Old 02-17-2022, 04:45 PM   #1
1969c10lightgreen
1969 C10 Build
THis is my 69 C10 build. I typically restore cars but have always wanted a 67-72 C10. I bought this one a while back now so just starting to post the progress. It was semi started but was a patina build. Lowering kit, disc brake conversion, wheels, trim etc. All the drive train redone. The guy added the 71-72 grille which I always liked. My dad had a 72 when I was young and always liked the truck so it has the look I like. Started full resto will start adding pics.
1969c10lightgreen is offline   Reply With Quote
Old 02-17-2022, 04:51 PM   #2
1969c10lightgreen
1969 C10 Build
I took the frame down and blasted it. Turned out decent. Added new trailing arms and bushings old ones were shot.
Old 02-17-2022, 05:09 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1969 C10 Build
Nice truck!!
Keith
Convert to disc brakes.
Old 02-17-2022, 05:18 PM   #4
1969c10lightgreen
1969 C10 Build
More pics as the frame is now. Lots of work but sure looks nice.
Old 02-17-2022, 05:21 PM   #5
lolife99
lolife99's Avatar
Re: 1969 C10 Build
Surprised to see the 2-piece driveshaft.
Nice work!
Keith
Old 02-18-2022, 12:30 PM   #6
1969c10lightgreen
Re: 1969 C10 Build
Nice work!
I am curious why you say that? Are they an issue?
Old 02-18-2022, 12:31 PM   #7
1969c10lightgreen
Re: 1969 C10 Build
Typical rot
Old 02-18-2022, 12:33 PM   #8
1969c10lightgreen
Re: 1969 C10 Build
Everything repaired and then sandblasted or stripped down. I forgot to get a pic of the bottom at this point but blasted as well.
Old 02-18-2022, 12:34 PM   #9
1969c10lightgreen
Re: 1969 C10 Build
Everything epoxy sealed at this point.
Old 02-18-2022, 12:34 PM   #10
lolife99
lolife99's Avatar
Re: 1969 C10 Build
Those carrier bearings are prone to failure.
Even brand new ones.
And a 2-piece driveshaft is normally in a long bed truck, but I have seen them in a shortbed like yours before.
Most switch to a 1-piece.
Less u-joints and eliminates problems with that carrier bearing.
Especially in high horsepower applications.
Keith
Old 02-18-2022, 12:39 PM   #11
1969c10lightgreen
Re: 1969 C10 Build
Basically where I am at now. The frame is done and I can get back to blocking. I seam sealed inside as well. I plan on hanging the doors this weekend again and confirming everything while I block and prime again. So far a few small dings and dents but fairly straight. I plan on adding the trim for the roof and having the roof white. Might do the lower trim as well so its white below. I like the way it breaks it up. Already have new bed floor and rear tubs. I have fixed and have blocked one bed side a few times as well but need to get the other one done yet.
Old 02-18-2022, 12:41 PM   #12
1969c10lightgreen
Re: 1969 C10 Build
Interesting. It appears to be original and the guy I bought it from pretty much took the stock truck and lowered it so probably is. I can always switch later I suppose. Thanks for the knowledge.
Old 02-18-2022, 01:08 PM   #13
MikeB
MikeB's Avatar
Re: 1969 C10 Build
Nice that you can use your professional skills on your hobby. And with no customers to satisfy!
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-18-2022, 01:42 PM   #14
1969c10lightgreen
Re: 1969 C10 Build
For sure. I used to do this for people but as you say the timelines and constant changes drove me away. I only do it as a hobby now. Engineer by daily trade but have been doing restorations since I was in my early 20's. It can be fun with no expectations.
Old 04-06-2022, 11:11 AM   #15
1969c10lightgreen
Re: 1969 C10 Build
I was able to assemble the box this weekend pretty cool seeing it back together. Starting to look like a truck a bit. All new floor, driver side and tubs.
Old 04-06-2022, 12:19 PM   #16
MikeB
MikeB's Avatar
Re: 1969 C10 Build
In my long bed I've replaced two in 33 years and >50K miles. And both were done because the rubber seal was cracked. So I wouldn't spend money to convert unless you do have problems.
If you did install a new bearing, make sure the u-joints are properly "phased". I can't remember offhand how to do it, but it's in the service manual and maybe even in a Haynes manual.
I'm really liking your truck!
Mike
Old 08-08-2022, 03:57 PM   #17
1969c10lightgreen
Re: 1969 C10 Build
Its been a bit since my last update but it has been coming along nicely I think.
Old 08-09-2022, 04:24 PM   #18
lolife99
lolife99's Avatar
Re: 1969 C10 Build
Looks VERY nice!
I thought it would be green again, but I like the black.
Are you putting a 69-70 grille back in it?
Keith
Old 08-10-2022, 08:01 AM   #19
1969c10lightgreen
Re: 1969 C10 Build
Thanks for the compliments.
I was originally going green but unfortunatly my dad passed away during this build and when I was little growing up he had a 72 custom that was all black so I decided to dedicate this to his memory in a small way. That truck he had when I remember back had a built small block and was pretty fast and he used to scare the crap out of me with it. I have fond memories of it. I kept the motor green in this to hint at its original color. I always loved the two tone and had planned that either way.
I thought about putting the grille back but since I have a love of the 71/72 front end I will keep it I think. I probably wont keep the truck I tend to want to do the next project as soon as the last one is done but who knows. My dad always enjoyed watching me build the next project too.
Old 08-10-2022, 04:15 PM   #20
Danyo492
Re: 1969 C10 Build
Looks awesome! What epoxy did you use to seal the cab?
Danyo492 is offline   Reply With Quote
Old 08-12-2022, 10:33 AM   #21
1969c10lightgreen
Re: 1969 C10 Build
The black is PPG DP90 if I remember correctly.
