Old 03-22-2018, 04:36 PM   #176
chris1htx
Re: LT1 GenV swap
Originally Posted by 87chevy.com View Post
Satisfied with the upper radiator hose choice. Coukdnt find a one liece solution. This one required 2 different hoses with the single adapter. If the adapter was maybe 2 inches longer the stock Fbody hose would work without a 2nd hose.
Still need to sort out the e-fans.. among other things.. also got the ac lines braze together. Pleased with the outcome. Both ends will get 90 degree fittings and it will match / run along side the heater core lines.
Clint
What radiator did you go with?
chris1htx is offline   Reply With Quote
Old 03-24-2018, 01:20 PM   #177
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: LT1 GenV swap
Stock square body 454 radiator
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-08-2018, 10:19 PM   #178
87chevy.com
Re: LT1 GenV swap
Made a little progress finally, tank installed
And finally knocked out the trans lines!
Old 04-15-2018, 08:24 PM   #179
87chevy.com
Re: LT1 GenV swap
Drew up and cut out the transmission cross member pieces out. Didn't have the stock one, and if I did, probably still wouldn't use it lol. Waiting on the hole saw bit to arrive to finish it.
Similar design I used on the LS BMW
Plumbed the fuel system. Ran out of the push loc fittings, needed one more 45*, so a 90* was put on just to get it finished.
Proper 5bar fuel presssure regulator
Clint
Old 05-13-2018, 08:06 PM   #180
Advanced Design
Advanced Design's Avatar
Re: LT1 GenV swap
Nice work and problem solving all through the build! Any updates?
Advanced Design is offline   Reply With Quote
Old 05-14-2018, 08:24 PM   #181
87chevy.com
Re: LT1 GenV swap
Just got it started a few minutes ago after some quick trouble shooting... now it's going on hold again. Have another harness to mod, waiting for a set of custom header flanges to arrive so I can make a set of long tubes for it.
Clint
Old 05-16-2018, 03:18 PM   #182
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: LT1 GenV swap
Clint, I have a set of LT flanges that I won’t use. I don’t remember what I paid for them but if your interested...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-18-2018, 12:15 PM   #183
Clyde65
Clyde65's Avatar
Re: LT1 GenV swap
87chevy, what did you use to control your trans?
I found out the trans is a 2013 and the motor/pcm is a 2015. I’ve tried 3 tuners and no luck so far. It’s stuck in 1st gear.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-18-2018, 01:09 PM   #184
87chevy.com
Re: LT1 GenV swap
How do they know its a 2013 6l80? Using the stock 2015 ecu... do you have HPTuners? If so you can read out the data, post that on HPTuners site and ask of they can do a segment swap. I've only rehashed 2015's to 2014 If they didn't have vats2.
I got a 2015/16 flood transmission taking up space on the garage. Would more than likely need a rebuild just to be safe. Havnt taken the pan off, just stuffed it under my table saw.. I bought it with a hydrolocked motor for mockup before in-game across the good one I have now.
Old 05-18-2018, 07:33 PM   #185
Clyde65
Clyde65's Avatar
Re: LT1 GenV swap
Ya know... I think I have been BS’d again. Spoke to clinebarger today, just need to change out the valve body/Tcm. He said the only issue is when they come from different types of vehicles, 2013 car vs a 2015 truck, also he said the guy doing the programming could have fried it if he doesn’t have the correct equipment.
Thought?
Clyde65
Rebuild of Clyde
support our troops!
Old 05-18-2018, 07:34 PM   #186
Clyde65
Clyde65's Avatar
Re: LT1 GenV swap
The tag on the side of the trans decoded it’s a 2013...
I don’t have squat, I’m relying on others and what they say..possibly my issue all together.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-28-2018, 06:31 PM   #187
87chevy.com
Re: LT1 GenV swap
Hopefully you get the trans sorted out.
Got another swap harness wraped up.
Still waiting on the header flanges, hopefully they will ship out late this week. Once headers are made I'll reinstall the fenders and hood and take it around the block.
Old 05-29-2018, 07:42 PM   #188
Clyde65
Clyde65's Avatar
Re: LT1 GenV swap
Still haven’t gotten the trans fixed. New VB/TCM and still can’t program the trans TCM. Checked continuity from TCM plug to data lync connector and all is correct there.
My head is swimming in a lake of frustration on this...could there be something wrong with the ECM?
Clyde65
Rebuild of Clyde
support our troops!
Old 05-29-2018, 10:21 PM   #189
87chevy.com
Re: LT1 GenV swap
There is only 2 other wires that would be modified for the TCM, battery constant and the crank/run.
Clint
Old 06-09-2018, 08:23 PM   #190
87chevy.com
Re: LT1 GenV swap
Hours and hours worth of cad gets me this far. Exhaust ports exactly centered on 1 3/4 tube. I chose 1 3/4 since I have lots of bands left over and the port as well, when a 1 3/4 tube is shaped like a rectangle, the same size. I'm not to crazy about the flanges I ordered and received so drew my own.
Adapters screwed into the nutserts
Just threw some tubes on it just cause.
Mann, the MDF flange is way better than a steel flange and a starter tube in said flange with the insert adapter.. this way is much much much more stable and won't fall out! So wish I had done this on the last set of headers I built!
