04-30-2012, 12:06 PM | #176 |
chevy only
Re: Your 60-66 bagged projects?
No i wanted it, it was a buddy of mine jeff s
CHEVY ONLY... Nothin Else ! |
06-19-2013, 09:30 PM | #177 |
Wishbone suspension out back all custom built in my home garage. Z'ed the front end three inches with belltech lowering springs for now, I'm gonna drive it like it is for the rest of the summer then bag the front in the winter. I still need to figure out how the make the steering work when I put the bags up front. Any suggestions.
Posted via Mobile Device |
06-19-2013, 11:52 PM | #178 |
What I got from a fellow board member:
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-04-2013, 09:17 AM | #179 | |
Stovebolt-It is painted |
01-08-2014, 02:57 PM | #180 |
01-08-2014, 05:33 PM | #181 |
Even a ratty one ton dually...
May your life be like a roll of toilet paper... Long and useful or short and crappy!!! http://67-72chevytrucks.com/vboard/s...d.php?t=584520 |
12-03-2014, 11:33 AM | #182 |
Here's my 60 project. Fatman hub to hub with shockwaves up front and ridetech cool ride in the back. Its a work in progress but getting there!
12-03-2014, 12:49 PM | #183 |
65 swb with s10 chassis and drivetrain, custom front control arms, most of an ART air bar kit in back, EDC, old MIC manual valves, 22" B.A.D. billets
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-04-2014, 12:18 AM | #184 |
My '65.
12-04-2014, 08:17 AM | #185 |
Here is mine factory x member shortened pancaked and lca mounts moved up 2 inches.
12-04-2014, 08:22 AM | #186 |
Here is a shot of the back sorta hard to see.
12-04-2014, 08:23 AM | #187 |
And here is how it sits now front and rear suspension done wiring for engine done now some fuel system and brake lines
12-04-2014, 09:03 AM | #188 |
This is not a bad idea for changing the rear tires if they ever go flat. I had to lift my bed off with my engine lift just to get my rear rims on. I pray I don't get a flat very soon..
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
12-04-2014, 10:03 AM | #189 |
Here is mine latest project.. Its almost finished now.....
12-04-2014, 01:59 PM | #190 | |
I had to do it, the two sets of rear tires I have are both over 30" tall and are 285s, there was no way to get enough droop out of the suspension to get them on and off, I had to take the bed off with my daughter. I will eventually mechanize the tilt, right now it is manual but the air tank is right there, a properly placed air bag and a manual valve and some kind of latch for the front and it will open on its own. blue truck looks great! definitely the style that you wont have any trouble moving!
12-04-2014, 10:39 PM | #191 |
Thanks!!
I just hope and pray it gets sold before I get a flat tire.. Lol Maybe I should make all the bed connections weather pack connectors in case the bed has to come off again to change a tire...
08-18-2015, 07:08 PM | #192 |
ill bring this thread back to life,
heres my 61
1961 c10 longbed - gone 1964 c10 swb |
09-21-2018, 05:54 PM | #193 |
Bringing this one back from the dead... Anyone have some they want to update it with?
09-22-2018, 08:28 AM | #194 |
It's Better With Nitro
