Old 02-18-2024, 04:48 PM   #201
57FleetsideC4
Re: 57 Fleetside C4 build
Still plugging away on this project. I put a battery in it to see where I was on everything that has been done electrically so far. Was able to communicate with the PCM and found a couple of codes for the gas pedal which was my fault as I got a couple of the wires crossed when I took the connector apart to get it through the firewall. The second problem is it would not turn over and that was a broken wire in the supplied engine harness so now will turn over. I wired in the Dakota Digital dash which went really well and programmed it. I am going to try and start it soon and see how that goes. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 02-19-2024, 03:09 PM   #202
youngrodder
youngrodder's Avatar
I really like the color combo. Isn't wiring fun??
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-19-2024, 07:46 PM   #203
57FleetsideC4
Marc
Yes wiring can be trying at times. Luckily I found it pretty fast. I did put some fluids in it today and spun it a little and it fired a little. Must have been some fuel in the fuel rails. Steve
Old 03-02-2024, 09:42 AM   #204
57FleetsideC4
Made some good progress the last week or 2. I now have it running, brakes are bled and got all the fluid in the transmission and it does work. Right now working on a parking brake so it will pass New York state inspection. No pictures to show but still working away on it. Steve
Old 03-03-2024, 01:51 PM   #205
57FleetsideC4
Some more progress on the 57 project. I was able to finish the parking brake and installed the trim on the doors and rear window area. Started to come together. Here are some pics. Steve
Old 03-03-2024, 03:21 PM   #206
daveshilling
daveshilling's Avatar
VERY interested in a parking brake write-up for the C4 rear!
daveshilling is offline   Reply With Quote
Old 03-03-2024, 07:06 PM   #207
bowt1ed
Along with that, I'd love to see how you mounted your 2 to 1 bracket for the parking brake. Is that the Lokar kit?
Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 03-03-2024, 07:45 PM   #208
57FleetsideC4
Thanks, Jim
I used 2 of the universal summit racing parking brake cable kits, The bracket is lokar and a couple of lokar single cable couplers. I was able to use a block that came with the summit kits that uses allen screws to secure the cables at the wheel side then threaded one of the lokar couplers on the other end. I will post a picture of what it looks like later. I am using the stock brake handle and the angle the cable goes to the handle is not the best but works. Steve
Old 03-04-2024, 09:36 AM   #209
NWA58
I’m interested also, especially the cable from the stock handle. The stock lever action sat very high on the firewall and I’d like to keep it clean now that it is smooth. Would prefer not to see it under the hood.
NWA58 is offline   Reply With Quote
Old 03-04-2024, 09:59 PM   #210
57FleetsideC4
Here are the pics of the cable hook up, handle hook up and where it exits the firewall. Steve
Old 03-05-2024, 08:13 AM   #211
bowt1ed
Thanks!
Old 03-05-2024, 09:43 AM   #212
NWA58
Thanks for the detail pics on the brake cables! I really like your steering wheel… where did you find that and what is it?
Old 03-05-2024, 05:34 PM   #213
57FleetsideC4
The wheel is Billet Specialties Victory 14" D shaped. Steve
Old 03-06-2024, 01:56 PM   #214
bowt1ed
One more quick question on your cables. I couldn't tell from the pics, bit we're you able to run your cables through the original brake line bracketed holes, to run to inside of frame rails? Or are they just running from caliper to cable coupler bracket?
Thanks, Jim
Old 03-06-2024, 07:36 PM   #215
57FleetsideC4
Thanks, Jim
Hi, I used the stock brackets in the stock location of the C4 rear. Steve
Old 03-06-2024, 08:38 PM   #216
bowt1ed
Old 03-18-2024, 11:35 AM   #217
58CameoAZ
Sir,
Would it be possible to see how you routed your brake cables to the rear on your axle?
I ask because i am using a 85 C4 rear end in my 58, just was wondering how you routed them.
Thank you very much!
58CameoAZ is offline   Reply With Quote
Old 03-18-2024, 07:24 PM   #218
57FleetsideC4
Originally Posted by 58CameoAZ View Post
Sir,
Hi, Here are some pics. Hope it shows what you need. Steve
Old 03-19-2024, 10:59 AM   #219
58CameoAZ
Thank you Very Much!
appreciate the pics, I also need to route my brake lines and this gives me a better view of were they need to go also!
Thank you again
Allen
Old 03-27-2024, 06:31 PM   #220
57FleetsideC4
made some great progress on my 57 project. Some friends came over and helped me get the bed partially together and then finished putting it back together and the same bunch of friends came over and got the bed back on the truck. Really starting to come together. Here are some pics. Steve
Old 03-27-2024, 06:40 PM   #221
57FleetsideC4
I forgot one picture of the back. I like having all the chains and exposed latches hidden. Looks cleaner. Steve
Old 03-27-2024, 09:31 PM   #222
Kevin_C
Thats a big milestone! congrats
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 03-28-2024, 10:34 PM   #223
Jason 56
Looks awesome! You’re making great progress. I like the clean look also. It’s going to look amazing when it’s done.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 04-06-2024, 08:03 PM   #224
57FleetsideC4
Thanks for the kind words. Made more progress on my project. Put the back bumper on and finished wiring the rear, tailgate hardware and a picture of the current wheels that came with it. What's everyone's opinion on these. they are 15" American Racing Hopsters with 255/70 rear 225/70 front. They kind of fit the truck. My original plan and still may do is a set of 20" wheels and tires. Steve
Old 04-06-2024, 08:09 PM   #225
57FleetsideC4
Some more progress I made this week. I got the aluminum panel back with carpet on back from the trim shop and installed it, installed the carpet, kick panels, sill plates, and mocked up the panels for the door trim that will get covered in leather and carpet. I also finished the tail pipes. Steating to come together. Steve
