01-25-2023, 11:29 PM | #1 |
Drill / Tap front engine mount hole
I am needing to drill and tap this hole to add a factory GM serpentine belt system. Block is a 327 from a 65 impala This boss is on the passenger side between the timing cover and fuel pump. The hole needs to be 1/2” to 3/4” deep at the most.
Any tips or advice before I start drilling?
1965 c/10 swb 1969 c/10 lwb |
01-25-2023, 11:44 PM | #2 |
Re: Drill / Tap front engine mount hole
Yes, I have Advice
I would make a drill template plate/ jig. One that you can use the timing cover bolt holes that are beside to Bosses. Then use a Drill stop on the drilling process.
01-26-2023, 05:18 PM | #3 | |
01-26-2023, 05:48 PM | #4 | |
Well done Rusty! |
01-26-2023, 06:46 PM | #5 |
If you are not in a hurry I can make you a jig.
01-27-2023, 03:30 AM | #6 |
Thanks for everyone’s advice! I got it drilled and tapped successfully. Only went in about 1/2”-5/8”. It never went into the fuel pump pushrod hole.
01-27-2023, 11:44 AM | #7 |
01-27-2023, 01:45 PM | #8 |
You bet. I have a bare bow tie block, it was drilled about 1” and still wasn’t into the pushrod hole either. I posted this since the block I had to drill is a different casting and wanted to hear from people who have done it.
01-27-2023, 04:43 PM | #9 |
Moderator
My roller cam 350 was drilled but not all the way through. Pain in the keester to install a fuel pump.
