Old 10-09-2021, 10:58 PM   #1
forestb
forestb's Avatar
Power steering pump recommendations
I am looking for a new Saginaw P Series style power steering pump. I am looking for some brand recommendations. I was looking at Borgeson pumps because I I heard of them before but I didn’t like the way that the tube that comes out of the pump is bent. They all look pinched at the bends.
forestb is offline   Reply With Quote
Old 10-10-2021, 06:46 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Power steering pump recommendations
Not sure if you've seen this info page you can download. I'm using the 73-74 pickup, 8 cylinder, pulley retained by nut. http://www.alangrovecomponents.com/i...s/pspsheet.pdf
As far as what manufacturer to recommend I don't know.
Old 10-10-2021, 05:04 PM   #3
forestb
forestb's Avatar
Thanks that should help with trying to figure out what I have on there now so that I can replace it.
Old 10-10-2021, 05:06 PM   #4
forestb
forestb's Avatar
The one I have was on the truck when I bought it 20 years ago and it was pretty banged up then.
Old 10-21-2021, 11:48 AM   #5
The Rocknrod
Moderator
Did you ever find a new pump?
Old 10-21-2021, 12:06 PM   #6
forestb
forestb's Avatar
Nope. Sense you are the only one that has replied that project is on the back burner. It is not in needing of immediate replacement.
Old 10-29-2021, 09:03 PM   #7
61ChevyPanel
Active Member
61ChevyPanel's Avatar
The Alan Grove site has some great info about pumps http://www.alangrovecomponents.com/i...s/pspsheet.pdf
61ChevyPanel is offline   Reply With Quote
Old 10-29-2021, 09:58 PM   #8
forestb
forestb's Avatar
Thanks I will take a look
Old 10-30-2021, 08:07 PM   #9
forestb
forestb's Avatar
So I think I either have a 87-91 chevy pickup pump or a 75-78 chevy pickup pump. I am not sure if it has an o ring fitting or an inverted flare fitting
