01-31-2010, 06:26 PM | #1 |
Rear Axle Codes
Does anyone have the info to decode the axle codes that are stamped on the top of the left hand tube of the rear end for all years (67-72) including Burbs? I found some info but it only included 67 and 68-nothing for my 1970 trucks.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-31-2010, 08:39 PM | #2 |
member #16
Re: Rear Axle Codes
Post the numbers. someone will decode them.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-31-2010, 10:46 PM | #3 |
Re: Rear Axle Codes
The code on the tube is TDE. I searched the web some more tonight and found an answer to someone's question on that rear axle code on a build sheet and the answer was a 3.07 gear. Don't know for sure if that is correct. Truck had a 307 with a 4 speed.
02-01-2010, 02:40 PM | #4 |
member #16
Re: Rear Axle Codes
You are correct. 3.07:1 for code TDE if the gears haven't been changed.
10-28-2012, 05:12 PM | #5 |
Re: Rear Axle Codes
help please.
how about g BXG0141 |
10-28-2012, 05:59 PM | #6 | |
Re: Rear Axle Codes
http://67-72chevytrucks.com/vboard/s...16#post5668516 http://www.gmpartswiki.com/browse
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 10-28-2012 at 06:06 PM. Reason: Never let a dog type! Too many typos! |
04-09-2013, 06:05 PM | #7 |
Re: Rear Axle Codes
I have 12 bolt rear end with this code stamped on the right tube:
HE121W Any info. would be great, thanks |
04-09-2013, 06:29 PM | #8 |
member #16
Re: Rear Axle Codes
It looks like code HE is a 3.07:1 ratio. It is still a good idea to pull the cover and put some fresh oil in. You can check the no's stamped in the ring gear at the same time.
04-09-2013, 07:44 PM | #9 |
Re: Rear Axle Codes
Can you tell what year from this code HE121w
It has a hole cast into the pumpkin for the panhard bar. |
04-09-2013, 07:52 PM | #10 |
member #16
Re: Rear Axle Codes
1965-1966
04-09-2013, 11:59 PM | #11 |
Re: Rear Axle Codes
Do you know when the 12 bolt rear end went to 30 spline axles?
04-20-2013, 03:03 PM | #12 |
Re: Rear Axle Codes
Found another 12 bolt posi but want to know what year. This is stamped on the pass. side tube: HC0829W The ring gear is stamped 381778 11 41 GM 8 66 1. Any help would be great. Thank you for your help.
04-20-2013, 04:02 PM | #13 |
Re: Rear Axle Codes
67 3.73 posi
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-02-2013, 06:56 PM | #14 |
I'm just glad to be here!
Re: Rear Axle Codes
I am trying to ID a rear end housing that I have. The code on the passenger side tube is:
HA02 17W On the driver side I found an 88 stamped on the tube. I don't care what gears or if it is a posi, I am just looking for the year model. I know it is a 12 bolt, with an Eaton Posi carrier and 4.10 Richmond gears. The housing appears to be a 65-72 since there are torch marks at an angle from cutting off the pads on the tubes. Any info on this would be great.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-02-2013, 07:09 PM | #15 |
Re: Rear Axle Codes
HA 65-69 3.73
0217 built February 17th W by Warren Gear
07-03-2013, 08:50 AM | #16 |
Re: Rear Axle Codes
Thanks Tim!
09-01-2013, 09:08 PM | #17 |
Re: Rear Axle Codes
Any help with this code: RAC 054W81? Thanks in advance!
Panel Beaters C.C. |
09-01-2013, 09:27 PM | #18 |
Re: Rear Axle Codes
How does a 72 CA30/PA30 4.57 open HO72 sound to you?
09-01-2013, 10:00 PM | #19 |
Re: Rear Axle Codes
Hmm, my rear end is a 12 bolt & currently has a 2.76 in it (I understand it could have been changed somewhere along the line) and I have no idea where it came from. HO72 looks like a 10 bolt. Pardon my ignorance, but what's a CA30/PA30 model?
09-01-2013, 11:58 PM | #20 |
Re: Rear Axle Codes
Sure would have been easier if you had mentioned that up front.
The application I gave was for a 72 C30 1-ton truck or a P30 1-ton step van. Since you have a 12 bolt (now stated) I spent some time looking for you. GM parts wiki is showing RAC as a 78 C10 12-bolt open 2.76 axle. There very well might be others. Here are some links if you want to look around. Sorry, my connection is not fast enough nor do I have the time for most non-67-72 requests that are outside stock applications. http://www.gmpartswiki.com/getpage?pageid=60434 http://www.gmpartswiki.com/getpage?pageid=60426
09-02-2013, 02:17 AM | #21 |
Re: Rear Axle Codes
Sorry for the lack of info, I didn't realize the code would span across two different types of axles. Thanks a lot for the info!
10-10-2013, 07:01 PM | #22 |
Re: Rear Axle Codes
10-10-2013, 07:58 PM | #23 |
member #16
Re: Rear Axle Codes
Correct 1965 c-10 w/3.73:1 ratio.
10-10-2013, 08:58 PM | #24 |
Re: Rear Axle Codes
thanks john, that's good news. it should have 30 spline axles in it. I assume that the carrier in it will only fit 3.73 and up gears, 4 series. but since i'm looking for a posi I should be able to get a truck unit for 3 series gears, correct. the 3.73 are just to much for the th350. thinking about a 3.08 or a 3.42 to calm it down a bit.
04-08-2015, 10:34 AM | #25 |
Re: Rear Axle Codes
I know this is an old thread but didn't want to start a new thread.
I picked up this rear end to rebuild for the truck. I know it is a 12 bolt but can someone decode the stampings please?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
