#176 |
![]() Join Date: Mar 2011
Re: I am from the Desert
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#177 |
double pulley installed no more belt noise
#178 |
Belts are about maxed-out on that adjuster bracket, eh?
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#179 |
good eye Shifty ...the belts come in one inch increments as far as I can find out this way and that does not give me enough room going the other way with the alternator on a aftermarket bracket cause of the headers and original 327 heads have no provisions for bolting up a bracket to the head! originally the bracket bolted to the exhaust manifold I have clocked the alternator also ...long winded answer but I have run out of options ...there is just a tad left to pull the belts tighter ...no need to at this point ....thanks for looking as always open for advice
#180 |
I had that same issue on my 55 Belair that had a nice set of fuelie heads....I ended up with two of those brackets, one on either side of the alternator ear.
What belt number are you currently running?
#181 |
please send me a picture of your set up ....
I was using the Napa belt shown and when I put the double pulley on I went to auto zone for two Duralast that were supposed to match ....
#182 |
Much to my dismay, I haven't had the Belair since the late 80's...
![]() Seems to me that you could use 15545's for a 1/2 shorter, or 15540 for a full inch. It's kind of old skool, but you can ask for a matched set, and hopefully you are dealing with an older counterman.
#183 | |
#184 |
Well, I am an old counterman (since 1983), so I get it.
I truly miss that ol' 55, wasn't the fastest, wasn't the best stopping or handling, didn't get great mileage, etc...but it was by far the best car I've ever owned.
#185 | |
God Bless
#186 |
Cheers!
#187 |
finally .....so never a short story paint shop didn't make enough paint to complete the entire truck ( gave them a entire disassembled truck) so when they made the new batch didn't match come to find out PPG discontinued a tint that was being used in the formula( body shop offered to paint the entire truck again I said no because of my time invested in reassembly etc. they agreed and turned up the heat on PPG, PPG rep came out got it 97% close only good in horse shoes and POLITICS ):body shop kept the pressure on PPG and then they ask us to send them a correct color part(step from stepside) to their Lab in Pittsburg so they could create a formula and do a spray out .........we have a match ....its tuff with pictures and this color looks more blue gray than blue in some light and a lot blue in the sun light .....so after weeks of the back and forth ....we have a match so back to assembly ..first get the bed wood prepped ....stay tuned
#188 |
no match back to shop for repaint
#189 |
starting on bed wood fed up with paint fiasco trucks in shop being repainted in is entirety
#190 |
satin................bottom side 24hr dry time another coat tomorrow
#191 |
What finish coat are you using on the wood?
#192 |
Really brings out the heavy graining!
#193 |
X2, looks great, don't forget to do the ends of boards, mine checked
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#194 |
McCloskey Man O War Marine Spar Varnish Satin ...I was going to use an automotive clear but talked myself into this after reading a lot on the subject....I think im going to like it
#195 |
[QUOTE=Shifty One;9268042]Really brings out
yes it has second coat made them look a little darker... now on to top side tomorrow
#196 |
got the ends Jim
#197 |
buffin...bedsides
#198 |
shifting gears again.... truck out of paint finally now putting it back together for the finale
#199 |
Coming along nicely!
#200 |
