11-23-2022, 11:32 PM | #1 |
Pinion angle
When building my '71 Suburban, I changed all body mounts, engine mounts, trans mount, trailing arm and track arm bushings with polyurethane. I added a 700r4 and shortened my two-piece driveshaft by 3". I also changed only the front springs with 2" lowering springs. I am getting a slight vibration at certain speeds and I am thinking it could be the pinion angle is off after changing these things. Any thoughts? Could these mods have affected the pinon and trans angles?
11-23-2022, 11:48 PM | #2 |
67-72 parts collector,…
Re: Pinion angle
Have you checked your driveline angles?
This is a good angle calculator from Spicer. https://spicerparts.com/calculators/...gle-calculator
11-24-2022, 10:18 AM | #3 |
Re: Pinion angle
Adding a 700R (longer trans) and shortening the DS changed your DL angle. measure it (link posted is a good one)
You may need to add an angled shim on rear end... |
11-24-2022, 02:48 PM | #4 |
Re: Pinion angle
Between the transmission swap and the today's not exact factory engine and transmission mounts it's likely your angles need adjustment. The link goes the drive shaft work I did on mine. Post 348.
Two years later I ended up installing 2 degree shims in the rear axle mounts after converting to a one piece drive as part of installing a Gearvendor. Unfortunately I didn't document the swimming of the shaft very well. http://67-72chevytrucks.com/vboard/s...698377&page=14
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-24-2022, 03:32 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Pinion angle
Actually, shortening the front shaft doesn't change the DS angle because the carrier bearing is in the same location. The fact that you went from rubber to polyurethane mounts may contribute to your feeling something now that you didn't with the rubber mounts. Also, did you have both shafts with the carrier bearing balanced when the shaft was shortened? I dont think any of the changes you've made would affect the
pinion angle enough to cause a vibration. On page 4-24 of the service manual it describes rotating the rear shaft 4 splines to the left side of the vehicle. Model CE31403 rotates only two splines to the left. That phases the rear shaft to the front shaft regardless of the pinion yoke position. You should have both front and rear shafts with the (preferably new) carrier bearing balanced assembled together with new u-joints at a DS shop.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 11-24-2022 at 03:58 PM. |
11-24-2022, 03:49 PM | #6 | |
Re: Pinion angle
Assuming the shortened shaft was rebalanced?? Still would be a good idea to check DL angles Agree poly mounts do transmit more harmonics/vibration as rubber does a better job of absorbing those Also look for any sounds of "grounding" (exhaust hitting x member or something) |
11-24-2022, 11:04 PM | #7 |
Re: Pinion angle
I did the trig on the effect an additional 4" on the transmission or to put another way 4" shorter drive-line.
This assumes the drive-shaft had a 3 deg down angle. The longer transmission increased the angel .2 degrees. That's point two degrees. After shorting the drive shaft the angle was 3.2 degrees. It appears to be within tolerance. |
11-24-2022, 11:50 PM | #8 | |
Re: Pinion angle
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 11-25-2022 at 12:07 AM. |
11-25-2022, 01:39 AM | #9 |
Re: Pinion angle
I agree with the two shaft analogy. First shaft changes nothing.
I was only attempting to clarify the question how much lengthening the transmission changes the angle of the joint. |
11-25-2022, 04:03 AM | #10 |
Re: Pinion angle
Guys, you are hammering me on details not on the actual angle differences adding 4" makes....
I just used the 3 deg as an example. I could have used Collinear and the results wouldn't varied enough to measure the differences with the protractors used to measure these angles. If I use 1 deg for the math the difference is .1 deg. That's one tenth of a degree when you add 4 inches to the transmission. It also changes both u-joint angles the same amount. Show me your math and I will show you mine. LOL. Cheers |
11-25-2022, 04:04 AM | #11 |
Re: Pinion angle
Would think the added length would add more angle than that. The way I understand it for a shaft with three ujoints one has to be less than 1 degree and the two left should match within 1 degree. Basically, one has to disappear. Actually measuring the angle would be better than using calculations.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
11-25-2022, 04:06 AM | #12 |
Re: Pinion angle
One shaft only in my example. 55.5" between joints. With three shafts, yes it would be more angle as the distance between point would be much less.
11-26-2022, 11:33 AM | #13 | |
Re: Pinion angle
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-26-2022, 11:46 AM | #14 |
Re: Pinion angle
To Ironangel A thumbs up. |
11-26-2022, 12:21 PM | #15 |
Re: Pinion angle
I am going through something similar with my build and highly recommend this magnetic AccuRemote Digital Electronic Magnetic Angle Gage Level/Protractor/Bevel Gauge
it's really easy to over think this so don't let it the differential needs to point up at the same angle as the transmission points down, so if the trans angles down 5° try to angle the rear end up 5° or as close to that as you can then there's the 3° rule which basically means the driveshaft shouldn't angle down from the transmission more than 3° as it slopes down to the rear end same from the rear end the driveshaft should not slope up more than 3° to run up to the transmission this gauge makes it easy to measure stuff, you can stick it to the driveshaft right by the rear end and see what it says, then remove the driveshaft from the rear end and measure the angle of where the U joint goes in to the yoke and see what the difference is, again should be 3° or less |
11-26-2022, 01:33 PM | #16 | |
Re: Pinion angle
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 11-26-2022 at 01:44 PM. |
11-26-2022, 01:46 PM | #17 |
Re: Pinion angle
You have two beers on ice brother, Cheers!
