02-04-2014, 10:56 AM | #1 |
67 6 lug to 5 lug conversion.
Is there a thread or link anyone can point me too?
Is there a direct axle swap off another chevy truck to convert the 67 6 lug to a 5 lug? I just got my posi unit installed, I assumed I could use the 70-72 5 lug axles but They are longer. I guess I should just pick up a complete axle from a 70-72 if I can find one. I could pick one up and transfer the posi. I already have a rear disk brake conversion set-up. |
02-04-2014, 11:00 AM | #2 |
Re: 67 6 lug to 5 lug conversion.
Early classics has a 5 lug axle swap for around 300 bucks. I'm assuming you have a 12 bolt 30 spline.
02-04-2014, 11:05 AM | #3 | |
There aren't any direct swap axles. Go with aftermarket units which have zero wear & are stronger than OE.
02-08-2014, 10:23 AM | #4 |
just spent 500 on the diff wasnt wanting to spend another 300 on axles.
Thanks for the info! |
02-08-2014, 11:42 AM | #5 |
If you just installed a posi, did you upgrade the bearings? seals?
I had my 71/72 rear rebuilt, I gutted it and cleaned it all up and still cost me $1000, that included the master rebuild kit and the ring/pinion to 3.73. no posi.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-09-2014, 01:27 AM | #6 |
I only changed the posi. The 373 ring and pinion was already installed about two years ago by the previous owner. I did use a gauge and tested the play. Right at .09. I used the original spacers. And checked the ware pattern. It was dead on with the previous diff. So I only paid for the Eaton series 4. I did all this thinking I could just swap the axels from a 71 or 72. So now I am going to buy a few axles in the near future. It just slows down my progress.
That's a sweet 65 in your sig. Clyde how's the gas milage? |
02-09-2014, 02:46 AM | #7 |
Not to hyjack, but I'm in the same boat and curious about my options.
I have a 6 lug axle too, but it's garbage. Everything needs replacing. I can grab a local 12b/5 lug/ with 3.73s for around $180. Dunno the shape though. Was looking at putting a 9" together, but it's overkill and expensive. What do you guys think? |
02-09-2014, 02:57 AM | #8 |
TNT-MOTORSPORTS
I wont say it is the best option ...... but it is a reasonable option. Having the axles and drums redrilled to 5 on 5 and the centers turned down to fit the 5-lug wheel cost me $85.00 locally , just need to make sure the axles arent wore out first . Now to me the best option for a fleetside truck is to go ahead and put the wider 71-72 rear axle in if possible. Opens up alot more options for wheels with the correct backspacing .
02-09-2014, 08:31 AM | #9 |
Rottenwood Garage Member
Re-drill them and press in 5 studs and get some 71/72 drums. Very common practice. Then get one of the many kits for the front offered for a disc conversion or a simple 5 lug conversion (CPP) being one of them if you want to go that route fro the front. We just did it on a 69.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 02-09-2014 at 08:40 AM. |
02-09-2014, 09:26 AM | #10 | |
02-09-2014, 11:49 AM | #11 |
67-72 parts collector,…
Just remember the 70-72 rearends are 3/4" PER SIDE wider than the 67-69 rearends.
I would still buy new axles from Moser Engineering to replace those old axles. $260 from Moser Engineering. http://www.moserengineering.com/axle...spline-31.html Summit Racing sells them. http://www.summitracing.com/parts/msr-a3065gmt5
02-11-2014, 04:59 PM | #12 | |
Picked up the axle for a cool $100 from apparently a fellow member Thanks dude! Helps a lot |
02-11-2014, 05:37 PM | #13 |
So you scored Axel's from a member on this board on a thread I started and you are just rubbing it in my face?
02-11-2014, 06:06 PM | #14 | |
I'll thank all the replies myself, cause it helped me out of the same boat |
02-16-2014, 09:02 PM | #15 |
02-16-2014, 09:03 PM | #16 |
02-16-2014, 09:07 PM | #17 | |
Thanks |
02-16-2014, 09:13 PM | #18 | |
Thanks for the input. Good to know I have a few options here. |
02-16-2014, 09:18 PM | #19 | |
Tags |
5x5 bolt pattern, axles |