Hope to get the driver side modeled tomorrow and maybe get started on chopping it out of tube. Still need to make another saw fixture for the u-bends
Old 06-10-2018, 07:51 PM   #191
Advanced Design
Re: LT1 GenV swap
Very cool!
Old 06-14-2018, 09:14 PM   #192
Clyde65
Clyde65's Avatar
Re: LT1 GenV swap
87, do you do tuning? If so, would you mind answering some questions for me. I can get a tuner here that is willing or able to fix my issue.
Please pm me your number and best time to call, if your ok with me calling.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-15-2018, 12:41 PM   #193
87chevy.com
Re: LT1 GenV swap
PM sent
Got the driver side mocked up. Wound up sending my drawing file of the header flange to the later cutter, was not happy with the stainlessworks flange. Those should be done in a few days.
Thought about sending them out once I have them welded up and sell them but speed engineering says they will be making them at some point so not sure if its gonna be worth it.
Clint
Old 06-19-2018, 10:12 PM   #194
gringoloco
A guy with a truck
gringoloco's Avatar
Re: LT1 GenV swap
Speed engineering’s hang low, in my experience, so it might be worthwhile
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-21-2018, 11:30 AM   #195
87chevy.com
Re: LT1 GenV swap
This is where the collector is gonna be positioned. Clears factory shift linkage
Clint
Old 06-24-2018, 06:37 PM   #196
87chevy.com
Re: LT1 GenV swap
Mocked in the a massive 19" 600 watt pwm fan. The radiator core is 19" tall.. think it was meant to be.
Shows the gap between fan and core, will get pushed away a little more
The wood strips are 3/4, gonna use some 1x1 aluminum as a frame and rivet a piece of sheet to the frame.
Since I do t have a metal brake wide enough for the sheet metal, the 1x1 square tubing frame should work out. I'll bend a piece for the top, to cover the radiator and one for the bottom part so fan pulls all the air from the core area.
Need to do some research on what other companies use as far as thickness and see who has a sheet or scrap large enough for this project.
New header flanges should be in Thursday along with the u-bends.. and I work the following Saturday
Clint
Old 06-28-2018, 08:39 PM   #197
87chevy.com
Re: LT1 GenV swap
Recieved the header flanges and other bits today
Extra bits that should make header tube forming easy once the transition from port shape to round is made
Game plan is to use a grinder to make the transition and simply run a bolt through them to align it, then cut some grooves length wise and weld a bead in the groove. Cut some le grhs of tube and take em to work and use the press to form it.. could use a hammer .. well will see.
Using a hammer on the exhaust tube forming cone took some serious swings but the press made easy work of forming my transitions.
2.5 to 3" yes they sell transitions but way over priced for what they are. 2 cheap transitopms that arnt as smooth as the ones the fool made cost as much as the tool.. no brainer.. and the good ones are $$
For kicks I shrunk a 3" to 2.5.. smooth as butter!
Clint
Made an extra set of flanges if anyone is looking to make their own headers. I got plenty of extra inserts to make an extra tube former.
Old 07-09-2018, 06:27 PM   #198
87chevy.com
Re: LT1 GenV swap
Sharing the exhaust u bend fixture I've made.
Made the back fence tensioner out of a scrap away bar link. A regular bolt works too. I had to use a regular bolt for the stait cuts due to the lack of space.
Makes it easy as pie to duplicate the plastic version. The back fence makes it so much safer too. Also works for any size tube if the chop saw can handle it. Metal saw blade is the best thing as the abrasive deflects to much to be accurate
Old 08-01-2018, 08:21 PM   #199
87chevy.com
Re: LT1 GenV swap
I've made a L83 swap harness for someone and they bailed. Will fit short beds/long beds with stock tank location or short bed with cell in the rear between frame rails as this one was made for a short bed with a cell on the rear between the rails. Can provide measurements if needed. 750$ shipped with exchange of a stock harness.
Has provision for driver side alternator. Wires ran in loom and has ECU pins already crimped incase driver side alt is needed.
Harness is e85 ready
The white wood panel is just to hold the bulkhead and fuse block during wiring it. Cad drawing with the template to cut out will be provided.
8 ga power feed, starter, ignition and fan output (pwm) are the wires needed to be connected.
Has a separate interior harness and fuel harness for ease of install.
Even though this is not the for sale section, figured this would be the best spot for it.
Clint
Old 08-03-2018, 11:05 PM   #200
DavidZ213
Re: LT1 GenV swap
Random bag of spacers i found on the side of the street
Surprisingly they fit the passenger side alternator mount lile a champ!
Used up all the random length bolts i could round up for mock up. Now just need to print the final template and cut it out on some 3/8 plate...
Ill re-do the power steering plates later to incorporate an idler pulley for more crank belt wrap.. maybe un necesssry but why not..
Still need to sort out the motor mounts.. 3/8 plate to adapt gen5 to sbc... leaves a 1/4 inch or so between the booster and valve cover.. so tight, i cannot install the beauty cover
With this setup, I can keep the vacuum pump and not have to worry about vacuum although i have 2 l83 manifolds and going to try something with one amd post the results of the test
Clint
Clint I Would Like To Know If You Made Any Extra Brackets I’d be really interested. If you do can you pm me with details.
DavidZ213 is offline   Reply With Quote
