#176 |
Registered Loser
Re: What did you do to your truck today?
The Holley 500 is an easy swap. If I can do it anyone can. You will need to get an adapter to bolt it in. I'll try to post some pics a little later.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#177 |
Registered Loser
#178 |
Pulled the beds off the trailer flipped them over on a pallet and collected the money for one of them. Put them away and sprayed the bolts with rust penetrating stuff so I can pull the planks off later this week.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#179 |
One day...
Got the fuel pump changed, put new drive line in and fired up my 92 Xcab
#180 |
rearranged some of the pins on my engine harness and hooked the battery up to see if I could get her to turn. She turns over nicely. I need to get some new head lights and bulbs so I can check to make sure everything works.
#181 |
Layed upder it for a while. Tried to figure out other ways to shorten the frame. Think I got carried away because the new plans are chopping it off behind the cab and fabbing up a new backhalf with C notches and bags.
#182 |
1 thing at a time is progress.
Dreamed it was done.
Alan
Philippians 2:14-16 |
#183 |
#184 |
Almost started my Sons 64 on fire today. Was starting it and it back fired and flames were shooting out the carb. Need to fine tune the Timing. Looks like that will be tomorrows job.
JRBECK64 |
#185 |
well. i washed her up today and i found a great spot by my house to take pictures so i capitalized on the photo op i think i did a good job for a rookie photographer!
go to my album i have 70+ pics http://s49.photobucket.com/albums/f2...CHEVY%20TRUCK/
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield ![]() .......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS..... ![]() ![]() Last edited by 63deluxfleet; 11-10-2009 at 10:43 PM. |
#186 |
Nice work Isaac. I'm really liking the 63 cab look. The knee knockers scared me away.
Lookin good.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#187 |
One day...
Cool pics 63deluxfleet! i like this one the best
#188 |
Rebuilt Carb
Took it for a test drive Cussed at it as it coasted though my driveway as it wont start again.... ![]() |
#189 |
HOW long until spring??
![]() Join Date: Mar 2009
Mounted the transmission cooler and cooler lines. Then tried to make the kick-down cable reach and wished I could get it connected to the existing carb on the Inline six... Anybody have a turbo 350 behind a six cylinder and stock one barrel carb???
PLEASE send me a PM with how you hooked up the detent kick-down cable!!
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#190 |
![]() Join Date: Aug 2008
Completed my carb linkage, put my driveshaft together and started it up- just to hear it run.
#191 | |
The Beach Cruiser
1999 Silverado DD ![]() 1966 Panel Truck 2003 Harley Road Glide ![]() 1967 Schwinn Tandem Single Speed |
#192 |
replaced accelerator pump and it started and got me to a job and back home, still runs bad...bypass fuel pump with electric fuel pump to make sure it was not the problem....IT wasn't
AZ Chev Man ![]() 1st Ride 1958 Chevy Apache 2nd 1972 C10 1968 Chevy P10 Step Van '01 Blazer, '03 Astro |
#193 |
James
I put a new starter in today. I'm alittle scared though. I might have torqued the bolts just a little too much. So far it's workin great.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
#194 |
#195 |
Rods
![]() Join Date: Nov 2002
check for a vaccume leak.... try starting fluid rpms raise or wd40 rpms drop around the base of the carb and around the intake.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#196 |
Tx, did you get it installed? Any issues?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-13-2009 at 01:25 AM. |
#197 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I took an extra day to clean it up and paint it. I installed it yesterday. Today will finish hooking it all up, detail wiring and such.
#198 |
My ebay truck came in the middle of the night!
#199 |
Gee Virginia there is a SANTA CLAUSE!
http://s1299.photobucket.com/user/jb...23904108567829 |
#200 |
Hollister, CA.
![]() Join Date: Sep 2006
Went down to the DMV...and finally registered my truck....
The frickin 'Governator' took $226 of my hard earned money for that thing !! And the tag is only good untill FEB !! Man the lady at the counter real had a hard time...this truck came with the DMV paper all printed up from the guy. However the OG owner donated to charity, then this guy bought it (owns a lot), then I got it. So the pink was signed 3 times, we had 3 transfer forms....it had her going crazy !! Now, I just got it get it running !! So far...that little truck in my avatar has cost me $600 + $226 = $826 ![]() ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 11-13-2009 at 11:01 AM. |
