Old 02-25-2019, 11:37 PM   #1826
smbrouss70
smbrouss70's Avatar
Re: How to: Ruin a perfectly good C10
I like it! Nice job of hiding the ugly stuff. Are you doing the water pump orange and the accessories black? or?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-26-2019, 03:40 PM   #1827
knomadd
knomadd's Avatar
woah, it's been a while since I checked in... 3 pages (well 2 really) of updates that I've missed out on. Looking good! I love the valve cover treatment and the hidden items on the intake. I like the orange engine myself.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-26-2019, 06:59 PM   #1828
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, trying to hide everything, but I may end up with the oil fill at the front of the valley cover (it’s getting crowded in the back), to be determined soon.
Water pump will be orange, brackets/pulleys black, alternator case ‘aluminum’ to break it up a bit, unless I decide I hate it, then it will get painted black. Same goes for brake and clutch masters, alloy for now, unless they bother me too much then they’ll end up black.
Appreciate the kudos. I’m liking how its all coming together. 3 pages now, your input counts!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-03-2019, 12:52 AM   #1829
gringoloco
A guy with a truck
gringoloco's Avatar
More progress, albeit small. I found some nickel plated 1/16” npt fittings to use for the steam vent, instead of buying the $100 AN hose kits that are for sale everywhere. I lopped off the long, stock nipple and used an elbow, then plumbed a straight fitting into the water pump. Short, sweet, and to the point.
Also installed the oil filler in the valley cover, which I’m kinda on the fence about, but the hole is drilled, so that’s that.
It’s all in the details... Maybe I’ll be ready to stab this thing, soon.
-Chris
Old 03-03-2019, 10:03 PM   #1830
smbrouss70
smbrouss70's Avatar
I like it, probably the cleanest way to do the steam vent. I like the oil fill, too. If you don't like it after the 30-day rule, you could always pull the valley cover and weld in a tube to mimic the old style fill tubes.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-03-2019, 10:23 PM   #1831
sprint_9
sprint_9's Avatar
Shaping up nicely.
sprint_9 is offline   Reply With Quote
Old 03-04-2019, 01:04 AM   #1832
gringoloco
A guy with a truck
gringoloco's Avatar
The filler is growing on me. I think it won’t be so glaring once the accessories and air cleaner and knock sensors and whatnot are installed. It’s the only black thing there in a sea of orange right now...
Originally Posted by sprint_9 View Post
Shaping up nicely.
Thanks, I’ve been looking at yours and stealing ideas
-Chris
Old 03-04-2019, 01:17 AM   #1833
gringoloco
A guy with a truck
gringoloco's Avatar
Finally tore into the packaging of these beauties today and promptly set to tearing them apart and scrubbing them with 220 grit sandpaper. Why would a seemingly sane person do this to a $700 set of billet hood hinges, you ask? Why to paint them black to make them look more like stock, of course
I squirted the hood hinges (and the ICT billet engine accessory brackets) in my favorite shade of satin black. Hopefully tomorrow they are cured enough to reassemble...
-Chris
Old 03-04-2019, 10:59 AM   #1834
cornerstone
cornerstone's Avatar
Understated beauty. No flash, all business, LOVE IT
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-04-2019, 04:10 PM   #1835
rustytruck50
rustytruck50's Avatar
Great job on the retro & simple look on the engine...just goes to show you dont need copious amounts of billet & chrome!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 03-05-2019, 01:49 AM   #1836
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, and hope you guys like the finished look of the hood hinges as much as I do. I think they should have come this way:
-Chris
Old 03-05-2019, 01:50 AM   #1837
gringoloco
A guy with a truck
gringoloco's Avatar
I also installed the painted accessory brackets and came to the conclusion that I will need to paint those shiny bolt heads black, too
-Chris
Old 03-05-2019, 10:37 AM   #1838
aggie91
I'm just glad to be here!
aggie91's Avatar
The hood hinges turned out very nice!
paint that rusty damper bolt too...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-05-2019, 10:46 AM   #1839
darkhorse970
darkhorse970's Avatar
I love the overall theme! I feel the same way about scuffing brand new billet parts for satin paint, it just fits...bet it makes some folks skin crawl though!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 03-05-2019, 10:48 AM   #1840
knomadd
knomadd's Avatar
Nice work! I have to wonder why you did all that work though, aren't those hinges offered in black powder coat? Mine did, but I have the Eddie Motor Sports hinges. Either way, it looks good, and the engine is turning out nicely!
-Duane
Old 03-05-2019, 11:09 AM   #1841
TA_C10
TA_C10's Avatar
Curious, how did you mask the holes off so the paint made it into the surrounding hole, but not hit the silver bearings? They look great btw
Work Work Work, all day long, work work work while i sing this song..... Gonna paint these bolts, no more shine, gonna take off the spray paint with turpentine..... Sorry, old school sandler and spade CD's reminder for me.... Building purdy means HARD WORK! Looking great man.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-05-2019, 11:20 AM   #1842
smbrouss70
smbrouss70's Avatar
I'm Lovin' It!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-05-2019, 03:17 PM   #1843
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! That bolt is the old one, used to press the balancer back on after the cam swap. It will be replaced with a new stretch bolt that is shiny and silver (and will probably get painted black, too).
Thanks buddy, I just hate polishing
All-American offers these anodized black, with machined silver edges. I likely could have had them done in all black, but it was a $150 up charge and I’m cheap I was re-thinking that savings part-way through this project, though...
Very nice, love me some old-school Sandler! Though saying it that way makes me feel old
For the masking part, I used no tape, mostly stuff I had laying around. Pictured below are some of the tools; the washers fit perfectly in the bearing-face holes, held by the counter-sink screw and nut which fit perfectly in the backside of the bearings. All other threaded holes had bolts installed, or 3/8-16 j-hooks which were used to suspend the parts while spraying.
I'm Lovin' It!
It’s like a McDonalds commercial
-Chris
Old 03-05-2019, 03:33 PM   #1844
rustytruck50
Chris, the black finish on the hinges is just what the doctor ordered
-Doug
'05 RCSB Sierra 2WD
Old 03-06-2019, 10:53 AM   #1845
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Hey Chris, were you cheap before OTS or just after??
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-06-2019, 11:29 AM   #1846
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the input; I’m very happy with how they turned out.
I’ve always been a cheap-a$$, but now I can afford better parts
-Chris
Old 03-06-2019, 12:00 PM   #1847
SCOTI
SCOTI's Avatar
While I like the minimal bling effort, I feel painting the bolt heads creates areas for future failure. Plated bolts are fine (quality plated) & you don't have the chipping/peeling issues if something requires adjustment. Food for thought.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2019, 08:36 PM   #1848
gringoloco
A guy with a truck
gringoloco's Avatar
Sage advice, as always, Scot. Maybe I’ll find some black oxide replacements
-Chris
Old 03-07-2019, 12:21 PM   #1849
SCOTI
SCOTI's Avatar
Good idea but be warned..... most I've used are of poor quality & rust easily. I used the Black ARP header fasteners on my dually. 1st time I rinsed the engine compartment down they were rusty within days. I wound up only using their studs & after buzzing the surface rust off, painted them w/engine high-heat paint. I swapped all the remaining hardware for SS. I had higher expectations given ARP was the source especially given the cost as there were more cost effective alternatives.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2019, 06:59 PM   #1850
gringoloco
A guy with a truck
gringoloco's Avatar
Well, my boat is full of holes and sinking
-Chris
