Old 05-23-2021, 11:31 AM   #1
Asshat
Asshat's Avatar
Parking brake setup w/different rear end
I have an 83 rear end in my 63 C20, and am looking for the brake cable parts and how to install. I previously had a propeller shaft brake.
I have the brake handle that mounts under the steering coulumn, and the rear end seems to have all the parts for attaching the cable. However, I am missing the triangular shaped piece, which I believe is mounted to the cable; are there more parts required?.
Is it a two-piece cable system? One cable attaches to the rear drum and the other cable connects to the brake lever? Or, is it a three-piece system?
I found these on RockAuto.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-28-2021, 10:43 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Parking brake setup w/different rear end
5 days later(!)- try and find someone local who will let you slide under their vehicle to scope out what the system should look like for your year truck.
~Steven
Simi Valley, CA
Old 05-28-2021, 11:39 PM   #3
kaycee
kaycee's Avatar
My 63 has a cable from each wheel to a crossmember by rear of trans. that attaches to a bar type pulley setup. Brake handle in cab has a cable that runs down to this set up so I guess its like a 3 cable system . My 63 Impala uses the same setup ,do a google search I saw a picture on here some where a while back. I'll try and get you a pic. tomorrow
https://www.google.com/search?q=63+C...&source=iu&ict
See if this link works
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 05-29-2021, 07:03 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Check out this post for the diagram - https://67-72chevytrucks.com/vboard/...3&postcount=13
Old 05-29-2021, 11:03 AM   #5
Asshat
Asshat's Avatar
That does help -Thank you!
292, 4-speed
Old 05-29-2021, 11:14 AM   #6
kaycee
kaycee's Avatar
So your wanting to hook up the 83 newer cables setup ,I just put a 71 rear in mine and was wondering along this same thing ,I like the heavier newer cable
2005 FXDWG stage3
63 IMPALA 327
Old 05-29-2021, 12:06 PM   #7
Asshat
Asshat's Avatar
I don’t really care about the newer cable, or heavier, I just want to know what parts to buy. And, make sure I get it put together the right way.
292, 4-speed
Old 06-05-2021, 07:42 PM   #8
AcampoDave
AcampoDave's Avatar
In 1966 they did away with the e-brake crossmember and the related mechanism replacing it with a simpler lighter design. The cable from the handle linked up to a triangulated cable secured to the frame with hook/eye type retainers. I personally dont have one like that, but I do know they are a desirable upgrade when converting to an automatic transmission.
As for me, I went backward on my '66 since my triangulated cable setup was thrashed and I already had the crossmember type in my stash. But here is a good link... http://67-72chevytrucks.com/vboard/s...d.php?t=527022
AcampoDave is offline   Reply With Quote
