Old 07-21-2015, 10:56 PM   #176
6BT 56
6BT 56's Avatar
Re: 86 Silverado K20 12V CUMMINS Build
Hey Brian. How's your truck coming along ? I see you eyed up my latest truck . I also have another 1st gen dodge packed away . May make something like you are if my 6.2 turns out to need some unexpected repairs . What front springs , or lift kit did you get for your truck ?
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 07-22-2015, 05:20 AM   #177
lower50's
lower50's's Avatar
Very cool. Great job so far I see you cut the muffler off are you leaving it strait pipe? Also how do you like the sound deadening products you used? Keep up the good work.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-22-2015, 09:13 PM   #178
brimc
brimc's Avatar
Truck going slow. Little by little. I have to upload some pics and put up some updates real soon.
Sure wish I could stash away some trucks for future projects. Having a hard enough time with one truck lol.
I used Rough Country 4" all springs. Ordered out of a place in BC and had it shipped to the door. I would think there is a better way. It was like $800.
Maybe you can run the new truck at the fair in 2 months.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 07-22-2015, 09:21 PM   #179
brimc
brimc's Avatar
Thanks.
The truck will have a dynomax performance muffler. I have run this on this engine for many years and have got two free ones because they have a lifetime warrentee. (Rust) There is no drone, sound smooth and the turbo sounds awesome at the tailpipe.
I have more sound deadening to apply inside the cab and the rest of the body. So far they apply really good but time will tell as far as actually using it driving down the road.
BRIAN
Old 08-02-2015, 02:07 PM   #180
brimc
brimc's Avatar
So I got the box done. Came out better then the cab.
On to the next job...
BRIAN
Old 08-02-2015, 03:21 PM   #181
6BT 56
6BT 56's Avatar
I sure hope you like it cuz ur committed now ! That will put a new meaning to durable finish . I'd take it to a detailing shop when ur up,and rolling. Tell them you just bought it and you would like to see if it will buff up ! Lol......
How did you ever make out with the divorced tc deal ?
Old 08-02-2015, 03:52 PM   #182
brimc
brimc's Avatar
Lol committed. No kidding!
Don't think anybody wil be stripping and rebuilding this body in another 30 years
I'm still not sure or committed to the system I am going to go for the four wheel drive. I'm seriously considering putting a drivers side drop front axle and putting a real transmission and transfer case in. Just not sure yet.
BRIAN
Old 08-03-2015, 08:53 PM   #183
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on the bed!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-10-2016, 12:51 PM   #184
Zach079xxx
Zach079xxx's Avatar
Updates PLEASE. Just found and read through this entire thread.. Jelly, I am super jelly!
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 04-10-2016, 09:22 PM   #185
6BT 56
6BT 56's Avatar
Ya I'd like to know what's up too. Not too often in the web world that you actually find somthing cool going on and it's only a little ways away . And the truck lived up my way before you . That makes it a neat read aswell.
Old 05-22-2016, 07:00 PM   #186
brimc
brimc's Avatar
Thanks. Updates coming. Problem is you need progress before updates
I too look forward to reading updates especially when they are close by or at least Canadian. But I look forward to everyone's updates. This is the best place on the Internet for what we all do.
BRIAN
Old 05-22-2016, 08:49 PM   #187
brimc
brimc's Avatar
Well I got my old school fuel shutdown cable fabbed up and installed. It works too. Drilled a hole and mounted it below the headlight switch. Pushed in for "run"
Drilled a hole in the firewall and mounted with a rubber gromet.
Fabbed up a little holder bracket "run" position
"shutdown" position
I also got the fuel lines and sender finished up and dumped in 5 gal of good old $0.85 Diesel Fuel. What a big difference, seems like not that long ago it was $1.43. This weekend I was able to "drive" the truck in and out of the garage under it's own power. Able to start it up, shut it down and run it. Clutch and shifting seem fine so far. Was nice to get it out in the sun for awhile too.
