08-07-2022, 12:33 PM | #1 |
Active Member
Bench Seat Question
I think I have the wrong bench seat for my 69 C10. I know it was in the truck when I took it apart 12 years ago, but it doesn't line up with the floor holes.
Seat bracket outer bolts holes are 47.5" wide and the outer holes in the floor are 51" apart on center. I do not remember how the PO had it mounted. My question do you build/buy an adapter (if there is such a thing) or just buy the correct seat? My guess this seat came out of a later model truck. Thanks |
08-07-2022, 01:07 PM | #2 |
BlahBlahBlah
Re: Bench Seat Question
From the picture the seat looks too narrow. Mounting it up centered in the cab would probably have the driver very off center from the steering wheel. But maybe the picture just makes it look off?
... Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
08-07-2022, 01:10 PM | #3 |
This seat was in my truck when I got it but two things. It was very dirty and the installer had just drilled new holes in the floor to mount it.
First, I sprayed it down with super clean, turned my pressure washer to its lowest setting, and washed it until the water ran clean. Figured if I messed it up I wasnt loosing anything. Then I welded up the holes in the floor and made me some brackets to use the factory locations.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
08-07-2022, 01:46 PM | #4 |
Kinda looks like a squarebody seat with the seat belt holes and how the seat bottom curves in at the hinges.
If you like the seat you have, make some sort of way to bolt it down. If you were planning on recovering it or doing any changes to that seat and still want to keep a bench seat, go for the correct bench even if you have to restore the correct one
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-08-2022, 11:30 PM | #5 |
Active Member
Thanks for the information- just as I thought it's from a square body.
Now I'm looking for a correct bench seat for my 69 c10 |
08-09-2022, 07:41 AM | #6 |
Yep that seat is from a Square Body, a 1981-87 to be exact.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
08-09-2022, 09:01 AM | #7 |
That bowtie upholstery design must have been something available to purchase as a kit because I have seen a lot of those seats over the years. Back when Truckin' magazine was a thing.
Lots of people like them. If you steam clean that one and put it up for sale you will likely have more than enough money to buy a correct one for your truck.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-09-2022, 09:41 AM | #8 | |
