#2026 |
Re: My 86 build
thanks man....I never know either!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#2027 |
Re: My 86 build
#2028 |
Re: My 86 build
some show pics....
#2029 |
Re: My 86 build
awesome moose!!!
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
#2030 |
Re: My 86 build
#2031 |
Re: My 86 build
Moose
When you smoothed the firewall. Is there a void between the sheet metal you used and the firewall? Just curious what you did with the seam on upper part of firewall? What gauge metal you use? |
#2032 |
Re: My 86 build
engine bay is SICK
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#2033 |
Re: My 86 build
I used some fairly heavy steel, about 1/8" thick so it wouldn't warp all to hell, and cut down on the stone chips.. also the master cylinder is bolted to it. I welded it all along the top edge and from the back side through any hole I could find...hope that helps.
#2034 |
Re: My 86 build
thanks brother! ......this build is on hold temporarily while we work on the 67...lol.
#2035 |
Re: My 86 build
I really like the flat firewall. I can't do it because I will need the heat to work. Your truck looks good!
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
#2036 |
Re: My 86 build
eventually it will have vintage air.
#2037 |
Re: My 86 build
I had a feeling you were going to do that. I showed the pic to my wife, and I told her that since you live in Canada, you have to have some kind of heat installed in there.
#2038 |
Re: My 86 build
So which truck are you putting the floor pan in? This one does not look like it needs it! Looks like you are working on a 67, 86, and...???
You have a thread going for the one with the floor pan?
#2039 | ||
Re: My 86 build
#2040 |
Re: My 86 build
looking good moose!
subbed...
#2041 |
Re: My 86 build
what ever happened with this build?.....lol
#2042 |
Re: My 86 build
couple pics of the '67.....
#2043 |
Re: My 86 build
The 67 is looking sick wid it
#2044 |
Re: My 86 build
looking good man!
#2045 |
Re: My 86 build
I like what you did to the truck nice job!!!!
#2046 |
Re: My 86 build
Thanks guy's !
#2047 |
Re: My 86 build
can't wait to see more of the 67!
#2048 |
Re: My 86 build
check it out in the build thead...2nd link below in my sig...
#2049 |
Re: My 86 build
I just went through your entire thread ................... YOU SUCK MOOSE !!!!!! JK ..... your work your truck your ideals are top shelve my brova !!!!! awsome work
#2050 |
Re: My 86 build
Subscribed
