Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-18-2009, 01:42 PM   #176
sdailey
The Few, The Proud
sdailey's Avatar
Re: Project - '69 4x4 named "Patches"
Originally Posted by CUSTOM/10 View Post
Awesome build, I have a 72 swb 4x4 that's just about at the same stage as yours. It's been sitting for about a yr now, been collecting parts and have just gotten started on it again.
Do you know what tranfercase cross member you used. Did it come from a truck with a 205 or a 221, I'm mentioning this because there is a 1" difference in the amount of drop. The 205 member having more drop, so if you used a 221 cross member with a 205 TC you might have a problem with the trany hitting the cab floor. Just a heads up.
221 has 11"s of drop and the 205 has 12".
Gary
Thanks Gary. I've been watching your build as well.
Thanks for bringing up the point about the crossmember differences. I actually did drop the crossmember by 1" with some blocks that I had machined at a local shop. I even took pictures after I installed them to add to my build thread, but I forgot to add this tidbit of info. Thanks again for bring it up.
Shannon
sdailey is offline   Reply With Quote
Old 06-18-2009, 02:15 PM   #177
CUSTOM/10
CUSTOM/10's Avatar
That will take care of it !!!
Lot's easier to do it now, keep up the good work.
It's looking like My plans my change a little, have a chance at a deal on a vortec 383 imstead of the TBI 355. It will be worse on fuel, but more fun...
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-26-2009, 03:17 PM   #178
sdailey
The Few, The Proud
sdailey's Avatar
Slowly plugging away on the '69 still. I've been buying a few parts here and there. I recently bought a Wilwood master cylinder kit for my hydraulic clutch setup. I bought the kit from Summit for about $70.
I also bought a new 4-row radiator from Advanced Auto for $180. It's the heavy duty model for an ac/4x4 truck. It's built pretty soild for being made in Mexico.
Shannon
Old 07-26-2009, 03:23 PM   #179
sdailey
The Few, The Proud
sdailey's Avatar
One of the plans for my truck was to add an electric fan setup. So I did some searching on the board and looked a hundreds of threads about electric fans and I found a great write up by boardmember Shifty that seemed to meet my needs. I won't go throught the details of what I did, because you can look through Shifty's thread below and see the details. I basically copied his instructions and everything worked out perfectly.
Electric fan thread
http://67-72chevytrucks.com/vboard/s...d.php?t=216128
The parts I bought for my fan setup from Wes at Classic Hearbeat and Paul at GMCPauls were all top quality parts. This was also the first time I purchased anything from either one of these board vendors and the customer service was top notch from both. I'll be sending them more business in the future.
Powdercoated shroud from GMCPauls
Flex-a-lite fans from Classic Heartbeat
Fans mounted to shroud. Real clean look so far.
Shroud mounted to radiator
Then I mounted the complete setup to the core support for a photo shoot.
I'll be adding a serpentine setup to the motor as well when the budget allows. Once I get that installed I can test fire the 350 finally. The addition of the serpentine kit along the electric fans should the give the engine compartment a clean uncluttered look. Stay tuned for future updates.
Shannon
Old 07-26-2009, 09:38 PM   #180
msgross
msgross's Avatar
nice.. I have the same radiator..
I was wondering if you were suppose to cut those bands off it or not.. looks like it needs a little touch of spray paint now..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-27-2009, 11:15 AM   #181
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Mike. It's no cab floor replacement, but it's progress.
Yes I'll have to go back and spray a little touch up paint over the banded area of the radiator.
Shannon
Old 07-27-2009, 11:30 AM   #182
Rack Man
Wow...That fan set up looks awesome...Your build is coming along nicely!
I also got that same radiator...I didn't realize that those bands come off either....Are they only for shipping?...I've seen others installed with them left on as well?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-27-2009, 11:37 AM   #183
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Dan. Little by little and it'll get there one day. That's what I keep telling myself anyway. I can always look at your and msgross's build's to help keep me motivated though.
As far as the banding goes, I've always been told to cut them off. I don't guess it hurts anything either way though.
Shannon
Old 07-27-2009, 11:58 AM   #184
Rack Man
Curiousity got the better of me and I called the place where I bought mine and they told me that the straps really need to stay on....that they help with the expansion of the radiator....they also told me that It would void the warranty as they would consider it a "modification"....They even sell "Expansion Tank Strap Kits".....may all be BS but thats the story I got!
Old 07-27-2009, 02:44 PM   #185
sdailey
The Few, The Proud
sdailey's Avatar
Oh great. Thanks Dan. That's all I need to hear. You got my curiousity up as well so I called Advanced and they (manager & assistant manager) had different opinions as well. One said cut them and the other said "I think you're supposed to leave them on, but I'm not sure." I asked about the warranty and they said that it wouldn't matter. Who knows.