11-26-2022, 04:38 PM | #18 |
Re: Pinion angle
Several posts have stated that angles ahead of the carrier bearing have no effect on the DS angle. This is only true when the engine/transmission angle and the front drive line angles are in the same direction. As shown in Ironangel's drawing.
If the engine and front drive shaft are at opposite angles then changes in transmission length may cause the angles to change enough be out of spec. When I replaced my factory T400 with a T350 and a Gearvendor it changed the angles enough to require me to install 2 degree shims in the rear axle mounts and put a spacer under the carrier bearing. Admittedly that is a much longer change in transmission length Before I did the Gearvendor swap I installed one of the billet poly carrier bearings Ironangel discusses. To bring the angles in spec I had to adjust the engine/transmission angle as follows. Transmission 3.5 degrees down Front shaft 0 degrees Rear shaft 2 degrees UP Pinon angle 2 degrees DOWN I jacked the rear of the transmission up and slid a 1/2" piece of plate under the mount, lowered the transmission back down and after double checking my ride height, I took a new round of readings. Now the transmission angle is 2 degrees and the front shaft is 1 degree. Victory at that end! The second shaft was now just shy of 2 degrees. Now with a one degree difference between the transmission and the front shaft angles, and with the pinon and the transmission at the same angle I should be good as long as the other two u-joint angles aren't too extreme This arrangement puts the u-joint operating angles at: Front 1* Center 3* Rear. 4* I just wanted to bring this up so no one goes away thinking there is no need to check the angles forward of the carrier bearing.
11-26-2022, 08:43 PM | #19 |
Re: Pinion angle
WOW! Didn't realize how detailed this post was gonna be or how many opinions there would be. Gotta get a pinion angle finder now....
Thanks guys! |
11-26-2022, 11:11 PM | #20 |
Re: Pinion angle
This post has definitely gotten complicated! I'm working through this with my 2-piece driveshaft now. I used 4 inch lowering springs and had the front driveshaft shortened when the 700r4 was installed. After a while I realized that there was no slip in the rear section and the driveshaft had destroyed the center bearing. I just had the CPP cross member and tubular trailing arms installed along with the poly center bearing and their rear slip driveshaft. Everything looks like it will work and now I just need to have the center yoke replaced, since there is metal missing where the c clips go, and get the unit balanced. I'm hoping this will do the trick and I won't have to do any angle measuring!
11-27-2022, 02:12 AM | #21 | |
Re: Pinion angle
While a maximum 3 degree operating angle is recommended for optimal life and reduced vibes. It is not set in stone. The joint will not self destruct or destroy itself in short time if that is exceeded. No 4x4 I have ever owned has been kept to that. Never remember changing ujoints regularly on any of my lifted trucks and they have all been daily drivers. I think some may not understand the difference between the operating angle and the trans/driveshaft/pinion angle. Good to see a post that mentioned it. 3 degrees references operating angle. While the components create the operating angle they are not the angle that is most important.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 11-27-2022 at 02:58 AM. |
11-28-2022, 09:22 AM | #22 |
Re: Pinion angle
Just did mine I used an app on my phone for angle finder
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-28-2022, 11:24 AM | #23 |
Re: Pinion angle
When you had the front section shortened, did you take both pieces in to the shop or just the front piece? And did you pull the whole assembly out as a whole or pull the 2 pieces out separately?
11-28-2022, 02:15 PM | #24 |
Re: Pinion angle
IMHO I find the tremec phone app comes up with different #'s each time. More because the phone case (better to use it without a case) you have to hold STEADY against the point you measure. A $5 magnetic analogue angle finder, for me, is more stable and "hands free" so the needle settles for an accurate reading. One option for getting trans tail angle is hold the angle finder against the flat front of damper as it is dead nits the same angle as engine/trans
Lowered truck often needs an angled shim on rear end to get DL angles back "within" spec and also flat shims between trans and rear mount. This is where using an angle finder tells you wtf "your" angles are and which direction the tail of trans needs to move and rear pinon |
11-28-2022, 03:10 PM | #25 |
Re: Pinion angle
So are you guys saying that changing from a TH350 to a longer 7004R trans and having the front section of a 2 piece driveshaft will change the angles to the point that a vibration will occur. I have a C20 totally stock suspension with rear leaf and 4.10 gears. Very noticeable vibration at ~45 to 50 MPH. Both shafts were rebalanced when shortened. Shimming Carrier bearing, 2 and 4 degree axle shims, many hours later and nothing really changes. Is not wheels, tires as these have been changed.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
