Old 06-06-2014, 01:58 PM   #201
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
I just took out the orig. firewall pad in my cab and it was a thin cardboard material on one side and 1/4" insulation on the other. That rubber looks good & looks like it might be sturdier than the original stuff. Was it insulated on the inside portion?
Everything looks good! Keep at it.
What's that green wire going thru your vent for?
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 06-06-2014, 02:26 PM   #202
1963c-10
1963c-10's Avatar
Re: 61K10 build
Yeah the originals were not rubber....I have wondered if they were a decent upgrade. Mine are original and made from the same material as the gas tank cover with and insulation glued to the back side of them.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-06-2014, 02:39 PM   #203
61K10
61K10's Avatar
Re: 61K10 build
the new pad has the jute on the back. green wire is a ground for the fuse box and is just floating around. not tied down.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-06-2014, 03:06 PM   #204
1963c-10
1963c-10's Avatar
Re: 61K10 build
Just curious.....is this the new air freshner on top of the engine in the pic? Haha.....
Old 06-06-2014, 06:47 PM   #205
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Lookin Good as always, that sack looks vintage...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-07-2014, 01:25 PM   #206
61K10
61K10's Avatar
Re: 61K10 build
going to hang the air freshner on my gun rack lol.
the rubber firewall pad doesn't fit to well up top a little big. has a ripple or bubble. I guess you can't see it though.
don't ever try to install the wiper motor by yourself lol.
1961 chevy K10
Old 06-07-2014, 10:39 PM   #207
C@rnut001
Re: 61K10 build
Awesome job on your truck. It is looking amazing. Keep up the great job. I know that you said it has its little things that you know are not perfect, but that makes it a truck that you will drive. You have done an excellent job, keep it up!
C@rnut001 is offline   Reply With Quote
Old 06-08-2014, 01:43 AM   #208
argonaut
argonaut's Avatar
Re: 61K10 build
All the firewall covers I have seen are cardboard with jute on the back. Where did you get the one made of rubber?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-09-2014, 03:32 PM   #209
61K10
61K10's Avatar
Re: 61K10 build
Jason---got it from brothers--$59.95
Randy---chicken or turkey feed lol.
thanks C@rut001
my heater doesn't blow out any air--spins like h#ll though and makes alot of air noise. wrong cage i believe, spins clockwise but cage is made for counter-clockwise. motor is sealed so can't reverse the wires. I modded the heater and just ck'ed if it spun. every time i try to save a nickle it bite's me you know where.
1961 chevy K10
Old 06-09-2014, 06:03 PM   #210
1963c-10
1963c-10's Avatar
Re: 61K10 build
i think i have a spare motor and cage sitting on the shelf if its a factory application. i can get a few pics for you. think its off a 64 if i remember right
Old 06-09-2014, 06:06 PM   #211
1963c-10
1963c-10's Avatar
Re: 61K10 build
parts book shows different motor for 60-63 and 64-72. so motor wont work for you, but cage wqs good for 60-72 if it helps any let me know and i can get it to you.
Old 06-10-2014, 12:54 PM   #212
61K10
61K10's Avatar
Re: 61K10 build
thanks 1963c10 for the offer. my motor is off a late model gm. don't remember the year. it spins on hi much faster than the stock one did. I had to cut the center out of the stock motor plate (because it has the mounting bracket) to the firewall. ordered another cage--we will see.
1961 chevy K10
Old 06-10-2014, 12:59 PM   #213
61K10
61K10's Avatar
Re: 61K10 build
here's a pic of the motor on top of the org motor plate.
1961 chevy K10
Old 06-10-2014, 01:16 PM   #214
1963c-10
1963c-10's Avatar
Re: 61K10 build
OK, just let me know. The cage is yours if you need it, just cover the shipping.
Old 06-12-2014, 12:51 PM   #215
61K10
61K10's Avatar
Re: 61K10 build
1963c-10--figured out my heater lol. the org eco heater spins counter clockwise--well my new setup was spinning clockwise thus not throwing out any air. will post up my new setup when working.
1961 chevy K10
Old 06-12-2014, 01:29 PM   #216
1963c-10
1963c-10's Avatar
Re: 61K10 build
Cool, just glad you got it figured out.
Old 06-15-2014, 08:02 AM   #217
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Hey 61K10 any updates can't wait to see the doors back on and fenders and hood and bed Geesh sounds like a lot of work...
1964 BBC 402 4x4
Old 06-15-2014, 12:14 PM   #218
61K10
61K10's Avatar
Re: 61K10 build
been working on the reinstall of my wiring and everything under the dash. having a few problems as usual. hope to get the instrument cluster in today then column and gas tank. they sure come apart way easier than the go back together lol!
Kimble
1961 chevy K10
Old 06-16-2014, 01:21 PM   #219
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Kimble,
Your giving me lots a great info and ideas! Glad your leading the way in restore. Keep those pics coming. I like the wide swath path of your undercoating inside / out. Was the tintable undercoating not thought of till after?
'62 Chevy K10
Old 06-17-2014, 12:02 PM   #220
61K10
61K10's Avatar
Re: 61K10 build
Mitch to be honest i didn't even thank about it. Had a wire semi melt in my wiring harness. hooked up the tach wrong. got that worked out with new wire. (it was just a short piece). will test it all on the bench before installing it this time lol!
Kimble
1961 chevy K10
Old 06-18-2014, 10:45 AM   #221
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Well I like it either way, and good to know that it'll cover right over the paint. Unless you scuffed it up before applying to the back of the cab? Melted wire huh. Well could of been worse, i guess. Did you go thru a whole gallon to do fenders and cab both?
'62 Chevy K10
Old 06-19-2014, 12:22 PM   #222
61K10
61K10's Avatar
Re: 61K10 build
I used a scotch bright (3M) pad before i shot the liner on the cab. the stuff sticks big time. I have one Qt left. the fenders i used an under coating kind more than a bed liner type. I thank i posted wrong saying sem as i used duplacolor spray can bed liner. seemed to stick well also. now the sem bedliner is2 part. you add a hardner to it.
got my heater fixed. used a blower motor and cage out of a 96 camaro. runs counter clockwise and does it blow! had to space it up a little as the cage is taller. do you have the eco in cab or under hood heater?
1961 chevy K10
Old 06-20-2014, 10:07 AM   #223
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
I got the under hood heater (Deluxe) is what they called it. The data tag on mine reads - Comfort package 433M
'62 Chevy K10
Old 06-20-2014, 10:09 AM   #224
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
I think, I'm gonna just use the bed liner for the underside of the fenders and all like you did too.
'62 Chevy K10
Old 06-21-2014, 01:56 AM   #225
LuckyLightning
LuckyLightning's Avatar
Re: 61K10 build
61K10 - your dash cluster is my favorite type (needles instead of tell-tell lights). Is it original or 3rd party (if so, from whom)?
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
