#1826 | |
Re: PO has me PO'd
![]() Thanks Dusty for the deal
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#1827 |
Re: PO has me PO'd
Well, here is the new Scroggins-Dickey vortec tpi baseplate, mocked up with Kurt Lindner tpi
I believe it will be hooked up with FAST XFI mutiport fuel injection system...more to come on this part, as im still reading and learning which system is best for my app. EFI Connection is still in the running, uses LS1 components w/1 coil per cylinder Intake heater hose has to be changed for a 45 degree fitting...back into the season of working on the truck....lets see how far i get this year ![]() ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-09-2012 at 12:13 PM. |
#1828 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: PO has me PO'd
Is that the standard flow or high flow base?
#1829 |
Re: PO has me PO'd
#SD3816- doesnt say, but you can bolt on any factory or after market runners. Edelbrock offered hi flo
Im leaning more towards low end torque, as opposed to high rpm hp. As you know, these things stop flowing around 4500 Any advise you can give me would be great, did you solve your problem..... I have a great tuner with a dyno local to me
#1830 | |
60-66 Nut
Re: PO has me PO'd
We never did get that engine to start and run right. My son solved the problem with an RPM Air Gap and a 750 Holley.
I think you will have better luck with either an aftermarket ECM such as the FAST XFI, Holley Avenger or at least an OEM OBD II PCM such as the 0411, than we did with the OBD I ECM we were trying to use. From what I've read, the EFI Connection coil per cylinder conversion is a step in the right direction also. Although I haven't checked in the cost of that conversion, to know how affordable it is. Quote:
#1831 | |
Re: PO has me PO'd
Cost is comparible with the two units, about 2 grand give or takel
#1832 |
60-66 Nut
Re: PO has me PO'd
Since you have a good local tuner, you will have a big advantage over most of us in converting to EFI. When my son and I went thru this, we were dealing with someone 1200 miles away. At the time I did not know we had a decent chassis dyno and tuner not far away. Plus with the FAST XFI being a self tuning controler.
#1833 | |
Re: PO has me PO'd
Like you said, self tuner will help! First problem, throttle body has water outlets that are getting in my way, so i have to cut them off. They were used to prevent icing in the unit, so they can go away, since i dont live in alaska
#1834 |
Re: PO has me PO'd
#1835 |
Re: PO has me PO'd
Started screwing around with the throttle body, of course 4 of 7 screws where seized, soaking in pbpower blaster and gunk right now. Then ican cut off the water outlets
Probably some heat and tapping the studs will soften them up
#1836 |
Re: PO has me PO'd
Started to fool around with all three cables, or putting a round cable in a square bracket.
Found an oversized washer, ground down to square, and a press fit in the bracket. Corners will be silver soldered, as there is a small gap. The other square holes are the exact fit for oem cables, cruise and throttle Might build a collar to keep the kickdown cable in place ![]()
#1837 |
Re: PO has me PO'd
OOPS! Forgot i had this piece, makes it easier
#1838 |
high-Tech Red Neck
Re: PO has me PO'd
That is going to be a neat looking motor.
"He used to be a pretty nice feller, now he's a welder!" |
#1839 |
Re: PO has me PO'd
Thanks for looking and the compliments....wanted fuel injection, so i can remote start in the winter, always liked the look of the early tpi stuff, and this one fell in my lap.
Maybe, some day i can afford the englese system, looks like the early quad webers
#1840 |
Too Dumb To Know Better
Re: PO has me PO'd
Looks good Jim. It is amazing how many changes a project goes through the longer you work on it.
FI is definately an improvement over most carb setups. |
#1841 | |
Re: PO has me PO'd
Thanks for your encouragement Bud, and following along. There are times when i think this project will never get done, but i sit back and look at the whole and where it all started, and i do see progress... This fi will set me back, but i would rather have the truck roll out of the shop just the way i want it I turned 62 the other day, thinking of retiring, but this truck is what keeps me working.....
#1842 | |
![]() Join Date: Nov 2007
Re: PO has me PO'd
#1843 |
Re: PO has me PO'd
Thanks AJ, one other thing i forgot to mention in my rant....all the great people i have met along the way, 50 odd years and every day you meet someone with more info. then you previously had. Great board, huh?
Wish i had access when i started fooling around with cars
#1844 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: PO has me PO'd
Motor is cool looking .... Hope she runs as well as she looks...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1845 |
Re: PO has me PO'd
Thanks Bud, yeah, me too! The bottom end is the only thing in question, when i pulled the heads the cylinder walls where questionable......sooo, down the road it will have a stroked 400 sbc
Right now, im having problems with the water outlet on the intake. Been looking around to see what is available for the 1 1/2" outlet that i need. OEM seems to be about 1 1/4" Throttle cable for the tpi should be here this week....plus i hooked up the oem fuel rail, just have to find a regulator and pressure gauge
#1846 |
Re: PO has me PO'd
what the info on the valve covers? are those centerbolt heads there on?
#1847 |
Re: PO has me PO'd
Yes they are, a company down around south carolina casts them, pcv is under the cover...ill have to get the contact info. tomorrow
#1848 |
Re: PO has me PO'd
cool thanks!
#1849 |
Re: PO has me PO'd
You should have just found a totaled camaro or corvette... and pulled the engine...
very nice setup though
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#1850 | |
Re: PO has me PO'd
866-258-5670 www.cool-LEDS.com They work really well, if you have headers, since the spark plug wires feed thru the covers and directly at the spark plugs Cost about 150.00 Nah, Mikey, i dont have thousands to thro at the truck at one shot, this way, i only have to thro hundreds at it each time ![]() Thankyou for your continued service to the best country in the world, i for one sleep better knowing young men like you are covering my 6 Hope all is well with you and your family....call me if they ever need anything.... You cantrust a Marine with your money, and your life, just dont trust him with your wife ![]()
