Old 03-15-2008, 01:34 AM   #1
hotrodhomi
hotrodhomi's Avatar
Cutting front bag cups- again
I know I've seen this question before, but the words are too short from the search function to work.
How much more drop will I get if I cut my cups down from 2 3/8" to 1 1/2"? I wouldn't think that it would be equal to the amount cut off. If I do this can I still use my stock shock mount? This is on a '72 with 73+ control arms.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-15-2008, 01:49 AM   #2
shifty
Questionable
shifty's Avatar
Re: Cuting front bag cups- again
In this thread, he cut the front cups down by 1.5".
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-15-2008, 02:03 AM   #3
The Fab Shack
the 'around about' on cutting cups and front suspensions is this.. if you cut the cup .500 inches, then you'll get around a 1" drop at the wheel.
The Fab Shack is offline   Reply With Quote
Old 03-15-2008, 02:46 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
My understanding is 2:1 ratio, cut vs. drop...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-15-2008, 03:56 PM   #5
HotRodYJ
HotRodYJ's Avatar
I cut mine to 1.5" total cup height. from what I could gather that's about as short as you can go safely. The bag may touch the arm at full drop, but wont rub when aired up so no harm done. 2:1 is a pretty good rule of thumb cut vr drop judging from how mine worked out.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 03-16-2008, 12:03 AM   #6
68laydout
Junior Member
68laydout's Avatar
Curious as to what you guys are using to cut the cups?
68laydout is offline   Reply With Quote
Old 03-16-2008, 12:20 AM   #7
HotRodYJ
HotRodYJ's Avatar
I measured the 1" I needed to cut off with 1" wide masking tape. Then use a 0.045" thick cutting disc in a 4 1/2" grinder to cut right along the edge of the tape. Really nice straight cut this way and doesn't take very long at all.
Old 03-16-2008, 12:21 AM   #8
Shane
Shane's Avatar
I plan on cutting a second pair i have on a lathe using a cut off tool.
Shane is offline   Reply With Quote
Old 03-16-2008, 12:30 AM   #9
shifty
Questionable
shifty's Avatar
I was thinking I was going to use a bandsaw. I wound up selling my cups within 2 weeks of buying em, though.
Old 03-16-2008, 06:02 AM   #10
hotrodhomi
hotrodhomi's Avatar
Why did you sell. Are you using something different?
'66 impala ht
Old 03-16-2008, 10:06 AM   #11
shifty
Questionable
shifty's Avatar
Yeah, when I realized I could get ART Strong Arms tubular arms for less than $700, I weighed the pros and cons, and decided this was the best deal for me. No BS worries with angle correction, bag mounts, bags rubbing, etc. So I ran with that and sold my cups.
Old 03-17-2008, 12:10 AM   #12
Frizzle Fry
Frizzle Fry's Avatar
The Fab Shack had it right. 1/2 = cut/drop
Frizzle Fry is offline   Reply With Quote
Old 03-17-2008, 12:21 AM   #13
Frizzle Fry
I think I've read that the 73+ arms have shallower spring pockets. This is how people can get away with cutting the cups down to 0.75"-1" with those arms. Again, I've only read this and have no first hand exp with the 73+ arms...
Old 03-17-2008, 05:31 AM   #14
hotrodhomi
hotrodhomi's Avatar
I ended up cutting mine to 1 5/8" and I have only about 1/4" of clearance when fully slammed.
'66 impala ht
Old 03-17-2008, 06:50 AM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Same here. 1" was too short...
-Chris
Old 03-18-2008, 05:16 AM   #16
jlaird
jlaird's Avatar
hotrodhomi, gringo, 1/4" clearance from and to what? bag to arm? So with a 1 5/8 cup, the bag wont touch the arm when fully slammed?
Did you guys use the SD cups? I thought I remember reading they are slightly too wide for the cup to lay down on the bottom of the spring cup.
jlaird is offline   Reply With Quote
Old 03-18-2008, 09:15 AM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
The bottom outside edge of the lower bellows rubbed the spring pocket at the inner edge(towards the cross-shaft) and where the pocket bulges to clear the shock mount bolt. At 1.5" total height using SD cups, I cleared the inner but had to massage the shock mount area.
1 5/8" should be perfect. These problems were all at ride height with the bag inflated to 6" tall. Deflated will touch, but it shouldn't matter...
-Chris
Old 03-18-2008, 05:23 PM   #18
hotrodhomi
hotrodhomi's Avatar
Re: Cutting front bag cups- again
I'm not sure where my cups are from, I bought them from a site member that wasn't going to use them.
'66 impala ht
Old 04-09-2008, 06:44 AM   #19
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I cut 1" off my SD cups, on a lathe. I have a little bit of bag touch on the LCA when aired out, but no big deal.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 04-09-2008, 06:41 PM   #20
gringoloco
A guy with a truck
gringoloco's Avatar
Just saw this- Damn you dyslexia!!!
-Chris
Old 07-11-2022, 08:32 PM   #21
jondancer
So 1.75” would be a good fit ?
jondancer is offline   Reply With Quote
