05-26-2021, 11:39 AM | #1 |
1985 Long bed to short bed. Whats really needed. Just brake lines?
If I convert a 85 long bed to short bed, I am thinking All I need is DS shortened and the brake line
for a short bed truck. So is it really only 2 things I need? I know the cut measurements and everything else. Just looking for what needs to be replaced so I can order the hard parts. DS would be the last thing to get cut. Thanks I will be doing a 1985 silverado build, and a DETAILED (because no one has done it) video on how to shorten a 73/87 C10 on my youtube channel. From fleetside to stepper |
05-26-2021, 05:48 PM | #2 |
Re: 1985 Long bed to short bed. Whats really needed. Just brake lines?
I asked the same question and didn't really get a response.
I was under the impression that if you had a 20 gal tank, you would also have to change it to the 16 gal tank, but don't quote me on that. |
05-26-2021, 07:34 PM | #3 | |
If you have a 20 gallon tank, you'll need a 16 gallon tank to take its place. The tank brackets can be reused, but you'll likely want new mounting bolts. If you're buying a new tank, go ahead and buy a new sender unit to go with it. The fuel filler hose and/or neck needs to be changed. I don't know about the fuel lines.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
05-29-2021, 09:37 AM | #4 |
Guess Ill find out when I pull the bed. I will be doing a series of videos on this.
Not one long one. Worse case, I will pick up a Tanks inc tank. |
05-29-2021, 04:30 PM | #5 |
Sb 400 club
Brake line shortened
Tail light harness will be long Ebrake cable? Drive shaft shorten or from a short bed 16 gallon tank…
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
05-29-2021, 06:09 PM | #6 |
If your stepside doesn't have one with it, the fuel filler hose is different and hard to find. I am not sure anyone reproduces them for the stepside beds, least none that I can fine.
05-30-2021, 11:22 AM | #7 |
Just my recommendation, but do yourself a favour and get two 16 gal tanks, and get a switch for your dash and whatnot. Might as well, since you have access to everything. My SWB has only one tank and I can't take a relatively short roadtrip without stopping once or twice to fill.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
05-31-2021, 02:53 PM | #8 | |
06-06-2021, 02:57 AM | #9 |
hatzie can help you with your parking brake cable .
06-22-2021, 10:46 PM | #10 | |
06-25-2021, 07:08 PM | #11 |
