Old 03-29-2016, 10:58 PM   #176
brian1971
brian1971's Avatar
Re: Volt Gauge Conversion Kits
Hi Tom,
Hope all is well it's been awhile since we last spoke.I'm getting ready to install a American autowire harness and seeing if you have any volt meter conversions for sale.
Thanks Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 03-29-2016, 11:22 PM   #177
TBONE1964
Cluster King
TBONE1964's Avatar
Originally Posted by brian1971 View Post
Hi Tom,
Thanks Brian
Hi Brian,
PM sent
TBONE1964 is offline   Reply With Quote
Old 03-30-2016, 08:07 AM   #178
Steve Cole
Hey Tom,
I tried to reply to your last PM but I keep getting this message:
TBONE1964 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
If you are trying to send this message to multiple recipients, remove TBONE1964 from the recipient list and send the message again.
Any ideas??
Thanks, Steve
Steve Cole is offline   Reply With Quote
Old 03-30-2016, 08:16 AM   #179
brian1971
brian1971's Avatar
Hi Tom,
I tried to send a private message back to you last night but it wouldn't go through either thanks Brian
Old 04-04-2016, 06:02 AM   #180
northern 85
northern 85's Avatar
Have you done any of the 66 dash style conversions?
northern 85 is offline   Reply With Quote
Old 05-05-2016, 01:08 PM   #181
wannabefastcrf
are you still making these?
wannabefastcrf is offline   Reply With Quote
Old 05-05-2016, 01:53 PM   #182
The Rocknrod
Moderator
The Rocknrod's Avatar
Old 05-05-2016, 10:17 PM   #183
Ctinman
I would like to buy one of these when you have one available. Thanks
Ctinman is offline   Reply With Quote
Old 05-09-2016, 08:49 PM   #184
TBONE1964
Cluster King
TBONE1964's Avatar
Hey Guy's,
I will do volt gauge conversions but I need to find the gauges. As most of you know, it is the 76+ Chevy truck volt gauge I use for these.
If you have access or can find your own gauge, I can build a conversion for you if you send me the gauge.
I will start working on getting some more gauges. The problem is the price on the gauge is costing more so I am going to be charging more for the conversions. They are going to be more around $100.00 shipped now if I supply the gauge.
As far as the 60-66 volt gauge conversions, I can do those as well but the price will be $140.00. There is much more modifications to be done to the gauge tin to make them work. Also there is no "8-13-18" volt overlay for these like there is on the 67-72 conversions.
Thank you for the interest. Send me an email to tbonegarris@yahoo.com if interested.
Take care,
Tom
Old 05-12-2016, 04:06 PM   #185
brian1971
brian1971's Avatar
Hi Tom,
Email sent about conversion.
Thanks,
Brian
Old 05-12-2016, 06:03 PM   #186
The Rocknrod
Moderator
Originally Posted by TBONE1964 View Post
Hey Guy's,
... There is much more modifications to be done to the gauge tin to make them work...
Just for clarification - What is the "Gauge Tin"?
Old 05-12-2016, 07:52 PM   #187
TBONE1964
Cluster King
TBONE1964's Avatar
The cluster has the main tin which you could call the main body of the cluster and it has the small tins that hold the gauges. The temp and amp gauge are in one tin and the oil and fuel gauge are in another tin. It is that "tin" that needs to be modified to accommodate a later style volt gauge.
Hope this helps,
Take care,
Tom
Old 08-17-2016, 10:41 PM   #188
steveo3318
steveo3318's Avatar
Tom do you have any of these ready to be shipped? either in the 67-72 or the 75+. I am not sure which one I want. i am leaning towards the 75+ but not sure of any modifications needed to fit it. Will i need to put my needle on it?
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 08-17-2016, 11:19 PM   #189
TBONE1964
Cluster King
TBONE1964's Avatar
PM on the way.
Thank you,
Tom
Old 08-18-2016, 10:27 PM   #190
steveo3318
steveo3318's Avatar
Tom quick question. Have you ever thought about an overlay for the oil pressure gauge??? I would buy one if you had it!!! Just one similar to the voltmeter with numbers
Old 08-18-2016, 11:34 PM   #191
TBONE1964
Cluster King
TBONE1964's Avatar
I can check into it. The problem is the initial set up charge cost a lot. It worked out for the volt gauges because there was so much demand for them. Not so much on the oil pressure gauges.
I have considered doing electronic oil pressure gauge conversions but again, have not had much demand for them.
Take care,
Tom
Old 08-22-2016, 01:51 AM   #192
TrinitySteve
Do you have just the voltmeter face decal for sale?
TrinitySteve is offline   Reply With Quote
Old 08-22-2016, 10:29 AM   #193
TBONE1964
Cluster King
TBONE1964's Avatar
Sorry, I do not have any available to sell at this time.
Thank you,
Tom
Old 08-25-2016, 12:37 PM   #194
General23cmp
What keeps the +12v from grounding out from the tin on the voltmeter?
General23cmp is offline   Reply With Quote
Old 08-25-2016, 08:38 PM   #195
TBONE1964
Cluster King
TBONE1964's Avatar
The gauge itself has small insulators that keep the terminals from touching the tin. The way I supply voltage is the same way it is done by the factory only without the circuit board. I just tap into the 12V side of the temp gauge and piggy back it over the the 12V side of the volt gauge, add the ground, and all is good.
Yes it is possible if you are not careful to install the gauge incorrectly in the tin. At that point, things would start to get hot until the fuse popped.
Hope this answers your question,
Tom
Old 08-29-2016, 11:41 PM   #196
TBONE1964
Cluster King
TBONE1964's Avatar
Hello all,
I currently have enough gauges to build 2 conversion kits if anyone is interested.
They are $100.00 shipped.
Please ask any questions you have and thank you in advance for your continued business.
Take care,
Tom
Old 08-30-2016, 07:10 AM   #197
hexafamily
I'll take one for my '72. Let me know how how you want payment.
Don
'57 Chevy Nomad
'70 Buick GSX
'72 Cheyene (Boys' truck)
hexafamily is offline   Reply With Quote
Old 08-30-2016, 10:29 AM   #198
TBONE1964
Cluster King
TBONE1964's Avatar
PM on the way.
Thank you,
Tom
Old 08-30-2016, 11:24 AM   #199
hexafamily
Payment sent.
Don
'57 Chevy Nomad
'70 Buick GSX
Old 08-30-2016, 11:28 AM   #200
c104life
I will take the 75+, for my 71
c104life is offline   Reply With Quote
