Old 03-08-2019, 10:03 AM   #1851
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: How to: Ruin a perfectly good C10
You could always get a small brush to paint them once they are installed and tight. If you ever need to remove them, then you would have to touch up the paint...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-08-2019, 10:59 AM   #1852
smbrouss70
smbrouss70's Avatar
Karl is right, you know. There's a reason that I have a couple of bottles of black finger nail polish in my tool cart. And no, not to touch up my finger nails, they get black enough on their own.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-08-2019, 11:15 AM   #1853
SCOTI
SCOTI's Avatar
Agreed. Excellent ideas.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2019, 02:43 PM   #1854
gringoloco
A guy with a truck
gringoloco's Avatar
This is kinda what I was thinking, using my favorite brand of semi-gloss nail polish:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-08-2019, 03:23 PM   #1855
knomadd
knomadd's Avatar
I agree with Scoti. I've painted my fair share of bolts and all of them have chipped or peeled at some point. Most have failed very quickly (days or weeks). Plated bolts may work, but the black oxide I've seen hasn't been black for more than a few months. They rust.
The touch up paint idea is a good one, but if it stands out like a sore thumb in polished form, it will be easily spotted if it's touched up too. Just keep that in mind. This is exactly why I try to leave all of my bolts raw (stainless), unless they will rust (steel).
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-08-2019, 03:57 PM   #1856
smbrouss70
smbrouss70's Avatar
Powder coat is more durable than paint, but it doesn't pay off unless you have a DIY setup at your digs.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-09-2019, 10:34 PM   #1857
gringoloco
A guy with a truck
gringoloco's Avatar
With the engine somewhat complete, I decided it was time to get it ready to stab. First up, pull it off the engine stand where it’s been for months and swap the flex plate for a flywheel.
This setup is super simple and straightforward, using a PRW part# 1634680 which is drilled for both LS and big block clutches. Since I’m using an old Muncie (for now?), I’ll use the early style disc with 10-splines. Also installed an LS7 style pilot bearing, which thanks to GM’s consistency throughout the years, fits the old Muncie pilot shaft perfectly.
-Chris
Old 03-09-2019, 11:08 PM   #1858
gringoloco
A guy with a truck
gringoloco's Avatar
...and then stalled at the point of having the engine mounts in place. I had assumed that the bell housing would bolt up no problem. Silly me. It hits the rear cover bolts, so I’ll either be grinding on it a bit, or ordering a new one. Oh well, the engine looks good sitting there being held up by the picker and a jack...
-Chris
Old 03-09-2019, 11:43 PM   #1859
sprint_9
sprint_9's Avatar
Originally Posted by gringoloco View Post
Thanks, I’ve been looking at yours and stealing ideas
steal away, and ask questions if you have any.
Im excited to watch yours come together, engine looks good.
sprint_9 is offline   Reply With Quote
Old 03-10-2019, 04:32 PM   #1860
knomadd
knomadd's Avatar
Ooooo.... I remember that point, like it was last week... Looks good brother!
-Duane
Old 03-11-2019, 09:09 PM   #1861
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
Everything looks great, Chris!
Just MHO, but have used the VHT Black Epoxy spray paint and it does a very good job. Especially, if you give it a little bake in the grille!
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
www.louisianaclassictruckclub.com
65StreetCruiser is offline   Reply With Quote
Old 03-12-2019, 10:36 AM   #1862
SCOTI
SCOTI's Avatar
VHT's rattle can Epoxy does work nicely & is very close to the 'old school' Krylon as far as sheen & appearance when applied. But, it's not very forgiving if you don't follow their application time window.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2019, 02:12 PM   #1863
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks man, chip, chip, chip...
Ready to be where you are already!
Thanks bud. Hopefully you guys can see it in person sometime this summer.
I do like the vht epoxy, specifically the satin version
Truth. Some of my favorite LAPS rattle can, though
-Chris
Old 03-13-2019, 09:42 PM   #1864
65StreetCruiser
It Is What It Is
Looking forward to it, Chris! Anytime we can get together is a good time!!!!
Kevin
Old 03-13-2019, 10:44 PM   #1865
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Y'all have any idea about your next assignment?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-13-2019, 10:59 PM   #1866
gringoloco
A guy with a truck
gringoloco's Avatar
For sure, looking forward to it
Well, we thought we were headed to TX, but it looks like we’ve now been diverted back to LA. Should be back in the south sometime in May, which means I have to get this heap assembled enough to put on a trailer, and fast
-Chris
Old 03-13-2019, 11:46 PM   #1867
smbrouss70
smbrouss70's Avatar
Back to Shreveport? Oh, the damage we can do being a short 3 hour drive away!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-14-2019, 11:55 PM   #1868
gringoloco
A guy with a truck
gringoloco's Avatar
Bossier this time, but close enough. Watch out world!
-Chris
Old 03-15-2019, 09:22 AM   #1869
knomadd
knomadd's Avatar
You need to make a trip to Lone Star Thorwdown (LST) next year, when it's finished. It's out here just north of Houston in February.
-Duane
Old 03-15-2019, 09:30 AM   #1870
gringoloco
A guy with a truck
gringoloco's Avatar
I am straight-up stoked about these
Rick’s custom upholstery is rocking it. It’s awesome to see something that came from my brain, then onto piece of paper, turn into reality. They are also working on a dash pad and visors to match
-Chris
Old 03-15-2019, 10:21 AM   #1871
smbrouss70
smbrouss70's Avatar
Very nice!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-15-2019, 10:41 AM   #1872
Kronald_70GMC
Kronald_70GMC's Avatar
Damn! Them some fine looking pieces you got there. Good work!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is online now   Reply With Quote
Old 03-15-2019, 12:30 PM   #1873
C10_ustacould
That interior is going to be outstanding! Nice job
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-15-2019, 01:28 PM   #1874
TA_C10
TA_C10's Avatar
Sweet! Those look great and will compliment your truck nicely.
I want to upgrade all my stuff now.... It's hard to resist the urges, heck my stage 1 build is already more like a stage 1 and 2 combined.....
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-15-2019, 02:50 PM   #1875
SCOTI
SCOTI's Avatar
Blue Houndstooth? What's the color/info on the other material? I'm on the hunt for retro (appearance & color) blue material that doesn't break the back.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
