01-11-2021, 08:40 PM | #1 |
700r4 manual valve
I have a chance to get a 700r4 but it has a manual valve. I currently have a 200r4. Other than taking it to the tranny shop and having it changed to an automatic valve (they want to tear into it, prior to giving me a price range) is there a chance of me being able to use it with the manual valve? would a 3 speed column let me use it?
thanks for replies/input |
01-11-2021, 10:14 PM | #2 |
Re: 700r4 manual valve
You can use it, but with a 3 gear detent on that column shift, you won't be able to get all four forward gears. Don't forget about the TV cable set up, which is a must if you don't want to blow that 700R4.
01-12-2021, 10:08 AM | #3 |
Why replace a 200-4R with a 700R4? I don't see much of an advantage.
01-12-2021, 02:07 PM | #4 | |
I love my 700R4, but 2004R's are stronger and actually have even better gearing.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
01-13-2021, 11:45 AM | #5 | |
700R4 has a lower first gear (3.06 vs 2.74). Coupled with a high axle ratio like 3.08/3.23/3.42 it helps with "best of both worlds" startability and economy on highway. It also has a lower reverse if that helps. Overdrive is about the same at .67 and .70. That is one of the reasons I prefer a 700 over a 200.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 01-13-2021 at 11:50 AM. |
01-13-2021, 12:59 PM | #6 |
The best reason to swap would be if you have plans to tow. I was told by several quality rebuilders that 2004r's will not survive towing. Of course I found this out after geting a core 2004r to rebuild.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-15-2021, 01:32 AM | #7 |