One step forward, 2 steps back.
Shannon
Old 07-27-2009, 09:05 PM   #186
msgross
msgross's Avatar
well, it's made in mexico so maybe that bands keep it from falling apart...
as for the autozone/advanced counter guys... no friggin way am I taking advice from those guys!
The Garage:
Old 07-27-2009, 10:11 PM   #187
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Even if you had a warranty claim, they won't even pay attention to the bands. That requires thought and if it's not in the computer they won't know to check or ask.
Alan's Classic is offline   Reply With Quote
Old 07-29-2009, 09:41 AM   #188
sdailey
The Few, The Proud
sdailey's Avatar
I guess I should go tighten down the radiator clamps a little more in case it falls part.
I agree 100% about not taking advice from their employees.
Sad but so true.
Shannon
Old 07-29-2009, 01:17 PM   #189
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
that is going to be a nice rig when your finished.
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-29-2009, 01:27 PM   #190
sdailey
The Few, The Proud
sdailey's Avatar
Thank you Sir.
Shannon
Old 08-01-2009, 10:24 AM   #191
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
lookin good sdailey... Its going to be so worth it in the end! AWESOME job..
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 08-01-2009, 11:06 AM   #192
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Taylor. That's what I try to keep telling myself.
Shannon
Old 08-02-2009, 06:18 PM   #193
crimespree
crimespree's Avatar
yep, thats about where it was the other day. i got my truck running and back to the house. now its going to be time to sand and prime that hood. thanks again for that. i will be checking back to see how its going.
1970 CST - http://67-72chevytrucks.com/vboard/s...d.php?t=350091
1979 Yamaha xs650 bobber - sold
2008 Harley Nightster
crimespree is offline   Reply With Quote
Old 08-05-2009, 09:06 PM   #194
sdailey
The Few, The Proud
sdailey's Avatar
Well Christmas came early this year......
The UPS man delivered this 82# box today. I'm sure he said some choice words when he was walking up the steps on my porch to deliver it today.
Care to take a guess what's inside?
My new GM serpentine kit
One step closer to firing it up for the first time. I had a busy afternoon so I'll have to wait until later this week before I can install it.
On a side note, I've been shopping around for the best price for this kit for a while now and I finally found the best price at www.paceperformance.com
I don't know how everyone else is but once I know I'm buying something for my truck I'll go to the website or catalog and look at it a hundred times until the budget allows me to buy it. Then I start drooling over the next part on my list and so on. Well last week I was looking at this kit again on various sites like Summit, Jegs and Pace and to my surprise Pace had it on sale for a little over $70 cheaper than any other retailer, so I went ahead and bought it from them before the sale expired. For those interested GM's part number is 12497698.
Shannon
Old 08-05-2009, 09:13 PM   #195
msgross
msgross's Avatar
I just had two boxes weighing 175# total delivered. We were on vacation and the neighbor made the UPS guy come back over to the house and put it on the back porch since it was about to rain!!!! great neighbors and UPS guy, even if he wasn't happy.. He told her "those are heavy though!"
The Garage:
Old 08-05-2009, 09:29 PM   #196
Alan's Classic
Our UPS guy should be in great shape Huh. Parts lookin good.
Old 08-06-2009, 07:26 AM   #197
sdailey
The Few, The Proud
sdailey's Avatar
It's nice having good neighbors, isn't it.
Yeah, he should be.
Shannon
Old 08-09-2009, 08:52 PM   #198
sdailey
The Few, The Proud
sdailey's Avatar
I got around to installing the serpentine kit this afternoon. The instructions were sketchy at best, but with the help of Alan we got it installed with only one minor hiccup (see 3rd pic below).
On a side note I was able to mount this kit on my crate motor even though the passenger side head doesn't have (3) accessory holes, but the driver's side does. The kit comes with (2) braces. One helps support the alternator/ps steering bracket on the driver's side and the other supports the main bracket that the ac compressor mounts to.
Here's the only problem for the day.....a faulty water pump pulley bolt. Many thanks to Alan for taking the torque wrench out of my hand at this point "preventing" further damage from happening.
Slowly getting there. Thanks for checking in.
Shannon
Old 08-09-2009, 09:24 PM   #199
Alan's Classic
Yep looked like Capt. destruto was coming out pretty quick.
Old 08-09-2009, 09:35 PM   #200
Old School Kid
Let me know when your going to fire it up, it will be a momentuous occasion!
Looks great!!
My 65 (SOLD)
My 51 (SOLD)
