10-11-2018, 06:49 AM | #26 | |
Re: Making A New Oil Pressure Line.
10-11-2018, 11:42 AM | #27 |
My 66 has a steel line which I assume is original. There is no loop in it either.
Is steel w/o a loop correct? I need to look in the AIM to see if there is good illustration on the instalation. |
10-11-2018, 10:11 PM | #28 |
But Found Her 25yrs Later!
Yeah, steel I read was original.
02-08-2019, 10:47 PM | #29 |
is there anywhere to get the steel line anymore?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
02-09-2019, 04:26 PM | #30 |
03-07-2019, 10:29 PM | #31 | |
The Older Generation
I disagree on the generalization of the copper line work hardening. It depends on the type of copper. The copper oil pressure lines I sell are made from 1/8" refrigeration copper that is designed for installation in areas that are subject to heat, cold, vibration, and high pressure. Most of the original lines were mild steel tubing and some of them had a piece of vacuum type hose over the line, I presume to help dampen vibration. Also, some of them were one piece and some of them were two piece with a coupler at the firewall. Everyone needs to do what they feel comfortable with. I have used the copper oil lines on all of my builds since 2004 with no issues. That would be 6 trucks and 2 Hot Rods...... LockDoc
03-09-2019, 02:23 AM | #32 |
Great thread.
Kind of on the same subject, when I ran my new oil line I put a T fitting in at the block so I could run both a gauge and an idiot light sender. Figure with something as important as oil pressure, I want a belt AND suspenders.
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
04-13-2021, 01:13 PM | #33 |
Mr. Cheyenne
Hey Leon,
So this is what I was explaining that I have on my gauge now - which is how it came to me. The copper line behind the gauge has just as much copper line, if not more, under the dash as the engine bay. Which in the engine bay it has about the right amount with the 1 and 1/2 loops. When I put the new line in, the engine side doesn't leak but the new male ferrule would leak between the fitting and line (at the gauge). I took the fitting as far as I felt comfortable with. So could this frankenstein setup of adaptors have messed up the gauge causing it not to seal with the proper male ferrule fitting? Also, to add to this drama when I pulled the new line out of the gauge the fitting somehow slipped off and I cannot get it back on to try again. I was thinking perhaps I needed to re-adjust the line into the gauge. So I guess this all doesn't matter... ugh. Edit: Actually, looking at LostMy65 photo, perhaps I have a 3rd adapter? The black-ish nut, where the 1st of two brass adapter are connecting into? See re-uploaded photo with pretty colored/numbered boxes. I hadn't taken out what is outlined with the #1 Purple Box.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-13-2021 at 01:41 PM. |
04-13-2021, 03:01 PM | #34 | |
Looks like they kind of cobbled that up for sure. The black nut in your Purple box is the nut that holds the gauge in the metal plate. Leave that. You should be able to take a small punch or nail set and open the hole in the fitting back up enough to get the line back through it. Just don't go too far with it. Just enough for the line to slide through it. Be sure and push in on the oil line while you are tightening the fitting up. LockDoc
04-13-2021, 04:03 PM | #35 |
Mr. Cheyenne
nice tip Leon - that I can do!
Its a real pain these lines LOL
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
04-25-2021, 12:51 PM | #36 |
Mr. Cheyenne
I couldn't find anything that really worked well to "open up" the fitting - all I did was mess it up. So I grabbed one off of Amazon.
Finally got to installing it today and I insured I had enough line into the gauge - I actually installed the gauge side first. After getting it snugged down, no leaking! The line I took out was 5ft long! I could have likely mounted a oil gauge in the bed of the truck with that old line! LOL
07-01-2023, 09:09 PM | #37 |
Hi! My name is Chris Nelson and I'm having a helluva time finding the correct line for the mechanical oil gauge on my 72 chevy! I know this is an old thread, but I'm new to this group and not sure how to direct message..... is there any way I can buy one of these from you?! Thanks!
07-02-2023, 07:55 AM | #38 |
Mr. Cheyenne
Hey Chris, I see that you found the thread where Leon was selling the oil line - though looks like he is out. That's a bummer, hopefully someone else has a tip or going to a big truck shop will help. Good luck
07-02-2023, 08:51 AM | #39 |
Yeah I hope so! I'll try and find something that works! Thanks for letting me know! I did get a PM from him telling me that he was out of it too.... the search continues.....
07-03-2023, 11:48 AM | #40 |
Chris, if you subscribe to the board, you can place a WTB ad on the parts board. Someone likely has a good used line they would sell.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
