Old 12-31-2016, 05:05 PM   #176
solidaxel
solidaxel's Avatar
Re: Mike's 50
Originally Posted by MIKESAD50 View Post
Solidaxel, I did put a small amount of silicone on the tube fitting at transmission case, just above o-rings. It actually mentions it in the install directions.
................................... directions !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-31-2016, 11:30 PM   #177
MIKESAD50
Re: Mike's 50
I read them on occasion then I do what works best for me.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 12-31-2016, 11:32 PM   #178
MIKESAD50
Re: Mike's 50
Hotrodelrod, Thanks. I've been following your build and it is a cool build also.
1950 3100 5 window
Old 01-08-2017, 08:47 PM   #179
MIKESAD50
Re: Mike's 50
not much progress this weekend, pretty wet and cold( for the Bay Area) the last
week. Brought a door home and installed the weatherstrip. messed up and ruined the first time. 2nd attempt shown. Not happy, but hope the Drivers door will go better. have to order a new weatherstrip and will get a few other item when I order.
Yes, I'm doing the weatherstrip in the living room. no mess and Girlfriend ok with it, or at least didn't say anything.
1950 3100 5 window
Old 01-08-2017, 08:50 PM   #180
MIKESAD50
Re: Mike's 50
looks worse in pictures. its stuck though!
1950 3100 5 window
Old 01-08-2017, 09:21 PM   #181
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Mike's 50
Looks great from where I'm sitting!
--Josh
Old 01-08-2017, 09:23 PM   #182
HULK64
Re: Mike's 50
Tell us what you learned about doing it right the second time around?
HULK64 is offline   Reply With Quote
Old 01-08-2017, 09:54 PM   #183
Advanced Design
Advanced Design's Avatar
Re: Mike's 50
I think it's very cool working on the door in the living room.
Advanced Design is offline   Reply With Quote
Old 01-09-2017, 12:07 AM   #184
jweb
jweb's Avatar
Re: Mike's 50
I would install that door on the truck first. Make sure it shuts well, before doing the other door. Some people have had trouble with the standard door weatherstripping.
jweb is offline   Reply With Quote
Old 01-09-2017, 07:37 PM   #185
MIKESAD50
Re: Mike's 50
Jweb, I was thinking the same thing. A friend of mine is having problems with the same issue after installing seals.
I used Steele rubber products in hopes of avoiding some of these problems.
I have read about fitment issues with some of the "cheaper" seals not fitting well.
Have you heard of issues with the Steele rubber seals in particular?
I do have to wait about 5 days for a new seal from Steele, since I messed the other one up.
1950 3100 5 window
Old 01-09-2017, 08:42 PM   #186
jweb
jweb's Avatar
Re: Mike's 50
I had trouble with the Precision brand. I'm not sure about Steele.
I ended up using this https://www.metrommp.com/?f=detail&M...ET&Model=TRUCK
Old 01-10-2017, 09:55 AM   #187
reaper71
reaper71's Avatar
Re: Mike's 50
Another company I have used is SofSeal they are super nice!
Very soft and pliable and did not have any issues fitting.
Mark...
reaper71 is offline   Reply With Quote
Old 01-10-2017, 03:40 PM   #188
joedoh
joedoh's Avatar
Re: Mike's 50
I did my seals with the doors on the truck, it was a mother, especially because it was cold and the glue I had wouldnt set. this looks better haha
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-11-2017, 08:04 PM   #189
MIKESAD50
Re: Mike's 50
Joedoh,
No way I was going to do it after putting doors on again. If they never came off that is one thing.
That is why I brought them home. I dont have heat in the shops. Has been cool here. Will take back this week and fit the door and see how the weatherstrip affects the door.
1950 3100 5 window
Old 01-21-2017, 07:12 PM   #190
MIKESAD50
Re: Mike's 50
Well I put in a little time down at the shop. Mounted the passenger door. needs some adjustment, it does close and latch though.
Mounted the drivers mirror, I had already made up a lower radiator hose. I used vibrant performance products.
I started mounting the engine wiring harness and also drilled a hole in firewall recess to run throttle pedal, OBDII connector and ignition switch power for ECM. also shortened the drivers side O2 sensor wiring harness to clean up the harness install.
I still need to shorten the passenger side O2 sensor wiring. Need to run the B+ wire from alternator again.
Last thing I did was final trim and install an fitting on fuel supply to fuel rail, no picture of that.
I also brought the driver door home to install seal and other parts.
I bought another door seal. Also go the stainless lower door weather strip retainer, got a throttle and choke cable. I'm going to install in dash for the Original look and may try to incorporate a switch or something to make then functional for something, wipers, dash dimmer switch?
1950 3100 5 window
Old 01-21-2017, 07:17 PM   #191
MIKESAD50
Re: Mike's 50
I still have a bunch of work to the door, need to final trim and install window channel felt, doesn't fit well but hope to make it better with some adjustment.
Anyone used autocity classic glass?
1950 3100 5 window
Old 01-21-2017, 07:21 PM   #192
MIKESAD50
Re: Mike's 50
Running harness down back of motor, over top of transmission to under seat
1950 3100 5 window
Old 01-21-2017, 10:37 PM   #193
joedoh
joedoh's Avatar
Re: Mike's 50
sneaky wiring! looks great
dont adjust the door yet, let the seal sit closed a while, mine got easier.
Old 01-22-2017, 09:30 AM   #194
solidaxel
solidaxel's Avatar
Re: Mike's 50
What thermostat housing did you use?
LS 3 4L70E
Old 01-22-2017, 10:54 AM   #195
MIKESAD50
Re: Mike's 50
it is from Street & Performance but I guess they are out of business now.
1950 3100 5 window
Old 01-22-2017, 10:55 AM   #196
MIKESAD50
Re: Mike's 50
joedoh, I was trying to keep the wiring clean.
I didnt think of that letting the door rest. I will do that.
1950 3100 5 window
Old 01-22-2017, 11:04 AM   #197
donandal
Re: Mike's 50
I read this every update.
very nice!
You used a steele rubber gasket. Was it a real soft sponge
rubber or a stiffer material?
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 01-22-2017, 11:17 AM   #198
MIKESAD50
Re: Mike's 50
Donandal,
Thank you, not as nice as your awesome build, but will be good for me hopefully.
It is p/n: 70-0145-73, it is a sponge material. seems to fit well and is fairly soft
1950 3100 5 window
Old 01-22-2017, 05:08 PM   #199
donandal
Re: Mike's 50
Thanks for the info.
I sent for some samples from Steele Rubber.
That's another job I dread!
53 Chevy Pickup
Old 01-22-2017, 05:18 PM   #200
Dave_The_BMXER
Re: Mike's 50
Looks amazing so far!
Dave_The_BMXER is offline   Reply With Quote
