06-15-2011, 10:21 AM | #176 |
Re: Post Your Straight Six Pics!
The p/s belt arrangement in that pic is similar to mine, except I don't have a/c and the 2nd belt goes around the alternator, balancer, and water pump. I have run it that way since last fall with no issues.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-15-2011, 12:16 PM | #177 |
I don't see a problem with the setup. 3 pulleys joined around the common pulleys on the harmonic balancer, all the same circumference = same speed. Ya you get the glancing touch of unrelated components belts but they are moving at the same rate of speed. Thats a busy engine compartment.
06-15-2011, 01:17 PM | #178 | |
'69 Fleet It ain't yours, if you didn't build it! Last edited by Dano69c10; 06-15-2011 at 01:20 PM. |
06-16-2011, 05:10 AM | #179 | |
The glass ones like in the pic have another issue: the plastic filter medium is affected by the ethanol/alcohol additives present in most commercial gas. It swells -- causing a restriction. So I prefer a steel can with a paper filter medium. I use about the same placement as you have, but my fuel filter is about 4" higher than the manifold and stays cool enough there.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-17-2011 at 01:21 AM. Reason: typo |
06-16-2011, 06:15 AM | #180 |
Yep! I'm pretty handy with the ole spray bomb! Thanks. And what I did was scrub the thing down three times. Twice with purple power, and once with simple green. Took it all apart, at least down to the basic engine. plug all the holes and then blasted it with brake parts cleaner to remove any leftover oil or grease. Sanded it with some 400 grit sandpaper and then wiped that off with a clean rag and laquer thinner. Then primed, painted, and clear coated with Duplicolor engine enamels. Oh! Lol! Don't forget to tape off, and cover with paper your firewall and inner fenders, and anything else you don't want to get overspray on before you paint! Yes, I even taped off my oil filter and starter. Then, clean and paint your other things brackets, pulleys, fan, and whatever else you want seperately. As far as tips, I used a foam nerf ball cut and used as corks for different holes. And take your time! Well that's how, now let's see your outcome!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
06-16-2011, 06:29 AM | #181 | ||
06-16-2011, 11:00 AM | #182 |
Slick, when I do get around to it I will post picks. Again nice choice for color and a very nice job!
06-17-2011, 01:29 AM | #183 |
Slick -- the FRAM GF-11 is a simple steel canister type fuel filter, 1-7/8" diameter x 4" long, with 3/8ths barbed ends for fuel hose connection. Should be easy to find at any autoparts store. Not married to the Fram line, anymore either. I used to buy them when they were USA made. I found no drop in quality when they started being made in Israel, but now the new ones are made in China, and I will be looking for a different brand. Next time I change fuel filters, in about 10,000 miles.
06-17-2011, 05:15 AM | #184 | ||
06-17-2011, 11:03 AM | #185 |
If the lines have been replaced and the tank has been thoroughly cleaned or replaced, you should be good with the 2 filters you already have.
06-18-2011, 05:03 AM | #186 | |
Jegs and Summit have a selection of racing high flow fuel filters, billet milled body and replaceable element. May be what you're looking for.
06-18-2011, 11:17 PM | #187 |
Thanks guys! I'll let you know what I wind up doing!
07-29-2011, 05:48 AM | #188 |
Hey guys! Wanted to know if anyone has a pic of a 69 up 250 with th350 kickdown cable hookup. Mine's been cutoff and trying to find a cable that'll work and where to hook it up on the throttle linkage. Any input or pics would be very helpful. Wanted to stary here for you straight six guru's! Here's a couple pics of my setup.......
07-29-2011, 11:09 AM | #189 |
OK, Perfect place for this! Has anyine ever considered a late-model GM 4.2L, Atlas LL8, straight-six swap into our trucks? it seems like the natural step into the modern straight-six world. yeah, yeah, V-8 cheaper, V-8 better, LS1-this, LS2-that, blah, blah, blah.... Some of us actually like the sixes. I have no pictures to post of my 250 in my 68, but it has the super cool 6-into-2 header on it, which makes it sound like a Hi-Po small-black at idle. I also have a 250 out of a 66 GMC which will be my builder for my truck. Why be a sheeple with a V-8?
1968 C-10 Longbed, 6-cyl., 4-speed. 832-584-1245 "You see, in this world there's two kinds of people, my friend, those with loaded guns and those who dig." |
07-29-2011, 11:11 AM | #190 |
@Chevy_Brazil: Righteous!
07-30-2011, 04:14 AM | #191 | |
I'm just bummed GM didn't make a 4800 L6 [292].
07-30-2011, 01:52 PM | #192 |
68OrangeSunsghine, I fully agree! That is why I bought my 68 and am still running the points distributor. I think the L6 4200 would be a pretty cool swap, to see someone else do. I'm just tired of the same old six-bashing some guys do. There is a guy that comes out to our cruise night with a beautiful 64 Chevy 2-door post, with a nice 6 in it. When I talked to him about the 6 he didn;t have anything nice to say, I was a little sad, but it's his car let him mess it up if he wants to.
Viva La Six!!!!
08-11-2011, 11:07 AM | #193 |
Recent photo of 71
08-11-2011, 07:42 PM | #194 |
Tot Roddin'
Nice work Nathans71!
I've been working on just regular maintenance items: Pushrod panel gasket replacement Valve cover gasket replacement Radiator/Heater hoses Etc.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-12-2011, 06:22 AM | #195 |
Nice! I like the original look with the air cleaner setup. Keeping it that way I guess?
08-12-2011, 07:49 AM | #196 | |
67-72 parts collector,…
http://67-72chevytrucks.com/vboard/s...d.php?t=478750
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-12-2011 at 08:00 AM. |
08-12-2011, 11:08 AM | #197 |
My son requested the six remain in the truck and that we restore it close to original. Just cleaned up wiring, went to HEI, Power brakes and steering. Truck now has factory gauges, and plumbed with the copper tubing.
08-12-2011, 10:07 PM | #198 |
Blank Slate is sweet. Has a 68 short fleet that same color. Dated my wife in it 24 years ago. We traded it for a 86 Grand National in 88. Good times.
08-13-2011, 09:49 PM | #199 | |
Tot Roddin'
The color is not everyones first choice, but I love it.
08-13-2011, 10:49 PM | #200 |
Tot Roddin'
What paint did you guys use?
