Old 05-14-2016, 04:45 PM   #1
66clow
66clow's Avatar
Firewall holes
What are you all doing to plug holes in the firewall? Where can you get a variety of plugs?
Also what covers this hole? Under the Wheelhouse.
66clow is offline   Reply With Quote
Old 05-14-2016, 05:27 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Firewall holes
This is what goes there. They are a 7/16" bolt, 1-3/4 inches long, with a 2-1/4" integral washer on it.
LockDoc
Leon
Old 05-14-2016, 07:03 PM   #3
66clow
66clow's Avatar
Re: Firewall holes
LockDoc
Awesome thanks
Old 05-14-2016, 09:52 PM   #4
LockDoc
LockDoc's Avatar
Re: Firewall holes
Originally Posted by 66clow View Post
Awesome thanks
No problem. If there is a pretty good size gap between the inner panel and the cab brace this is the type of shim that goes in there.
LockDoc
Leon
Old 05-14-2016, 10:21 PM   #5
66clow
66clow's Avatar
Re: Firewall holes
LockDoc
I noticed one side was touching and the other had a quarter inch gap.
Old 05-14-2016, 10:50 PM   #6
LockDoc
LockDoc's Avatar
Re: Firewall holes
The shims are almost a 1/4 inch thick.
LockDoc
Leon
Old 10-20-2020, 09:02 PM   #7
Tripmiester
Re: Firewall holes
I see this is a old post, I have these shims and was wondering where they go!
Steve
Tripmiester is offline   Reply With Quote
Old 10-20-2020, 11:48 PM   #8
LockDoc
LockDoc's Avatar
Re: Firewall holes
Steve
Sometimes they fall out when disassembling the front clip and people have a hard time figuring out where they came from.....
Not every truck has them and there will usually be a different number of them side to side.
Here is a picture of where the bolts with the large washer go. The "F" shims go between the inner panel and this cab support rail. The shims are made that way so you can start the bolt, then hook the shims over the bolt and they won't fall out while you are tightening the bolt.. The inner panel has a good size square hole in this location.
LockDoc
Leon
Old 10-21-2020, 07:33 AM   #9
Tripmiester
Re: Firewall holes
So right here?
Sorry the last post was supposed to be a question mark not a exclamation point.
Steve
Old 10-21-2020, 10:20 AM   #10
LockDoc
LockDoc's Avatar
Re: Firewall holes
So right here?
Steve
Yes, that is the bolt with the big washer.
LockDoc
Leon
