone know where to source one? Mine is missing and I have not been able to find one.
clegg is offline   Reply With Quote
Old 02-03-2019, 02:13 PM   #154
Black_Sheep
Black_Sheep's Avatar
Re: slammed 57
The shaved dash came out nice!
Black_Sheep is offline   Reply With Quote
Old 02-05-2019, 11:44 AM   #155
slammed57
slammed57's Avatar
Re: slammed 57
thanks everyone, I appereciate it.
CLEGG are you asking about the factory latch spring that you need?
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 02-05-2019, 01:57 PM   #156
clegg
Re: slammed 57
I have the latch assembly, just not the spring that pushes the hood up when released. Thanks.
Old 06-07-2019, 09:10 PM   #157
slammed57
slammed57's Avatar
Re: slammed 57
well back on the truck here....my new goal is to have all the metal work done by October...remember its a GOAL, not an ABSOLUTE but I am pretty determined here... we'll see. but I got the front sway bar in the rear sway bar will be in by the end of the month... also been looking for rear shock mounts but I could find anything that would work for me sooooo! I fabricated some up... took a while to cut and weld everything up, but they are in. THe Mar-k bed should be here next Wednesday. I am looking for a pair of good rear step side fenders if any of you know of a pair for sale, I know shipping ain't cheap but I need some. but thanks for checking in
My 57 current build
Old 06-22-2019, 08:57 PM   #158
slammed57
slammed57's Avatar
Re: slammed 57
Got the new mar-k bed the other day... real nice quality i do have to say. but nothing more nerve racking than cutting up a brand new bed. now I need to come up with a plan for raising the bed floor and tubs
My 57 current build
Old 06-22-2019, 09:03 PM   #159
mongocanfly
Post Whore
Re: slammed 57
mar-k is top quality!!!...I wish they made more truck parts..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-22-2019, 09:12 PM   #160
slammed57
slammed57's Avatar
Re: slammed 57
57,
My 57 current build
Old 06-22-2019, 09:13 PM   #161
slammed57
slammed57's Avatar
Re: slammed 57
i wish they did too....
My 57 current build
Old 06-23-2019, 09:47 AM   #162
youngrodder
youngrodder's Avatar
Re: slammed 57
It looks great...For tubs I suggest looking at Dennis Carpenter F@*d parts
https://www.dennis-carpenter.com/en/
They are not cheap but I think that they have the best shape and you can get them in different widths. I went with 2 3/4" on my 48.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-23-2019, 12:13 PM   #163
mongocanfly
Post Whore
Re: slammed 57
Which ones did you use Marc?....I got some for mine that are for mid 60s Chevy truck...I've seen them used ad thought they looked good...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-23-2019, 08:09 PM   #164
jaws61
Re: slammed 57
i used the same ones as mongocanfly did and love them on the truck because it looks stock... plus the up side i think paid 100 canadian for the both of them...
jaws61 is offline   Reply With Quote
Old 06-23-2019, 08:30 PM   #165
slammed57
slammed57's Avatar
Re: slammed 57
I wanted to go with a wide harley rear fender. I was going split it down the middle and cut it to the size i needed.. I liked how curved it was and thought it would look pretty clean.....but radius is only 27" and i really needed about 32" radius... so I will probably go with mongocanfly type tub...
My 57 current build
Old 06-23-2019, 09:05 PM   #166
56hotrodred
Re: slammed 57
Really nice work.
56hotrodred is offline   Reply With Quote
Old 06-23-2019, 09:17 PM   #167
youngrodder
Re: slammed 57
Here's the ones I used..they were2 3/4" wide
Old 06-23-2019, 11:41 PM   #168
my56chevytruck
my56chevytruck's Avatar
Re: slammed 57
Hello my friend. I like the rear Harley fender idea, you'll find a way to make it right. you are very creative.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-23-2019, 11:56 PM   #169
svr
svr's Avatar
Re: slammed 57
I used a trailer fender, you can find them with a larger radius. I split it down the middle, welded a flange on them and covered the open side.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 06-23-2019, 11:59 PM   #170
svr
svr's Avatar
Re: slammed 57
Another, the fender was cheap$30-40 as i remember.
Old 06-24-2019, 11:29 AM   #171
slammed57
slammed57's Avatar
Re: slammed 57
Thanks bud... I did look at those and they look great . but I need them about 9" wide and would have to cut them up to get it there... I just hate to pay so much for something i still need to cut into
My 57 current build
Old 06-24-2019, 11:32 AM   #172
slammed57
slammed57's Avatar
Re: slammed 57
Thanks morrie but the radius just won't work and would have to really have to put too much time into them even if i could make them work
My 57 current build
Old 06-24-2019, 11:33 AM   #173
slammed57
slammed57's Avatar
Re: slammed 57
Yes Sir... I have been thinking this route as well. Did you weld them to the bed sides or did you make a flange and bolt them to the bed
My 57 current build
Old 06-24-2019, 10:19 PM   #174
svr
svr's Avatar
Re: slammed 57
Welded a flange on the inside and bolted them on. These are wide enough so nothing will bother them, they sit inside the C4 dogbones, tires will hit my dog bones first.
Old 07-02-2019, 09:18 PM   #175
slammed57
slammed57's Avatar
Re: slammed 57
Ok thanks bud, I appreciate it
My 57 current build