Got the exhaust completely finished also. DynaMAX performance muffler and tail pipe. Very solid with 4 rubber mounts.
Decided on a 1.5 inch body lift. The box is completely bolted down with new hardware. Will need to take and upload more pictures........
BRIAN
Old 05-22-2016, 09:37 PM   #188
COS399
COS399's Avatar
Nice work. Should be back together in no time.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-23-2016, 07:57 AM   #189
6BT 56
6BT 56's Avatar
Looks good . Always gets you motivated once they start to look like trucks again. What did you end up using for a transfercase ?
Old 05-23-2016, 08:42 PM   #190
Dieselwrencher
Nice work! It looks great out doors too!
Ryan
Old 05-24-2016, 08:24 AM   #191
lower50's
lower50's's Avatar
Now thats some good progress. SO cool when it moves under it's own power congrats!! My friend has a '85 Toyota Land cruiser and has used your cable shut down method for years. Great for anti theft as well.
1951 MG TD
Old 07-11-2016, 08:45 AM   #192
brimc
brimc's Avatar
"Christmas in July"
Just picked it up after 3 years of searching. Think I found the right one. Mid 70's IH remote mount 32 spline np205.
BRIAN
Old 07-11-2016, 09:55 AM   #193
6BT 56
6BT 56's Avatar
Just what the doctor ordered . Lol. You don't trip over those everyday. Where did you find it? Kijji to the rescue ?
Old 07-11-2016, 10:18 AM   #194
brimc
brimc's Avatar
Yup. Kijiji. Was hiding in a backyard shop way down in port credit. Time to get serious. So far inspection has shown up no surprises. I don't think it was shifted much. Clean inside and shift rails don't seem to have any indent ball wear. I will know for sure after a full tear down and refresh. Also does not look like it was ever taken apart. The price I paid there is money left over for new paint and a rebuild kit no problem.
BRIAN
Old 07-11-2016, 09:00 PM   #195
Dieselwrencher
Nice sore on the tcase!
Ryan
Old 07-11-2016, 11:22 PM   #196
lower50's
lower50's's Avatar
Nice that old stuff is hard to find up here.
1951 MG TD
Old 07-12-2016, 10:21 AM   #197
brimc
brimc's Avatar
Thanks guys. Yes good score and very hard time find good stuff and rust free stuff around here.
Got it cleaned up some. Gotta look online for a rebuild kit and some new yokes? Any advise on that without paying a fortune in shipping?
BRIAN
Old 09-05-2016, 07:04 PM   #198
brimc
brimc's Avatar
HELP
I trying to source yokes for my transfercase. New ones are $$. I want to run the 1410. Does anyone know if all 89-93 cummins np205 regardless of input shaft all run 32 spline front and rear outputs? I'm likely better off buying another transfer case from behind an automatic as long as the yokes are good. I also would possibly get the driveshafts and be able to lengthen or shorten as needed. This way I would buy a new yoke for my 14bolt, it needs one regardless of the size and another for the input of the 205 for the intermediate shaft. The ones that are on the case are the small ones. Don't really think it is a good idea to go cheap in this area of the build.
Help, comments, suggestions would be greatly appreciated. Thx.
BRIAN
Old 09-12-2016, 06:46 PM   #199
Dieselwrencher
I think the 89-93 dodge 205s are 32 spline on the front too.
On edit, quad says they are. About 3/4s the way down the page
QU10935 Genuine NPG Balanced CV Flange is the USA made factory replacement for original square front output CV flange used in 1975½-1993 full size Dodge 4x4 trucks with the NP205 Transfer Case. Includes slinger. Order optional QU10806 Bolts to secure driveshaft. Will also fit any other NP205 32 spline fixed yoke shaft.
Please refer to QU10935 page for more details and ordering information.
http://www.quad4x4.com/New_Process_NP205_Parts.html
Ryan
Old 04-14-2018, 02:23 PM   #200
brimc
brimc's Avatar
Time for updates working on pictures......
BRIAN
