Old 09-03-2014, 08:50 PM   #201
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Project "Schrum" 1959 Gmc 100
I have a guy from Hickory that is going to come out and see if he can get it fixed
I really need to just send it to a mechanic and have them do all the work to it so it can run perfectly
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 09-04-2014, 01:15 PM   #202
_Ogre
_Ogre's Avatar
Originally Posted by SCHRUMGMC View Post
there is no place to put the Gas pedal on the transmission cover.
the gas pedal does not mount or go thru the trans cover
stock pedal linkage
mounts here (orrieg's truck)
and here is where it mounts: 1'' hole with 2 screw holes mid way above the floor
shop air compressor timer
Old 09-04-2014, 03:27 PM   #203
SCHRUMGMC
SCHRUMGMC's Avatar
For some reason my Transmission cover on the left side doesn't fit it right?
Where my gas pedal is now the transmission cover hits it.. It should be on the firewall?
1971 GMC Sierra
1959 GMC 100
Old 09-04-2014, 07:26 PM   #204
OrrieG
OrrieG's Avatar
Mine is V8, six is different. here is fam linkage for six and edited photo. tran cover is probably from another truck.
OrrieG is offline   Reply With Quote
Old 09-04-2014, 07:41 PM   #205
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks Orge. Do you have any idea what could be wrong with my Distributor ?
1971 GMC Sierra
1959 GMC 100
Old 09-04-2014, 08:34 PM   #206
Kim57
Kim57's Avatar
Your distributor may have a worn shaft or the drive gear may be loose.
I really have no idea how they're driven on the 6s.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-04-2014, 08:38 PM   #207
OrrieG
OrrieG's Avatar
Is the distributor housing physically moving back and forth with the engine running at a constant speed, or moving when you accel/decel? Or is the timing mark bouncing around when you try and time it? I thought you had bought a new vacuum advance set up and replaced it?
Old 09-04-2014, 08:40 PM   #208
SCHRUMGMC
SCHRUMGMC's Avatar
It moves around when I start the truck up to the retarded timing area and it pops through the carb . I don't have a new Vacuum advance
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 06:45 AM   #209
coralhead
coralhead's Avatar
Sounds like the timing is off or intake valves not completely sealing (timing off) if it backfiring(popping?) through the carberator. Have you put a timing light on it to check the timing setting or are you doing it by ear? Makes a big difference in running with the timing set correctly.
coralhead is offline   Reply With Quote
Old 09-05-2014, 09:12 AM   #210
SCHRUMGMC
SCHRUMGMC's Avatar
It pops because the Distributor moves that way when I start the truck. I've never seen something like it before.. It wasn't doing this until I messed with the rotor cap and put the Dist Cap back on
If the distributor is worn out, is there a way I can get it rebuilt. It did fine until now
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 10:09 AM   #211
SCHRUMGMC
SCHRUMGMC's Avatar
I've thought of a reason why the truck doesn't idle well, possible intake leak? it has a new gasket but all things can be possible. If I can get it to idle when I figure out this distributor issue. ill squirt some starter fluid to see it it revs up
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 10:31 AM   #212
lowrodderchev
lowrodderchev's Avatar
Ok the whole distributor is moving or just the cap? On the 6 cylinder distributor the vacuum advance is tighten down with a nut and screw is it tight? And is it leveled were the distributor is drop all the way down to into the motor? other than that maybe your cap is not on right is the tab on the cap lined up with slot on the distributor?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 09-05-2014, 12:31 PM   #213
SCHRUMGMC
SCHRUMGMC's Avatar
The WHOLE Distributor like I keep saying is moving
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 02:27 PM   #214
lynx5653
lynx5653's Avatar
And i still say take it to a mechanic !!!!!!!!!!!!!! Stop messing with it before you end up with more problems.
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 09-05-2014, 03:01 PM   #215
SCHRUMGMC
SCHRUMGMC's Avatar
im not going to touch it, ill put a alternator in
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 04:46 PM   #216
lowrodderchev
[QUOTE=SCHRUMGMC;6831149]The WHOLE Distributor like I keep saying is moving[/QUO
someone needs a nap or a time out and good idea take it to mechanic seems like that truck don't like you to much LOL
Old 09-05-2014, 04:54 PM   #217
crossfire84
crossfire84's Avatar
[quote=lowrodderchev;6831412]
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 09-05-2014, 05:34 PM   #218
SCHRUMGMC
SCHRUMGMC's Avatar
Haha Low, I wasn't angry
I am buying an Delco Remy Alternator from Napa tomorrow to replace the Generator
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 05:46 PM   #219
lowrodderchev
dude I got that electronic distributor sitting there its your just cover shipping instead of screwing with the stock one.
Old 09-05-2014, 05:52 PM   #220
SCHRUMGMC
SCHRUMGMC's Avatar
Post a photo of the distributor. I'd like to get a Petronix electronic kit though
1971 GMC Sierra
1959 GMC 100
Old 09-05-2014, 05:58 PM   #221
lowrodderchev
have that on my fleetline 6 years its been great to me
Old 09-05-2014, 06:31 PM   #222
coralhead
coralhead's Avatar
I have a petronix in my '50. Works great but will not fix a jacked up (wornout) distributor. If the distributor is bad it is bad.
Old 09-05-2014, 06:40 PM   #223
SCHRUMGMC
SCHRUMGMC's Avatar
Thankfully I have a backup Distributor for my truck, that came out of a '59 Chevy
http://www.hartin.com/alternator.htm
Found this on how to wire the alternator up
Only problem I face is the indicator light
1971 GMC Sierra
1959 GMC 100
Old 09-07-2014, 01:23 PM   #224
OrrieG
OrrieG's Avatar
I'd take lowridder up on his offer and focus on changing the distributor and getting it running right before tackling the alternator. Didn't you get the generator rebuilt and get a new voltage regulator? Nothing wrong with the original generator system, I ran mine until 2000. Only reason GM changed was because cars were drawing higher amperage loads and alternators were better way to deal with it. Stock trucks without AC, etc. do fine with 36 amps....
Old 09-09-2014, 12:59 PM   #225
SCHRUMGMC
SCHRUMGMC's Avatar
I'm trying to figure out the best price for an Alternator brackets. I am going to change out the distributor for my back-up one that I have. Hopefully that will solve some of the current issues
https://www.classicpartsusa.com/prod...ternator_Items
1971 GMC Sierra
1959 GMC 100
