03-02-2021, 04:25 AM | #1 |
Front drop/tire fitment issues.
I am having an issue with my 17x7 4"bs wheels with a 235/55-17 tire protruding from the wheel well. The teruck is lowered 4" in the front with 2" spindles and 2" springs. After doing some research i have conluded that my problem may be caused by the spindles. Unfortunetly do not recall which brand i have. I do know they arent a high end brand like belltech or western. So i have a few questions.
1. Is it true that djm is the only brand of spindle that does not widen the front "track"? 2. How do i know what brand if there isnt a name or part # in the casting? 3. For anyone responding can you include all relevent specs for your drop/wheel setup? Please and thank you
my reaction when i realized the true condition of my truck? 3 words...un........... believable |
03-02-2021, 04:26 AM | #2 |
Re: Front drop/tire fitment issues.
I probably should mention that my truck is a 93 gmc sierra c1500.
03-02-2021, 09:09 AM | #3 |
Just thought that i might also mention that i am unable to post any pics for reference. Photobucket now required a paid sub of like $10 a month or something. Thats a bit much for something i might use a few times a year. Sorry. Not sorry.
03-02-2021, 11:12 AM | #4 |
What is your wheel offset? I have 22x9 on my 97 C1500 with Belltech spindles and it tucks in the fender.
BTW DJM stuff is junk and wouldn’t use it. Here are my wheel specs:
Customization is what you want it to look like -- not what other people think it should look like |
03-02-2021, 01:25 PM | #5 |
67-72 parts collector,…
React Suspension has a new modular spindle for the 88-98 OBS trucks.
I would give them a call. https://reactsuspension.com/collecti...c1500-8898-001
03-02-2021, 01:50 PM | #6 |
driving is in my blood
Sounds like the problem is the wheel offset.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-03-2021, 06:22 PM | #7 |
So what is the issue? The tire sticks out too much? 7" wheel with 4" b/s should tuck. That's prolly close to stock wheel size. My Tahoe is lowered via cut coil, it's more than 2" now, with stock wheels it fits fine. Even with the 8.5" vette wheels, and spacers it doesn't push it out. Those spindles push it that much?? Got a pic?
03-04-2021, 07:15 AM | #8 |
thanks for the response. my wheel has a 4" bs with 0 offset.
03-04-2021, 07:16 AM | #9 |
thanks for the response EVERLET. my wheel has a 4" bs and 0 offset.
03-04-2021, 07:21 AM | #10 |
just the other day i watched a youtube video in which the guy had lowered his 94 or 95 with coils a control arms. he had an 8" truck rally with a 225/70 that fit just fine. that certainly added to my confusion.
03-04-2021, 07:40 AM | #11 |
apollogies for look like a moron when i post replies. i obviously havent been on here for a long time and have forgotten how
03-04-2021, 07:54 AM | #12 |
lolife99 those spindles look legit and would like fix my issue (if it is my spindles) but the brake requirement is a bit confusing. i suppose it would help to know if i have hd brakes.
03-04-2021, 01:27 PM | #13 | |
They know these trucks and can help you with their React Suspension products. They are the ones that developed these drip spindles. https://azproperformance.com/ They also have a Facebook page
03-04-2021, 01:35 PM | #14 | |
The 92-98 trucks had the HD spindles with a 1.25” wide rotor. The 88-91 trucks can easily be convert to the HD rotors. But you’d also have to change calipers.
03-04-2021, 11:57 PM | #15 |
You never mentioned how much the wheel is sticking out. To me it’s not a spindle issue. Factory wheels were usually between 35-40 mm offset. You switching to a 0 offset wheel pushed the wheel outward around 1.5”. Put a factory wheel on there just to see where the wheel is.
Back in 1997, I had 15” wheels on there with the belltech 2” and 2” springs. After cutting the lip of the lower control arm, no issues. Hell I put the 15” back on for nostalgia sake. It looks like the wheel sticks out but you have to remember that the front of the fender tapers in.
03-06-2021, 08:07 AM | #16 |
lolife99 thanks for the info about the brakes also. My truck is a 93 sierra c1500 so it should have hd brakes. this thing was never molested by the original owner. I paid $1500 for it almost 3 years ago. the 1st thing i did was repaint a set of rallies and new tires (15x6.5, 235/70's front 15x8, 265/70's rear) Then a few months later i lowered it and went thru the brakes in the process. new calipers,pads,rotors,dust shields,and steel braided hoses.
03-06-2021, 08:21 AM | #17 |
everlet. thanks for the reference pics. what are the specs of that combo? please and thanks. unfortunetly i dont have pics of the truck with the 15x6.5, 235/70's post lowering. that settup tucked probably 1/2". i do have a few pics of it with the new 17x7 and a 235/55 on the front (i did a quick test fit before bolting the 2nd set of vn504's on my wagon). just havent decided if i want to upgrade my photobucket account.
