Old 09-21-2021, 09:53 PM   #1
Bullzak_83
Alt Mount
Question, does anyone have a picture of how this bracket for the alt,mounts.
I know this is not right, but I'm trying to figure out the correct way of setting it up. It's on my 70 cst 10. I have cut a extension to bring it out away from the block. I have evan noticed that the fan on the alternator was dragging the bracket somewhat, I actually ground the bracket, so it would clear the fan.
Bullzak_83 is offline   Reply With Quote
Old 09-21-2021, 10:12 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Alt Mount
Here is a 307, same water pump as 350, short water pump same brackets
http://67-72chevytrucks.com/vboard/s...89&postcount=8
Old 09-21-2021, 10:24 PM   #3
zosoppp
Re: Alt Mount
on my 1970 c10, sbc350, I have the upper arm connected to the REAR of the alternator's top ear with the bolt going in from the firewall side. Also the engine end of the upper arm is connected to the head with the same bolt as the base, no spacer forward.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 09-21-2021, 10:31 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Alt Mount
You have the wrong adjustment arm. If you notice the one on zosoppp's engine has a lot more curve to it. That is the one you need so it can be mounted on the back of the boss that the bolt goes into.... I think it also has an offset where it bolts to the lower bracket.
LockDoc
Leon
Old 09-21-2021, 10:31 PM   #5
Bullzak_83
Re: Alt Mount
I've to attach on the back side, but the width of the bracket would not allow the bolt hole to line up with the bracket, i guess I could modify the bracket
Old 09-21-2021, 10:33 PM   #6
Bullzak_83
Re: Alt Mount
Could you resend the link, i couldn't get to open.
Old 09-21-2021, 10:36 PM   #7
Warrens69GMC
Re: Alt Mount
here
https://67-72chevytrucks.com/vboard/...89&postcount=8
Old 09-21-2021, 10:39 PM   #8
zosoppp
Re: Alt Mount
LockDoc
Here is the lower end of the upper bracket.
Old 09-21-2021, 10:41 PM   #9
LockDoc
LockDoc's Avatar
Re: Alt Mount
OK, I see that that one is straight. Thanks.
LockDoc
Leon
Old 09-21-2021, 10:43 PM   #10
zosoppp
Re: Alt Mount
LockDoc
Actually I was thinking that there might be a little bend in it from that photo, hard to tell, though.
Old 09-21-2021, 10:47 PM   #11
LockDoc
LockDoc's Avatar
Re: Alt Mount
Could be. A picture of the whole arm from more straight on would be the only way to tell for sure.
LockDoc
Leon
Old 09-21-2021, 11:13 PM   #12
zosoppp
Re: Alt Mount
LockDoc
Found another angle installed, definitely looks like two bends in it.
Old 09-21-2021, 11:53 PM   #13
LockDoc
LockDoc's Avatar
Re: Alt Mount
Yep, I thought it should have offset bends in it.
LockDoc
Leon
Old 09-22-2021, 03:58 PM   #14
NorCalC20LWB
Re: Alt Mount
I had the same issue, bought the longer year alt bracket which arrived straight, no bend at all. Put a couple bends in it with a vice, very easy and worked great.
NorCalC20LWB is offline   Reply With Quote
Old 09-23-2021, 08:40 AM   #15
Grumpy old man
Grumpy old man's Avatar
Re: Alt Mount
With the short water pump the 71-72 brackets work note the lower bracket in the picture below . The generic aftermarket brackets sold don't work well with taller valve covers .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-23-2021, 09:58 AM   #16
zosoppp
Re: Alt Mount
Yeah, that's one of the gotchas of going to the internally regulated 10SI is that the alternator does not have the clearance for the valve cover when changing/adjusting the belt tension.
I assume that the 12si is similar in that regard.
Next time I have to do that I might just pull the valve cover to get the belt off and on again.
Old 09-30-2021, 05:51 PM   #17
Bullzak_83
Re: Alt Mount
Hey Grumpy Old Man, that's the problem I having. I have tall valve covers and that's why I added the extension. You don't happen to have a part number for that longer bracket on the top do you?
